Old 04-24-2022, 08:12 PM #1
MK_Ultra's Avatar
MK_Ultra MK_Ultra is offline
MK_Ultra is on a distinguished road
MK_Ultra's Avatar
Spare Tire Wheel Fit?
I have used search and understand that a 285 tire will fit under the 4Runner. I am skeptical about this as my OEM spare tire is almost flush with the edge and it looks like there is no room.
I just bought a new set of BF Goodrich All Terrain T/A KO2 LT265's and have an extra one I would like to use as a spare. My question is should I mount the BF Goodrich All Terrain T/A KO2 on the spare wheel/rim and place it back underneath or should I get another wheel/rim which matches my Trail wheels?
I am curious if it has to be the spare rim or will another wheel work?
MK_Ultra is offline   Reply With QuoteReply With Quote
Old 04-24-2022, 10:06 PM #2
NB17Limited's Avatar
NB17Limited NB17Limited is offline
NB17Limited will become famous soon enough NB17Limited will become famous soon enough
Limiteds come with a matching spare. I currently have 5 Pro wheels with one as the spare. Works fine
NB17Limited is offline   Reply With QuoteReply With Quote
Old 04-24-2022, 10:28 PM #3
Rightside Up's Avatar
Rightside Up Rightside Up is offline
Rightside Up will become famous soon enough Rightside Up will become famous soon enough
A nice wheel could get dinged up pretty good under there.
2018 ORP Barcelona Red
Dobinsons 2.5”/1.5” lift with springs and shocks.
Diff. Drop.
Pro Comp UCAs.
RSG angled sliders.
Rightside Up is offline   Reply With QuoteReply With Quote
Old 04-24-2022, 11:19 PM #4
CF_Machete's Avatar
CF_Machete CF_Machete is offline
CF_Machete has a spectacular aura about CF_Machete has a spectacular aura about
CF_Machete's Avatar
Yeah , ran a ko2 285/70/17 on the spare rim for a few years. You get som play with where the wheel sits when the chain has some slack.
If you're in the nj area, you can try my spare on for size. Its been sitting in my garage since i switched to a bumper swing mounted spare.
Troner envy... the struggle is real!
CF_Machete is offline   Reply With QuoteReply With Quote
Old 04-25-2022, 12:58 AM #5
wcjeep's Avatar
wcjeep wcjeep is offline
wcjeep has a spectacular aura about wcjeep has a spectacular aura about wcjeep has a spectacular aura about
wcjeep's Avatar
Different vehicle I own has a tight fitting spare. It's deflated to zero psi when stowed. At zero psi the spare has no problem being stowed. The truck has onboard air in case of emergency. The truck is typically towing my offroad jeep that also has onboard air.
2018 Offroad Premium w/KDSS
1993 Jeep YJ w/stuff
wcjeep is offline   Reply With QuoteReply With Quote
Old 04-25-2022, 05:56 AM #6
TRD PANTHER's Avatar
TRD PANTHER TRD PANTHER is offline
Real Name: BLACK TRD PRO
TRD PANTHER has much to be proud of TRD PANTHER has much to be proud of TRD PANTHER has much to be proud of TRD PANTHER has much to be proud of TRD PANTHER has much to be proud of TRD PANTHER has much to be proud of TRD PANTHER has much to be proud of TRD PANTHER has much to be proud of TRD PANTHER has much to be proud of
I run a 285/70-17 on a matching TRD Pro wheel that fits in the spare tire well fully inflated. The nice side faces upward. I hear from those who have KDSS that it rubs slightly against the bar, but works.
I do a five tire rotation and like to have a matching size tire and wheel.
Spare Tire Wheel Fit?-a87b6949-7364-46a9-9808-2ce509e28308-jpg
TRD PANTHER is offline   Reply With QuoteReply With Quote
Old 04-25-2022, 08:29 AM #7
Turn_down's Avatar
Turn_down Turn_down is offline
Turn_down is on a distinguished road
Turn_down's Avatar
Bit off topic but arr your rims 7” wide? Any issues running 285’s on a 7” rim?
Turn_down is offline   Reply With QuoteReply With Quote
Old 04-25-2022, 02:43 PM #8
MK_Ultra's Avatar
MK_Ultra's Avatar
Thank you for all of the information, this is helpful. I assume the trail wheel is lighter then the spare wheel and just better all around? I want to use this as the spare wheel:
Old 04-25-2022, 04:31 PM #9
Humble Leader's Avatar
the standard trail wheel will work. many have a fifth TRD pro, trail or standard rim as their spare rather than the steelie. limited have a full size spare as well so it will work. I have 265s on an 8" wide rim and it fits just fine and I think the trails are 7.5" wide so you should have no issues
Old 04-25-2022, 11:01 PM #10
Yes, they are 7" wide and I have never had any issues. Since I have a SL rated tire the lowest I air down to is 19psi. On my previous 2001 4Runner that I had for 17+ years, I ran a 285/75-16 on the factory 7" wheels and never had any problems.
Old 05-04-2022, 07:47 AM #11
jdm-v35 jdm-v35 is offline
jdm-v35 is a jewel in the rough jdm-v35 is a jewel in the rough jdm-v35 is a jewel in the rough jdm-v35 is a jewel in the rough
It will fit, but the trail wheel is much heavier than a steelie. I believe it is 31 lbs each. No real benefit vs a steelie for short term use.
jdm-v35 is offline   Reply With QuoteReply With Quote
fit , goodrich , spare , tire , wheel
WTB: One 285-70-17 AT spare tire and TRD Pro wheel. So Cal TRD PANTHER For Sale: Suspension/Wheels/Tires 3 09-07-2020 12:38 AM
FS: 2016 4runner Trail - 4 Wheel/Tire Combo + 1 spare tire (Houston, TX) brg128 For Sale: Suspension/Wheels/Tires 2 03-21-2016 08:54 AM
WTB Spare Gen 5 SR5 Wheel & Tire Erkelbot For Sale: Suspension/Wheels/Tires 1 11-24-2015 11:13 AM
3rd Gen Spare Tire and Wheel Tomsea999 Free 4 09-12-2015 08:21 PM
FS: spare tire + wheel Flo4Run Classifieds - buy & sell (no commercial ads please) 1 11-02-2008 12:52 AM
