Old 04-13-2022, 09:28 AM #16
scanny's Avatar
scanny scanny is offline
scanny will become famous soon enough
scanny's Avatar
So basically if you turn off key fob and put a lock on OBD port then thieves have no way to steal 4Runner? Or there might be some other ways?
2022 4Runner TRD Off Road, Lunar Rock
Goodyear Wrangler Duratracs
scanny is offline   Reply With QuoteReply With Quote
Old 04-13-2022, 09:29 AM #17
Humble Leader's Avatar
how were you able to track the vehicle once it was stolen? did you have your own apple air tag in it as well?
hope everything gets fixed up. I've been using a faraday box but really I don't think anyone is coming after my 2012 lol.
Old 04-13-2022, 09:36 AM #18
Something_Awesome's Avatar
Something_Awesome Something_Awesome is offline
Something_Awesome will become famous soon enough
Originally Posted by Salvo Jimmy View Post
My 2022 fob has a battery saver feature. It turns off the fob, thus it can work as anti theft.
You hold down the lock button and press the unlock button twice. The red light flashes twice 2 times then you release the lock button. Fob is then off.
For example you cannot open doors by putting your hand in the handle. You have to turn the fob back on by pressing the unlock button.
I do this every time I leave the vehicle.
Thank you for this. I will use this. I think my wife's Lexus CT does not have this feature. So I may need the box I just bought anyway. But even absent the threat of theft, it's nice to save the battery. I never unlock cars using the handle anyway.
Something_Awesome is offline   Reply With QuoteReply With Quote
Old 04-13-2022, 09:45 AM #19
bill444 bill444 is offline
bill444 is on a distinguished road
I think with Toyota you have to turn the fob broadcasting off after every time you use it. If you remove the battery, then you can't open the doors with the lock/unlock button. It's kind of a shame you can't disable the proximity feature but leave the lock/unlock function working.
Some people are putting their keys in what is advertised as a faraday box or pouch. Some of these work and some do not.
There's a few problems with some of the cheaper mass produced units. Some aren't built that well and leak RF. Others may not prevent the leakage of RF for the specific frequencies used by the key.
The trick is to test it in close proximity to the car for the door unlock function and inside the car for push to start. Some negative reviews of boxes report that it does not block bluetooth or wifi although the key is not using those frequencies in the first place.
One problem with the RF blocking box is you're not likely to use it when you and the car is not home.
I am going to see how much of this can be disabled in the 4Runner itself so that the key won't matter.
Edit: disabling the Smart Key system is listed as a feature only the dealer can disable in my owner's manual. I am going to see what scan tools can do that.
bill444 is offline   Reply With QuoteReply With Quote
Old 04-13-2022, 10:22 AM #20
Johnnyg182 Johnnyg182 is offline
Johnnyg182 will become famous soon enough
Now I’m kinda glad my 2019 Pro still uses an old school key. Unless they break into my house for the key…..
Johnnyg182 is offline   Reply With QuoteReply With Quote
Old 04-13-2022, 10:27 AM #21
Brandonium's Avatar
Brandonium Brandonium is offline
Real Name: Brandon
Brandonium will become famous soon enough
Brandonium's Avatar
Real Name: Brandon
Likewise. I like using an old school key in my 2016 TEP. That push button crap is just lazy sauce.
2016 Toyota 4Runner TEP + KDSS + RC
1971 Volvo 142e (Lovely brick with a tractor engine)
1977 International Scout II (Another brick tractor)
Brandonium is offline   Reply With QuoteReply With Quote
Old 04-13-2022, 10:45 AM #22
scanny's Avatar
scanny's Avatar
Normally I disable keyfob by holding lock button and pressing unlock 2 times. Keyfob stop broadcasting and I can't unlock by just pulling door handle. But keyfob will be activated and will start broadcasting again if you press any button. I tried to remove battery from second spare keybob and see if I can live without battery and don't worry about forgetting to deactivate key or push a button and activate it by mistake.
So I found out that if you unlock door with mechanical key alarm start going on and it's pretty loud. The only way to disable it is to push engine start button keeping keyfob close to that button. It works, but it's a hassle to have keyfob without battery. I wondering if disabling smart key system disables key broadcasting or truck listening?
Old 04-13-2022, 10:53 AM #23
Wow, good to know.
I disabled the Smart Key system on different 2016 Lexus and it prevented the car from listening. On that car, I could disable it from the Nav system's settings menu. I could open the doors with the fob button and had to hold the key near the start button before it would start. Essentially I had to follow the "dead battery" process to start the car.
Old 04-13-2022, 11:39 AM #24
CutthroatSlam CutthroatSlam is offline
CutthroatSlam is a splendid one to behold CutthroatSlam is a splendid one to behold CutthroatSlam is a splendid one to behold CutthroatSlam is a splendid one to behold CutthroatSlam is a splendid one to behold CutthroatSlam is a splendid one to behold CutthroatSlam is a splendid one to behold CutthroatSlam is a splendid one to behold
I had the push to start break on a rental car and they had to deliver a new car to me and pick up the old one. That was back in 2011. Never again. Hate them things.
CutthroatSlam is offline   Reply With QuoteReply With Quote
Old 04-13-2022, 12:04 PM #25
What could have been....
My 2020 TRD Pro 4runner stolen by organized crime for resale in Africa-stolen-trd-pro-jpg
Old 04-13-2022, 12:28 PM #26
gptoy09 gptoy09 is offline
gptoy09 is on a distinguished road
That's a crazy story. Glad you got your truck back relatively in one piece. Hope insurance helps with getting it back just like new.
96 T4R-Sold
04 T4R Sport V8-"Sold" (Divorce Loss)
09 Tacoma DCLB Sport-Current
22 T4R TRDOR-In Transit
gptoy09 is offline   Reply With QuoteReply With Quote
Old 04-13-2022, 12:46 PM #27
scanny's Avatar
scanny's Avatar
Wow, good to know.
Just checked manual - Smart Key system can be turned off but it said that it can be changed only by Toyota dealer. I guess that if it turned off, the rear window can't be operated from outside at all? I wish Toyota kept a regular key I had in my 2010 T4R...
Old 04-13-2022, 12:48 PM #28
Mr_Bingley Mr_Bingley is offline
Mr_Bingley will become famous soon enough
Just tried this with my 2021 ORP and it works! Thanks for this
Mr_Bingley is offline   Reply With QuoteReply With Quote
Old 04-13-2022, 02:13 PM #29
lewdog998's Avatar
lewdog998 lewdog998 is offline
lewdog998 is a splendid one to behold lewdog998 is a splendid one to behold lewdog998 is a splendid one to behold lewdog998 is a splendid one to behold lewdog998 is a splendid one to behold lewdog998 is a splendid one to behold
lewdog998's Avatar
WORKS on my 2020 Pro too!
2020 TRD Pro in Super White
RCI full alum skids - C4 Fab sliders-Diff breather mod-Upper grill hidden light bar- Auxbeam switch panel- DD reverse / turn light LED mod - Front Runner 3/4 Rack - 285/70 Dura tracs - Maxi Trac onboard air - Eibach TRD Pro lift springs - Front Runner 3/4 rack - Hefty Fabworks Lo-pro bumper - Warn VR Evo 12S. Dirt King UCAs
Man is born free, yet he is everywhere in chains....
lewdog998 is offline   Reply With QuoteReply With Quote
Old 04-13-2022, 04:23 PM #30
lets_go_4running lets_go_4running is offline
lets_go_4running is on a distinguished road
OP here. Thanks for all your comments. As soon as I get back to the car I'm going to post pictures of the antenna sabotage they did, as it is quite a piece of work.
I noticed the mayday "phone home" button functionality (what some call DCM) seems disabled. What is usually the little green light is now red. I know some folks were previously looking for ways to disable this, and it seems the thieves have found a way without pulling the DCM fuse (which also kills the sound system). Besides chopping the antenna, perhaps they also did something programming via the ODB port as well?
Interestingly, the built-in GPS maps navigation still seems to work, at least when driving out in the open.
Some folks asked how I found the car. I didn't, it was the police. Perhaps they were onto these guys somehow...
For disabling smart keys, faraday cage is the easiest. The hold-lock-two-button-unlock is great, but forget once, regret forever.
lets_go_4running is offline   Reply With QuoteReply With Quote
car , keys , police , stolen , thieves
4runner resale price is incredible Net4n6 Off Topic 2 06-06-2014 06:55 PM
2010 FJ and 4Runner rank 1st & 2nd for resale value!! 4RunnERD General Discussions 3 01-07-2012 03:21 AM
Used 4Runner resale values jreask 3rd gen T4Rs 20 08-17-2010 11:59 PM
Advice Needed - 4Runner to East Africa eadrivers 5th gen T4Rs 35 04-27-2010 11:58 AM
4Runner resale value? lockerc18 General Discussions 99 06-22-2008 10:09 PM
