Old 04-13-2022, 03:44 PM #16
BigBlueSince82's Avatar
BigBlueSince82 BigBlueSince82 is offline
BigBlueSince82 is on a distinguished road
You are probably right but I didn’t buy a 4Runner to start to have doubts at 90k miles. Really pisses me off. I I’ll be doing a compression test by this weekend to rule out other possibilities.
BigBlueSince82 is offline   Reply With QuoteReply With Quote
Old 04-13-2022, 03:46 PM #17
Originally Posted by 03_4x4Runner View Post
What oil and filter are you using?
Quaker state full synthetic with trd oil filter.
Old 04-13-2022, 10:58 PM #18
BlackWorksInc's Avatar
BlackWorksInc BlackWorksInc is offline
BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold
@BigBlueSince82
I had the spark plug out of this 2003 Highlander with a 3.0L 1MZ-FE engine earlier today, so I snapped a quick picture with my scope (I also see that I need to fix the date and time on it...) It has over 230k on it and mechanically runs very well with no significant oil consumption or mechanical issues (though this poor thing needed a lot of maintenance from being neglected); here's what the inside of the cylinder looks like.
It's not exactly an apples to apples comparison given the 1MZ-FE is a cast iron block, but it uses roughly the same hardening process as the cast iron sleeves in your 1GR-FE block IIRC, so close enough.
Note- I didn't bother rotating the picture, so up is down, down is up.
Cylinder wall scoring-img_0003-jpg
BlackWorksInc is offline   Reply With QuoteReply With Quote
Old 04-13-2022, 11:34 PM #19
octanejunkie's Avatar
octanejunkie octanejunkie is offline
Real Name: C8H18 Mike
octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of
Originally Posted by BlackWorksInc View Post
@BigBlueSince82
Par for the course with a waste spark ignition system, aka nothing to be concerned about. The sooty buildup on the piston face will increase compression over time lol
Cross hatching on the cylinder walls is normal, from the factory to promote ring seal and proper break in, and over time as the rings rotate in the piston grooves.
If your cylinder walls are not chrome lined (ours are not) and they are smooth as silk, then be worried.
Sent from my Pixel 4 XL using Tapatalk
1999 Toyota 4Runner SR5 Un-Sported 2WD, V6 Auto ->2WD 4runner Journal Thread
octanejunkie is offline   Reply With QuoteReply With Quote
Old 04-14-2022, 02:00 AM #20
@BigBlueSince82
Thank you, i appreciate the effort. I hope others can share photos for comparison. I’m starting to really lean towards the valve seats leaking. Either way after 90k plus miles I don’t believe there shouldn’t be vertical score lines like this in an engine that doesn’t have future problems on its way.
Old 04-14-2022, 12:20 PM #21
Charles Bronson Charles Bronson is offline
Charles Bronson has a spectacular aura about Charles Bronson has a spectacular aura about
I'd file this under "Don't worry now, but let's keep an eye on this for a bit".
You can do a Google search and see that this isn't wildly uncommon and in many cases, isn't an issue.
Let's look at the facts with your motor and these motors in general:
1) You 4Runner isn't, and apparently hasn't, exhibited any driveability issues, misfires, oil consumption, smoking, spark plugs look fine, etc.
2) The 1GR-FE dual VVT-i engine is quite reliable. The most common major issue is a failed head gasket, but that isn't very common to the dual VVT-i motor that's found in the 5th gen 4Runner.
A year after I purchased my 2016 BMW M235, it started making a faint noise that sounded just like low rpm rod knock. The short block in the M235 is ~$12K alone. After some research and inspection, it turns out that a combination of the dual mass flywheel and self-adjusting clutch can be quite noisy as they get a little age. I figured out that I could make the sound go away by simply pushing in the clutch pedal. The car has made that sound for the last 5.5 years and 50K miles. Used oil analysis has been perfect. Point being, don't worry until there is really something to worry about.
Charles Bronson is offline   Reply With QuoteReply With Quote
Old 04-14-2022, 08:34 PM #22
So I'm tearing down a '19 4runner with about 31k on it to swap out the short block due to an oil galley leak. I got it all torn down ready to swap out and snapped a few pictures for you.
This engine has the same marks and "shadows" along the cylinder walls. You can't feel them with a fingernail or fine tipped pick they look more like burnish marks you'd see when someone superficially scuffs a polished stainless steel plate. My best guess is that they're burnish marks from when the engine originally "seated in/wore in" from minor variances in the roundness of the pistons, rings, and cylinder that are totally within acceptable factory tolerances.
Cylinder wall scoring-20220414_161616-jpg  Cylinder wall scoring-20220414_161644-jpg  Cylinder wall scoring-20220414_161715-jpg
Old 04-14-2022, 10:12 PM #23
You are the best!!!! Thank you very much! I’m sure this topic has peaked some interest on here. I just hope you are 100% right. Keep the pictures coming, I’m interested to see how common this is.
Old 04-15-2022, 08:03 PM #24
catrains catrains is offline
catrains will become famous soon enough catrains will become famous soon enough
you did the oil changes great and then you looked in to the cylinder well,,,,, I was repairing engines and the bores use a tool to buff it ..your picture works great ...
so you did not loose engine oil ...your engine is very good around 100K miles ..
catrains is offline   Reply With QuoteReply With Quote
Old 04-16-2022, 05:18 PM #25
lewdog998's Avatar
lewdog998 lewdog998 is offline
lewdog998 is a splendid one to behold lewdog998 is a splendid one to behold lewdog998 is a splendid one to behold lewdog998 is a splendid one to behold lewdog998 is a splendid one to behold lewdog998 is a splendid one to behold
lewdog998's Avatar
I checked my 20 with 48k miles....what I found was quite shocking....I did some research and figure as long as I don't feed it after midnight or install a water injection system on the truck, I should be ok.
Cylinder wall scoring-20220416_161530-jpg
2020 TRD Pro in Super White
RCI full alum skids - C4 Fab sliders-Diff breather mod-Upper grill hidden light bar- Auxbeam switch panel- DD reverse / turn light LED mod - Front Runner 3/4 Rack - 285/70 Dura tracs - Maxi Trac onboard air - Eibach TRD Pro lift springs - Front Runner 3/4 rack - Hefty Fabworks Lo-pro bumper - Warn VR Evo 12S. Dirt King UCAs
Man is born free, yet he is everywhere in chains....
lewdog998 is offline   Reply With QuoteReply With Quote
Old 04-16-2022, 06:09 PM #26
Hahaha, mine was definitely fed after 12! Did you notice any oil in your intake manifold? I have way more then I would like. Definitely need a catch can installed soon.
Old 04-16-2022, 07:55 PM #27
How much are you filling the engine and how are you checking the oil level afterwards? A little too much can result in some excess getting sucked into the intake via the PCV system.
Old 04-16-2022, 09:14 PM #28
Fill with 6.5 quarts. Check on level ground. I know the book says 6.6 but I figure there has to be some oil remaining, if not .1 quarts would not make a difference.
Old 04-19-2022, 10:50 AM #29
Hammer0313's Avatar
Hammer0313 Hammer0313 is offline
Real Name: Buck
Hammer0313 has a spectacular aura about Hammer0313 has a spectacular aura about
Hammer0313's Avatar
Real Name: Buck
Subscribed!
2019 TRD - Engine 0/5/10w30 - Diffs Redline GL-5 - BFG K02 - TC Redline GL-4 - Trans WS
Hammer0313 is offline   Reply With QuoteReply With Quote
Old 04-19-2022, 11:58 AM #30
baldrik78's Avatar
baldrik78 baldrik78 is offline
baldrik78 is a glorious beacon of light baldrik78 is a glorious beacon of light baldrik78 is a glorious beacon of light baldrik78 is a glorious beacon of light baldrik78 is a glorious beacon of light baldrik78 is a glorious beacon of light
baldrik78's Avatar
Clearly the answer to is to pull the motor, pull the heads, drop the bottom end and give it a good ol' dingleberry honing.
2017 TRD ORP KDSS IG
Dobinsons IMS w/ 314/325 Coils - JBA UCAs - Durobumps - Firestone 4108
DRKDSS Disconnect Switch - Treaty Oak KDSS Spacers - Eimkeith PCK
SSO Roof Rack - SSO Sliders - SSO Slimline - Smittybilt X20 10k - RCI Skids
TRD Pro Wheels - Spidertrax Spacers - Mickey Thompson Baja Boss A/T 255/85 R17
baldrik78 is offline   Reply With QuoteReply With Quote
engine , miles , oil , plugs , spark
scored cylinder wall 91 3.0 4runner blazinjames Classic T4Rs 5 05-16-2014 07:34 PM
Slave cylinder or master cylinder? That is the question. ieatelk Classic T4Rs 8 07-14-2012 04:54 PM
Master Cylinder, Slave Cylinder Issue bomhour Classic T4Rs 6 01-10-2010 09:14 PM
Against the wall: Should I take this offer? iLLWiLL 4th Gen T4Rs 27 07-17-2007 05:39 PM
New Year's Ice Wall jpalaska 4th Gen T4Rs 12 01-05-2007 03:26 PM
