Old 04-20-2022, 07:34 PM #31
BigBlueSince82's Avatar
BigBlueSince82 BigBlueSince82 is offline
BigBlueSince82 is on a distinguished road
I was finally able to perform a compression test today and I believe the results couldn’t have been better. Hope I’m not corrected (fingers crossed). I used a digital tester and the results are as follows:
Left Bank:
186.5
188.5
186.5
Right bank:
192
196
186.5
Has anyone else performed a compression test recently? I’m not to sure what the compression pressure should be for the newer version of the 1gr VVT-i but I found that the older version standard and minimum pressure was 193psi and 148psi.
BigBlueSince82 is offline   Reply With QuoteReply With Quote
Old 04-20-2022, 08:14 PM #32
2021nightshade4x4 2021nightshade4x4 is offline
2021nightshade4x4 is just really nice 2021nightshade4x4 is just really nice 2021nightshade4x4 is just really nice 2021nightshade4x4 is just really nice 2021nightshade4x4 is just really nice
Left Bank:
186.5
188.5
186.5
Right bank:
192
196
186.5
That’s a really narrow range. Makes my OCD happy.
2021nightshade4x4 is offline   Reply With QuoteReply With Quote
Old 04-21-2022, 12:16 AM #33
BlackWorksInc's Avatar
BlackWorksInc BlackWorksInc is offline
BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold
From the FSM:
3. INSPECT COMPRESSION
(a) Warm up and stop the engine.
(b) Remove the intake air surge tank
(c) Remove the 6 spark plugs
(d) Disconnect the 6 fuel injector connectors.
(e) Inspect the cylinder compression pressure.
(1) Insert a compression gauge into the spark plug hole. (Procedure A)
(2) While cranking the engine, measure the compression pressure. (Procedure B)
Standard pressure:
1400 kPa (14.3 kgf/cm2, 203 psi) or higher
Minimum pressure:
1100 kPa (11.2 kgf/cm2, 160 psi)
Difference between each cylinder:
100 kPa (1.0 kgf/cm2, 15 psi) or less
HINT:
Use a fully-charged battery so that the engine speed can be increased to 250 rpm or more.
Measure the compression in as short a time as possible.
(3) Repeat procedures A and B for each cylinder.
(4) If the cylinder compression is low, pour a small amount of engine oil into the cylinder through the spark plug hole and repeat procedures A and B for cylinders with low compression.
If adding oil increases the compression, the piston rings and/or cylinder bore may be worn or damaged.
If pressure stays low, a valve may be stuck or seated improperly, or there may be leakage from the gasket.
(f) Connect the 6 injector connectors.
(g) Install the 6 spark plugs
(h) Install the intake air surge tank
Note- I would make sure you're going wide-open throttle when you are doing your compression test, a lot of people forget that and it skews the readings.
Based on your results I'd say that's a healthy engine, I know a lot of people will point out that it's not near the "standard pressure" but it is worn in and I'm going to guess that the engine wasn't warmed up when you did the test. At the end of the day, what matters more is that the compression is decently above the minimum specification and more importantly that the variance between the cylinders is within specification.
BlackWorksInc is offline   Reply With QuoteReply With Quote
Old 04-21-2022, 06:33 AM #34
Originally Posted by BlackWorksInc View Post
From the FSM:
I think so too. But now that you posted that I have one concern. I removed the air intake tube but I did not have the throttle body positioned open. The engine was warmed up and brought up to temp before the test. I removed the fuses for ignition and fuel, obviously all the spark plugs. Are you implying that the throttle body should be propped open? Getting the feeling I need to do this again.
Old 04-21-2022, 07:47 AM #35
RAVL 2016 RAVL 2016 is offline
RAVL 2016 is on a distinguished road
Those numbers look excellent but you should also do (or have done) a leak down test while you are at it. If that comes back good then you have nothing to worry about.
And as far as test procedure, if you want to get the concern behind you, maybe have all this stuff done by a Toyota shop. Then you know for certain. Peace of mind is worth something.
Again good luck!
RAVL 2016 is offline   Reply With QuoteReply With Quote
Old 04-21-2022, 03:14 PM #36
Alright so I performed another compression test and the results were higher then the first test. I believe the main factor for this was that I cranked the key 7-8 times per cylinder instead of the 5 I did previously. I also made sure to have the throttle body open as I performed the test. The extra 2-3 cranks definitely pushed the psi further before it topped out as I was getting similar readings as the first test with only 5 cranks. Definitely a dumb mistake. Not sure why I had 5 cranks stuck in my head. Might have been something i watched.
Left bank:
203
203
200
Right bank:
207
205
200
Old 04-21-2022, 03:38 PM #37
Bmnorm2 Bmnorm2 is offline
Bmnorm2 is a jewel in the rough Bmnorm2 is a jewel in the rough Bmnorm2 is a jewel in the rough Bmnorm2 is a jewel in the rough
Great results. You definitely don't have a compression issue. I'm more interested in leak down.
Bmnorm2 is offline   Reply With QuoteReply With Quote
Old 04-21-2022, 06:44 PM #38
catrains catrains is offline
catrains will become famous soon enough catrains will become famous soon enough
Left bank:
203
203
200
Right bank:
207
205
200
again your engine is working great /............
catrains is offline   Reply With QuoteReply With Quote
Old 04-21-2022, 10:45 PM #39
Left bank:
203
203
200
Right bank:
207
205
200
Gorgeous numbers! pumping air like a champ!
Yeah you always want to hold the throttle open (just mash the pedal down when you're doing the test) so that the engine can breathe at full capacity, if you have it closed you're essentially at idle (think difference between trying to breathe through a straw and just taking a breathe normally.)
Old 04-23-2022, 09:21 PM #40
Thank you for all the help and insight. I decided to change the oil early at 3k miles like my last oil change due to winter and higher idle times. Sending a sample to blackstone for some peace of mind. I also installed an oil catch can to see if that helps with the oil in the intake. Early signs show it will.
I have a theory to the scoring on the piston walls. I have a 2nd car that I have been using for work rather then my 4Runner, even though I would still end of taking it to work 50 percent of the time until the gas prices went Sky high. Then I was parking the 4Runner from Monday - Friday and only using on the weekends the last few months. Giving more time to allow the oil in the intake to drip all the way down and soak what ever carbon there was in the combustion chamber. This might have allowed the carbon to loosen up and tumble down onto the cylinder walls. It’s my best guess to all this.
But just to really raise some eyebrows. I have decided to increase the oil weight to 5w-30 by Quaker state. I know this has been discussed on forum before but I decided to give it a try thanks to the 540rat. I will send a sample of this to blackstone as well for comparison. Changing the oil to 5w-30 has decreased the typical 1gr chatter/clatter that they all have. Looking forward to the next oil analysis.
Old 04-23-2022, 10:41 PM #41
Old 04-24-2022, 07:40 AM #42
Hammer0313's Avatar
Hammer0313 Hammer0313 is offline
Real Name: Buck
Hammer0313 has a spectacular aura about Hammer0313 has a spectacular aura about
Hammer0313's Avatar
Real Name: Buck
Looks like your 4R is pumping air like a champ, happy to see that. And you bumped up to a 30 weight oil that I know you'll enjoy; I've been running a 30 weight for the last 50k and the 4R sounds and feels really good.
2019 TRD - Engine 0/5/10w30 - Diffs Redline GL-5 - BFG K02 - TC Redline GL-4 - Trans WS
Hammer0313 is offline   Reply With QuoteReply With Quote
Old 04-24-2022, 12:03 PM #43
Yes I agree. I’m not one to “feel” an oil change or a cold air intake, but I definitely notice a difference with how the engine sounds/operates with the heavier weight oil.
Old 05-05-2022, 08:29 PM #44
I just received my oil analysis back from blackstone labs and it appears that I don’t have anything to worry about. See report below.
Cylinder wall scoring-cbe3ce9a-4ab8-43c1-bd09-7f15e3fe268b-jpg
Old 05-05-2022, 08:50 PM #45
octanejunkie's Avatar
octanejunkie octanejunkie is offline
Real Name: C8H18 Mike
octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of
Originally Posted by octanejunkie View Post
Did you do a compression/leak down test?
This looks like nothing to worry about until you do.
Sent from my Pixel 4 XL using Tapatalk
Told you lol
1999 Toyota 4Runner SR5 Un-Sported 2WD, V6 Auto ->2WD 4runner Journal Thread
octanejunkie is offline   Reply With QuoteReply With Quote
engine , miles , oil , plugs , spark
scored cylinder wall 91 3.0 4runner blazinjames Classic T4Rs 5 05-16-2014 07:34 PM
Slave cylinder or master cylinder? That is the question. ieatelk Classic T4Rs 8 07-14-2012 04:54 PM
Master Cylinder, Slave Cylinder Issue bomhour Classic T4Rs 6 01-10-2010 09:14 PM
Against the wall: Should I take this offer? iLLWiLL 4th Gen T4Rs 27 07-17-2007 05:39 PM
New Year's Ice Wall jpalaska 4th Gen T4Rs 12 01-05-2007 03:26 PM
