Old 04-18-2022, 09:24 PM #1
jmmec jmmec is offline
jmmec is on a distinguished road
Engine Rat/Mouse - Chewed Tubing + Cylinder 3 Misfire + Rough Idle
Ah, not good...
I have a 2016 4Runner TRD PRO and when I started it today I immediately noticed a rough idle followed by the dashboard showing:
  • Check Engine light flashing
  • TRAC OFF light flashing
  • Multi-Terrain Select light flashing
ODB shows codes:
  • P0303 Cylinder 3 Misfire
  • P1605 Rough Idle
When I opened the hood there was a little sign of grassy material, nothing at all like a nest, but I'm pretty sure a rat / mouse did some damage. See the attached pics where there is some chewed tubing.
What is this chewed tubing for? Can I temporarily duct tape it back together?
I'm not a mechanic so have an appointment at a shop on Wednesday. But anything else I can troubleshoot before then? I'll take a closer look at the engine bay tomorrow to see if there is any other evidence of damage.
Thank you for any advice....
Pictures:
Engine Rat/Mouse - Chewed Tubing + Cylinder 3 Misfire + Rough Idle-dashboard-resize-jpg  Engine Rat/Mouse - Chewed Tubing + Cylinder 3 Misfire + Rough Idle-chewed-resize-jpg  Engine Rat/Mouse - Chewed Tubing + Cylinder 3 Misfire + Rough Idle-chewed-closeup-resize-jpg
jmmec is offline   Reply With QuoteReply With Quote
Old 04-18-2022, 09:45 PM #2
214RUNNER's Avatar
214RUNNER 214RUNNER is offline
Location: THE ARM PIT OF AMERICA NY STATE THE ROTTEN APPLE
214RUNNER is on a distinguished road
214RUNNER's Avatar
Looks like the vacuum hose to the fuel pressure regulator. Take the old hose off & replace it clear the codes. if you don’t have a way to clear codes auto zone can do it and you can get the hose there also
214RUNNER is offline   Reply With QuoteReply With Quote
Old 04-19-2022, 09:56 AM #3
Thank you!
Hoping this is the only fix that is needed.
I didn't find the broken tubing until after I drove it about 8 miles -- it drove fine, just sluggish. Anyone know if it is damaging to drive it another 5 miles to AutoZone to get some new tubing?
Would taping it together before driving there help at all? I guess that line is normally pressurized? No fuel at all is coming out of it.
Old 04-19-2022, 11:27 AM #4
Charles Bronson Charles Bronson is offline
Charles Bronson has a spectacular aura about Charles Bronson has a spectacular aura about
Do you not have a friend or coworker that can take you?
Taping it together should work assuming you're using decently strong tape. There isn't a ton of vacuum. Tape it together and see how it runs. If it runs smoothly, then go to the auto parts store.
I'd cut a small piece of the line so that when you go to the auto store, they can get you the correct inner diameter line. Make sure to measure the full length of line you need.
Don't worry, this isn't rocket science. You're truck in running like crap and throwing codes because it has a major vacuum leak and the fuel pressure regulator isn't getting the vacuum it needs to work correctly. I wouldn't drive until it's temporarily fixed with tape or a new line.
Charles Bronson is offline   Reply With QuoteReply With Quote
Old 04-19-2022, 02:07 PM #5
I took another look under the hood and the wires that connect to (the coil pack on?) cylinder 3 are chewed off. I don't see other damage besides the chewed vacuum line.
Ya, I'll get a ride over to AutoZone to get some supplies to replace or at least patch the vacuum line. I'm taking it to a shop tomorrow in case there are additional problems.
Thanks everyone....
Old 04-19-2022, 10:58 PM #6
BlackWorksInc's Avatar
BlackWorksInc BlackWorksInc is offline
BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold
We keep a roll or two of Rodent Tape for these types of repairs. I'll repair a harness and then wrap it in this stuff. I think we order it from Honda?
I don't know how well it works, but I can't say that I have really seen many come-backs for rodents chewing through that stuff that I can recall?
Part # 4019-2317
Be thankful they didn't chew up the knock sensor harness, that's an annoying pain in the ass to replace without pulling a cylinder head off.
BlackWorksInc is offline   Reply With QuoteReply With Quote
Old 08-29-2023, 08:40 AM #7
Teflonpresident Teflonpresident is offline
Teflonpresident is on a distinguished road
I'm getting these same codes...
2015 toyota 4Runner limited.
Can anyone give me a list of things to troubleshoot on these codes? Ihave checked for chewed wires because we have a tree rat (squirrel) thats has a history of chewing wires.
Teflonpresident is offline   Reply With QuoteReply With Quote
Old 08-29-2023, 09:08 AM #8
Found it! I got Tree Ratted.... The connector over cylinder 3 was bitten thru and wire harness was sitting in place so it looked good until i touched it.
Old 08-29-2023, 09:47 PM #9
like2lean's Avatar
like2lean like2lean is offline
like2lean is on a distinguished road
like2lean's Avatar
It'll keep happening till you take action...lever action, pump action, semi auto, pick your poison...which works well too.They're all cute and funny till they get into your house or car and cost you thousands of dollars. I've made "a lot" of money over the years from rodent damage, it's no joke.
like2lean is offline   Reply With QuoteReply With Quote
Old 08-30-2023, 01:29 AM #10
TK-422's Avatar
TK-422 TK-422 is offline
Real Name: Chris
TK-422 will become famous soon enough TK-422 will become famous soon enough
TK-422's Avatar
Real Name: Chris
Get yourself a pair of these to prevent future damage.
Under Hood Rodent Repeller Battery Operated
You can also spray mint oil in the engine compartment once a month to keep them away.
My wife's RAV4 had $700 damage to the harness from rodents.
<a href=http://www.tophersworld.com/imagesb/tk422_signature.jpg target=_blank>http://www.tophersworld.com/imagesb/tk422_signature.jpg</a>
"I hope yours took a bath once in a while, kid. This guy's armor smells like he lived in it."
―Han Solo to Luke Skywalker, while donning TK-422's armor.
TK-422 is offline   Reply With QuoteReply With Quote
Old 08-30-2023, 12:51 PM #11
Whippersnapper02's Avatar
Remove the engine cover and start using something like Grandpa Gus peppermint spray.
Old 08-30-2023, 05:34 PM #12
like2lean's Avatar
like2lean's Avatar
Mint spray, mothballs, and cats all work well. I've seen the wires chewed right off the electric underhood ones. Mice are bad, but around here squirrels do the worst damage. They're just mean like vandals, just tear sh#t up for no reason.
Old 02-22-2024, 04:49 AM #13
Krampuss's Avatar
Krampuss Krampuss is offline
Krampuss is on a distinguished road
Krampuss's Avatar
Oh no, that sounds like a tricky situation! The chewed tubing might be part of the engine's vacuum system. While duct tape could be a temporary fix, it's best to let the pros handle it. Check for other signs of damage, and take pictures for reference. Good call on the mechanic appointment – they'll have you back on the road in no time. By the way, do you guys know how I can remove a hornet nest from my backyard? My friends advised me to ask hornet control for help. Anyway, good luck with the repairs. Hang in there!
Krampuss is offline   Reply With QuoteReply With Quote
Old 02-24-2024, 11:13 PM #14
1000MPH's Avatar
1000MPH 1000MPH is offline
1000MPH is a name known to all 1000MPH is a name known to all 1000MPH is a name known to all 1000MPH is a name known to all 1000MPH is a name known to all 1000MPH is a name known to all
1000MPH's Avatar
I guess we’re not the only ones having this problem.
Rodents incapacitate millions in eco-friendly military equipment in Ukraine: the unforeseen problem
1000MPH is offline   Reply With QuoteReply With Quote
Old 02-27-2024, 10:15 AM #15
Humble Leader's Avatar
happened to me about a month ago. multiple cylinders misfiring according to the dealer. good thing I didn't have far to go home and was able to drive slow or I would have needed a flat bed... had to put the truck in P every time I came to a stop because I thought it would stall out due to low RPM, it was really shaking! repair was covered by insurance though which is nice, minus deductible
engine , flashing , light , rough , tubing
P0306 Misfire Rough Idle airforceabbott 4th Gen T4Rs 55 03-22-2023 04:19 PM
Running Rough and Cylinder 5 Misfire kctigrgrl 3rd gen T4Rs 18 10-12-2021 05:00 PM
Rough Idle/Misfire after muffler replacement jcm 4th Gen T4Rs 2 01-21-2017 09:24 PM
93 SR5, misfire, rough idle. No CEL 93bushbeater Classic T4Rs 20 01-15-2016 12:54 PM
Misfire/rough idle fixed for free fullboogie 4th Gen T4Rs 4 07-15-2014 09:56 AM
