Old 04-24-2022, 10:26 AM #16
214RUNNER's Avatar
214RUNNER 214RUNNER is offline
Location: THE ARM PIT OF AMERICA NY STATE THE ROTTEN APPLE
214RUNNER is on a distinguished road
214RUNNER's Avatar
M 21 TRD Off Road Premium had the same play less than 5000 miles. I put the ECGS bushing and new seal got rid of 80% of that play, I didn’t trust the dealer to fix it were i am so i did it my self. I also had a slight vibration that started around 30 to 40 mph in 2WD & went away in 4WD. Now there is no more vibration in the diff.
I did notice the driver side axles sticking out about 2mm from the diff to the dust shield on the inner axle, i saw a video on youtube guy had almost the same thing he said he checked a few 4Runners at the dealer to compare and was the same. Other than the steering wheel shake once & a wile i think I’m god for at least 250 300 thousand miles.
Originally Posted by futz_roy View Post
They sent a video of the play in the axle.
When I was under the car, there was the same amount of play on the driver side and passenger side.
Any additional insight on if this is normal or excessive/unacceptable is greatly appreciated.
April 20, 2022 - YouTube
214RUNNER is offline   Reply With QuoteReply With Quote
Old 04-24-2022, 10:31 AM #17
Jakeepoo3's Avatar
Jakeepoo3 Jakeepoo3 is offline
Jakeepoo3 has a spectacular aura about Jakeepoo3 has a spectacular aura about Jakeepoo3 has a spectacular aura about
Jakeepoo3's Avatar
That little gap between the diff and axle is normal
Jakeepoo3 is offline   Reply With QuoteReply With Quote
Old 04-24-2022, 10:52 AM #18
214RUNNER's Avatar
214RUNNER's Avatar
Yea i figured that it was ok, i forgot to check it to compare before and after i think it was a total of about 4mm. if i pushed the axle in to the diff it was about 1/2mm from flush with dust shield and 3 1/2mm out. 4mm isn’t that much but i wasn’t sure what it was before so that got me over thinking about it.
Old 01-13-2024, 11:20 PM #19
Jake.e Jake.e is offline
Jake.e is on a distinguished road
That lateral, side to side, play is no good. There should be a small amount of straight in and out play. I had the same thing happen on the driver side at 100,000 miles. Caused a vibration in the steering wheel under acceleration. I caught it way before it got as bad as yours is. I made a video the same way you did if you want to check it out to see the comparison. New axle time! You can refurbish them OEM gold bricks before they get really bad. I've been abusing the sh1t out of $60 A1 Cardones on the trail over a year smooth as a cloud so far. Kept OEMs for trail back ups. Here it's the vid link.
登录 Facebook | Facebook
When you say yours had straight in and out play, do you mean the cv axle itself would slide in and out of the dif slightly? For some reason my drivers side axle doesnt seem locked in? It slides in and out like an eighth to a quarter of an inch
Jake.e is offline   Reply With QuoteReply With Quote
Old 01-14-2024, 10:07 AM #20
my passenger side does the same. not sure if it's that much but yeah.
Old 01-20-2024, 11:22 AM #21
Jakeepoo3's Avatar
Jakeepoo3's Avatar
Yes sir! That's exactly how it should work. You're good!
Old 01-22-2024, 11:51 AM #22
CutthroatSlam CutthroatSlam is offline
CutthroatSlam is a splendid one to behold CutthroatSlam is a splendid one to behold CutthroatSlam is a splendid one to behold CutthroatSlam is a splendid one to behold CutthroatSlam is a splendid one to behold CutthroatSlam is a splendid one to behold CutthroatSlam is a splendid one to behold CutthroatSlam is a splendid one to behold
346K on original axles, but installed the ECHS bushing which cleaned up a lot of the front end issues. Any little play in the front, coupled wirh poorly balanced tires, and you will get the shakes at 60.
CutthroatSlam is offline   Reply With QuoteReply With Quote
axle , excess , front , play , vehicle
Cv axle play chris.andros.18 3rd gen T4Rs 6 01-13-2024 11:37 PM
CV axle play Ehahn84 3rd gen T4Rs 10 01-13-2024 11:24 PM
CV Axle Play keithyota 4th Gen T4Rs 1 11-25-2020 09:24 AM
CV axle clunks over bumps excessive play at front diff sickskinz 4th Gen T4Rs 1 01-26-2016 05:51 PM
Right front axle play at the differential Atomic_Dog Classic T4Rs 6 02-14-2012 04:10 PM
