Old 04-11-2022, 02:41 PM #16
John in NC John in NC is offline
Real Name: John
John in NC will become famous soon enough John in NC will become famous soon enough
Real Name: John
I just had my 2011 with 145,000 miles in for the airbag recall, and also had done:
Power steering fluid
Transmission fluid
Brakes/ brake fluid, had a rear driver side dragging caliper too...
Spark plugs were recommended but I didn't do it, OG plugs still.
Long ago I had the prop shafts lubed (driveshaft zerks?), they were dry. Should probably have that done again.
Up next I think I'll change the fluid in the front and rear diffs and transfer case. Rear for sure.
I don't think I've ever had the coolant flushed/ filled but I'd guess that is on the radar.
John in NC is offline   Reply With QuoteReply With Quote
Old 04-11-2022, 03:48 PM #17
CutthroatSlam CutthroatSlam is offline
CutthroatSlam is a splendid one to behold CutthroatSlam is a splendid one to behold CutthroatSlam is a splendid one to behold CutthroatSlam is a splendid one to behold CutthroatSlam is a splendid one to behold CutthroatSlam is a splendid one to behold CutthroatSlam is a splendid one to behold CutthroatSlam is a splendid one to behold
Transmission fluid
Our 2014 SR 5 has the same dragging caliper on rear driver's side. Pads wear unevenly. Guess I should replace the caliper.
Plugs should be done every 120K miles. Longer you leave them in there, the greater the chance they get stuck in there.
CutthroatSlam is offline   Reply With QuoteReply With Quote
Old 04-11-2022, 04:24 PM #18
BR06run BR06run is offline
Real Name: Bill R.
BR06run is on a distinguished road
Real Name: Bill R.
2010 Limited 143,000 miles. Driver side stop light not working. Bulb must be bad. Nope bulb is good. What then. Clean contacts and still not working. Bend contacts on bulb holder out a little more and it works fine. XM radio been bad for years now but who cares about that. Not me.
BR06run is offline   Reply With QuoteReply With Quote
Old 04-11-2022, 05:40 PM #19
TacoRunn0517's Avatar
TacoRunn0517 TacoRunn0517 is offline
TacoRunn0517 will become famous soon enough
My 2016 Trial is going in for 140K Routine Servicing on Wednesday. June 2022 will make it 5 years since I bought it new. I was doing way more driving but since I've been WFH since March 2020, I'm not driving as much as I use to. The only major repair that I had was replacing my leaking water pump around the 108K-Mile mark. Will be interesting to see how my Runner holds up over the next 5 years. I'd like to get 300K on the ODO before thinking about upgrading to a Land Cruiser.
2016 Toyota 4Runner Trail Edition - Magnetic Gray Metallic - 4x4 *** Trailfinder AT 265/70-178 *** 3M Obsidian Tint (30%) *** LASFIT LA Plus Series H11 H9 H8 LED Bulbs *** XenonDepot Xtreme LED Pro 9005/HB3 Bulbs (w/ DRL Driver) *** LASFIT LD Plus Switchback H8 H11 H16 LED Fog Light ***
TacoRunn0517 is offline   Reply With QuoteReply With Quote
Old 04-18-2022, 11:03 PM #20
dsfra's Avatar
dsfra dsfra is offline
dsfra is on a distinguished road
dsfra's Avatar
Looks like this thread has pretty much dried up. So thanks for all the input...
Next stop: Canyonlands / White Rim Trail. Someday...
2012 Silver Trail Edition, KDSS, Nav, 265/70-17 BFG A/T KO's, ScanGauge, B&M 70264 Tranny Cooler, 20" Opt7 LED Light Bar, LED DRL's, Prodigy P2 Brake Controller, Wired for Dual Wide-Angle Cameras on Rear of Trailer, Hitch and Rear Bumper Trailer Lights on Center Pin of Connector, Timbren Rear Bump/Springs, 19' Escape Trailer Thumping Happily Behind
dsfra is offline   Reply With QuoteReply With Quote
Old 04-27-2022, 11:29 AM #21
4r-4ever 4r-4ever is offline
4r-4ever will become famous soon enough
just keep driving it. bring a spare drive belt just in case. those coolant hose, lasts a very long time. bring a spare alternator or get your radiator replaced before a very long trip. i think those are the most important to keep the car moving.
4r-4ever is offline   Reply With QuoteReply With Quote
Old 04-27-2022, 12:35 PM #22
Transmission fluid
Prop shafts are supposed to be lubed every 5K miles.
Old 04-27-2022, 08:42 PM #23
TRDfan2011's Avatar
TRDfan2011 TRDfan2011 is offline
TRDfan2011 is on a distinguished road
TRDfan2011's Avatar
I just replaced rear brakes on my 2011 with 71500 miles. Same issue with driver's rear inner pad worn as if caliper is hanging up. That wheel continued to smell like the caliper was hanging up. Replaced the brake hardware and applied light CRC brake grease to the hardware. Thoroughly cleaned & put fresh grease on pins. Caliper is no longer hanging up. Hopefully that was the problem.
2011 Black SR5: Revo3s, K&N Air + Cabin filters, Aries Bullbar, Rhino Hitchstep, AVS Bug Deflector & In-channel Ventvisors. Real mods in sight...
TRDfan2011 is offline   Reply With QuoteReply With Quote
Old 04-27-2022, 08:47 PM #24
4runrr 4runrr is offline
4runrr is on a distinguished road
Originally Posted by ArthurKotb View Post
Rear calipers, rotors, pads at 126,170K 7/21
You win, 4runner with the most miles ever....
4runrr is offline   Reply With QuoteReply With Quote
Old 04-28-2022, 12:15 PM #25
Xtremluck's Avatar
Xtremluck Xtremluck is offline
Xtremluck is a splendid one to behold Xtremluck is a splendid one to behold Xtremluck is a splendid one to behold Xtremluck is a splendid one to behold Xtremluck is a splendid one to behold Xtremluck is a splendid one to behold Xtremluck is a splendid one to behold
Xtremluck's Avatar
2012 SR5 with 167K on it and exists as a dedicated off-road adventure vehicle:
Maintenance Schedule (Purchased with 71K on the odo so previous maintenance knowledge is spotty)
-Regular Mobil 1 synth oil and filter changes every 10,000 miles. Also grease all drivetrain zerks
-Engine coolant flush at 80K
-Transmission fluid drain and filter replacement at 144K
-Diff and transfer case fluid at 77K, 144K
-Spark Plugs at 150K
-Brake Fluid at 120K
-Brake pads and rotors at 73K, 117K
-Timing belt at 134K
-Various suspension setups: Bilstein 6112s, Icon CDCV and currently KING 2.5s w/custom length rears
Things that have broken:
-Multiple inner and outer tie rods
-Power steering rack at 133K
'12 Silver 4Runner SR5: 14+ facelift, CBI front, CBI Rear, Warn EVO 10-S, ARB Snorkel, Baja Designs 30" S8, Squadron Sports, S2 Rack Lights, King 2.5 Suspension, OME 899, 33" Cooper ST Maxx, Full CBI Skids, Metaltech Sliders, GFC Tent, ARB Awning
Xtremluck's 2012 SR5 Build Thread
Xtremluck is offline   Reply With QuoteReply With Quote
Old 04-29-2022, 09:45 AM #26
ArthurKotb's Avatar
ArthurKotb ArthurKotb is offline
Real Name: Rich
ArthurKotb has a spectacular aura about ArthurKotb has a spectacular aura about ArthurKotb has a spectacular aura about
ArthurKotb's Avatar
Real Name: Rich
Well the pads were replaced more frequently. I just meant that the caliper and rotor were replaced at that mileage.
Rich
2004 V8 4Runner 140K+ miles
Kentucky
ArthurKotb is offline   Reply With QuoteReply With Quote
Old 04-29-2022, 12:34 PM #27
Something_Awesome's Avatar
Something_Awesome Something_Awesome is offline
Something_Awesome will become famous soon enough
Just sold a 9.5 year old Honda with 89K miles. Still had the original timing belts. If the new owner wanted to take that car on a 5,000 mile road trip around the USA, it’d make it with ZERO problems. You’ll be fine. If after inspecting the car the dealership can’t identify any potential issues, I would not worry.
I suppose the only worry is hoses. You could always change them now. They’ll go another 10 years. If you don’t plan on keeping the car for 20 years, then might as well do them now as opposed to waiting for one of them to crack.
Something_Awesome is offline   Reply With QuoteReply With Quote
Old 04-30-2022, 03:51 PM #28
2000se 2000se is offline
2000se is on a distinguished road
Wow.. you be driving!
I've got an 02 that just 310k...12 years older than yours and we're at the same mileage!
2014 SR 5 hitting 290K miles right now. In addition to the above routine wear related parts replacement list, I had to replace the air valve on the driver’s side. Also the wires into the plugs of the harness there on the air valves are crimped in poorly and I’ve had to repair those. Otherwise, just routine maintenance and no major repairs.
2000se is offline   Reply With QuoteReply With Quote
Old 04-30-2022, 03:54 PM #29
Nope my 2016 Limited had to have all new suspension because it was the X-Res.
2 of the front shocks started leaking so the whole systems had to be replaced. 140K miles.
Old 04-30-2022, 05:20 PM #30
ArthurKotb's Avatar
Real Name: Rich
ArthurKotb's Avatar
Real Name: Rich
You do off-roading? Just curious. I have the X-REAS shocks on my 2004 at 131,000 and no leaks. My 4Runner handles great with a 23' travel trailer or the 17' bass boat. I really like the X-REAS.
Rich
Kentucky
guys , lots , miles , plenty , years
10 years = 123456 miles Net4n6 General Discussions 0 01-15-2016 12:25 PM
19 years and 364,000 miles... StreetCreeper 3rd gen T4Rs 5 01-29-2015 01:14 AM
14 years old and 90K miles what do I need to do? Former_Jeeper 3rd gen T4Rs 8 12-21-2013 07:53 PM
10 years old, 126k miles and its very 1st problem scoobydann 3rd gen T4Rs 1 08-22-2012 11:55 PM
27 years, 311,000 miles later.....85 T4R 93toy Gallery 4 05-18-2012 03:30 PM
