04-13-2022, 07:36 PM
MT 255/85r17 Tires
Hi team,
Anyone here running Mickey Thompson’s new 255/85r17 Baja Boss?
These are tall skinny (35x10) tires and seem to be a good alternative to traditional 34/35s as they’d have less weight, rolling resistance, and rubbing. A few FJ people have tried them and raved about them on FJ forum.
Thoughts / experience welcome.
Thanks.
04-13-2022, 08:29 PM
No never had those tires but I have 3 255/80R17 Nitto Ridge Grapplers ready to go on my 4Runner. Still waiting on the last one to be delivered. Looks like hopefully tomorrow.
I am figuring the lower weight and narrower tire might help out with miles per gallon issues
04-13-2022, 09:29 PM
Yes, MPG is definitely something to consider too. I get 15-16mpg on a good day with 33s. There are guys who run 40s on a ram power wagon, which weights 2,000 lbs more and has a 6 liter v8, and they get the same mileage.
04-13-2022, 09:42 PM
These are an interesting option. At 64# though they aren't especially light. And honestly most sizes are almost prohibitively heavy compared to a similar sized tire. I wonder how a tire that heavy rides? Other big downside to this size is the widest approved rim size is 8"
Edit: It'd be interesting to see some real world weight numbers
04-13-2022, 09:54 PM
They also have better gearing and 8 or 10 speed transmissions so that V8 is barely idling most of the time.
'20 Army Green 4Runner TRD PRO
'16 Quicksand Tundra TRD PRO Gone
'08 Salsa Red Pearl 4x4Runner SE V6: Gone
04-14-2022, 01:38 AM
That’s part of the appeal. I like stock wheels and they are 7 inches wide. While I can mount 315s on it, not many shops will take that job. 64 pounds is exactly what KO2s weigh in 315’s. Another benefit is that 255s won’t rub on the UCA, so you don’t need spacers or special offset to clear them.
Here’s a gentleman who installed the 255s Baja Boss on his FJ and when he weighted them he said they were 43lbs, but likely just misspoke: https://www.youtube.com/watch?v=keTaWTVdPFA&feature=youtu.be
04-14-2022, 01:44 AM
your money, do as you please. As for me, that would be a hard pass.
05-26-2023, 01:01 PM
Hi team,
Thanks.
Resurrecting this thread - wondering if OP went with the 255/85/17 tires, and what mods if any were done to the 5th gen 4R for fit.
I'm considering this for 2021 4R TRD ORP. I've always preferred narrower tall tires for the type of off-roading I do.
Thanks!
05-26-2023, 01:41 PM
I have these tires. I think they are pretty great. Good wet traction, good off road, decent in the snow. I did still end up doing a lot of trimming to make them fit. Biggest downside is the truck is basically just a 4 speed now. Overdrive actually makes my mileage worse. I need to regear, hopefully this year. I'm averaging 14 mpg, riding around in 4S all the time.
2017 TRD ORP KDSS IG
Dobinsons IMS w/ 314/325 Coils - JBA UCAs - Durobumps - Firestone 4108
DRKDSS Disconnect Switch - Treaty Oak KDSS Spacers - Eimkeith PCK
SSO Roof Rack - SSO Sliders - SSO Slimline - Smittybilt X20 10k - RCI Skids
TRD Pro Wheels - Spidertrax Spacers - Mickey Thompson Baja Boss A/T 255/85 R17
05-27-2023, 11:09 AM
This is good to know! I am planning on going with this size. I am hoping a tune will hold off the regear for awhile. Do you think it would help? I currently have 255/80 Wildpeaks and highway driving isn't too much of a chore.
2016 T4R SR5: Ironman FCP w/ Performance Springs l RAV4 Mirrors l TSO Pro Grill l TSO INCOG Front Bumper l Raptor Lights l 255/80 Falken WildPeak AT3W l CaliRaisedLED Ditch Light Brackets l Avid Sliders l Custom Drawers l R1 Concepts Rotors/Pads
5th Gen Build
1996 T4R Limited: E-Locked l 285 KO2's l Toytec BOSS w Superflex l SS Panhard l Ultra Gauge l AIRAID MIT l Drifter CB Mount l AOF Sliders l Weathertech's l Hilux 167 Snorke l Cobra 19DXIV l Ditch Lights l Relentless Front Bumper l Superwinch Tiger Shark l Paranoid Fab Din Switch
05-30-2023, 11:43 AM
Thanks for the update! I figured a regear would be needed. Was wondering if the body mount chop was still needed with this tire size.
Thanks again for the help!
06-01-2023, 01:44 PM
Depend son off-set. I have TRD wheels with spidertrax spacers. total offset is about -28mm. I needed an aggressive BMC and I needed to trim an inch off the front fender arch. I still rub on the tub when she really flexes. If you are closer to a 0 or -10mm off-set, you might have an easier time.
Thread Tools |
Display Modes |
Rate This Thread |
Linear Mode
