Home Menu
Site Navigation
User Tag List
Reply
Thread Tools Rate Thread Display Modes
Old 04-18-2022, 09:24 PM #1
jmmec jmmec is offline
Junior Member
jmmec is on a distinguished road
Junior Member
Engine Rat/Mouse - Chewed Tubing + Cylinder 3 Misfire + Rough Idle
Ah, not good...
I have a 2016 4Runner TRD PRO and when I started it today I immediately noticed a rough idle followed by the dashboard showing:
  • Check Engine light flashing
  • TRAC OFF light flashing
  • Multi-Terrain Select light flashing
ODB shows codes:
  • P0303 Cylinder 3 Misfire
  • P1605 Rough Idle
When I opened the hood there was a little sign of grassy material, nothing at all like a nest, but I'm pretty sure a rat / mouse did some damage. See the attached pics where there is some chewed tubing.
What is this chewed tubing for? Can I temporarily duct tape it back together?
I'm not a mechanic so have an appointment at a shop on Wednesday. But anything else I can troubleshoot before then? I'll take a closer look at the engine bay tomorrow to see if there is any other evidence of damage.
Thank you for any advice....
Pictures:
Engine Rat/Mouse - Chewed Tubing + Cylinder 3 Misfire + Rough Idle-dashboard-resize-jpg  Engine Rat/Mouse - Chewed Tubing + Cylinder 3 Misfire + Rough Idle-chewed-resize-jpg  Engine Rat/Mouse - Chewed Tubing + Cylinder 3 Misfire + Rough Idle-chewed-closeup-resize-jpg
jmmec is offline   Reply With QuoteReply With Quote
Old 04-18-2022, 09:45 PM #2
214RUNNER's Avatar
214RUNNER 214RUNNER is offline
Member
Location: THE ARM PIT OF AMERICA NY STATE THE ROTTEN APPLE
214RUNNER is on a distinguished road
Member
214RUNNER's Avatar
Looks like the vacuum hose to the fuel pressure regulator. Take the old hose off & replace it clear the codes. if you don’t have a way to clear codes auto zone can do it and you can get the hose there also
214RUNNER is offline   Reply With QuoteReply With Quote
Old 04-19-2022, 09:56 AM #3
Junior Member
Junior Member
Thank you!
Hoping this is the only fix that is needed.
I didn't find the broken tubing until after I drove it about 8 miles -- it drove fine, just sluggish. Anyone know if it is damaging to drive it another 5 miles to AutoZone to get some new tubing?
Would taping it together before driving there help at all? I guess that line is normally pressurized? No fuel at all is coming out of it.
Old 04-19-2022, 11:27 AM #4
Charles Bronson Charles Bronson is offline
Member
Charles Bronson has a spectacular aura about Charles Bronson has a spectacular aura about
Member
Do you not have a friend or coworker that can take you?
Taping it together should work assuming you're using decently strong tape. There isn't a ton of vacuum. Tape it together and see how it runs. If it runs smoothly, then go to the auto parts store.
I'd cut a small piece of the line so that when you go to the auto store, they can get you the correct inner diameter line. Make sure to measure the full length of line you need.
Don't worry, this isn't rocket science. You're truck in running like crap and throwing codes because it has a major vacuum leak and the fuel pressure regulator isn't getting the vacuum it needs to work correctly. I wouldn't drive until it's temporarily fixed with tape or a new line.
Charles Bronson is offline   Reply With QuoteReply With Quote
Old 04-19-2022, 02:07 PM #5
Junior Member
Junior Member
I took another look under the hood and the wires that connect to (the coil pack on?) cylinder 3 are chewed off. I don't see other damage besides the chewed vacuum line.
Ya, I'll get a ride over to AutoZone to get some supplies to replace or at least patch the vacuum line. I'm taking it to a shop tomorrow in case there are additional problems.
Thanks everyone....
Old 04-19-2022, 10:58 PM #6
BlackWorksInc's Avatar
BlackWorksInc BlackWorksInc is offline
Elite Member
BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold
Elite Member
We keep a roll or two of Rodent Tape for these types of repairs. I'll repair a harness and then wrap it in this stuff. I think we order it from Honda?
I don't know how well it works, but I can't say that I have really seen many come-backs for rodents chewing through that stuff that I can recall?
Part # 4019-2317
Be thankful they didn't chew up the knock sensor harness, that's an annoying pain in the ass to replace without pulling a cylinder head off.
BlackWorksInc is offline   Reply With QuoteReply With Quote
Reply
Tags
engine , flashing , light , rough , tubing
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
P0306 Misfire Rough Idle airforceabbott 4th Gen T4Rs 55 03-22-2023 04:19 PM
Running Rough and Cylinder 5 Misfire kctigrgrl 3rd gen T4Rs 18 10-12-2021 05:00 PM
Rough Idle/Misfire after muffler replacement jcm 4th Gen T4Rs 2 01-21-2017 09:24 PM
93 SR5, misfire, rough idle. No CEL 93bushbeater Classic T4Rs 20 01-15-2016 12:54 PM
Misfire/rough idle fixed for free fullboogie 4th Gen T4Rs 4 07-15-2014 09:56 AM
Powered by vBadvanced CMPS v3.2.2
Copyright ©2000 - 2024, vBulletin Solutions Inc.
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2024 DragonByte Technologies Ltd.
Feedback Buttons provided by Advanced Post Thanks / Like (Lite) - vBulletin Mods & Addons Copyright © 2024 DragonByte Technologies Ltd.
User Alert System provided by Advanced User Tagging (Lite) - vBulletin Mods & Addons Copyright © 2024 DragonByte Technologies Ltd.
Copyright © 2020
