04-26-2022, 09:17 PM
Thoughts on reverse light modifications
So, I think we can agree the factory reverse lights are a bit lackluster. I've installed LEDs in mine and got a bit of improvement but could still be better. I know there are products out there like the Diode Dynamics tails as turns modules, but I don't know that I want the tails doing triple duty (running, brake and turn lights). I'm also aware of Diode Dynamics aux reverse lights but I find them a bit expensive for what they are at over $200 for the lower end set.
This got me thinking, has anyone tried doing a bit if rewiring and switched the reverse and turn signal lights? Basically, switching the wires on the light connectors. A decent amber LED should be bright enough to be seen during the day and would allow for the same setup the tails as turns modules provide minus having 4 reverse lights. I suppose my only concern would be field of view for the turn signal since it's greater for the factory turn signals than the factory reverse lights.
Any thoughts?
FTR, I've used fog lights as aux reverse lights on 3 trucks and really like the flush mounted bumper lights I currently have on my Ram but that's not really an option on a factory 4R rear bumper.
2016 Trail Attitude black. 1.5" unknown brand lift, 275/70-17 Toyo Open County A/T on DX4 Rebel 17x8.5 -6, bull bumper, light bar, skid plate by Amazon, DD fogs, TRD roof rack by Craig's List, Accessorides remote start kit
04-27-2022, 06:08 AM
Real Name: James
Real Name: James
04-27-2022, 09:46 AM
I did the tail as turn mod and couldn’t be happier. I recommend it to everyone I know that has a 4Runner and they all love it.
04-27-2022, 09:55 AM
04-27-2022, 11:08 AM
That's a very interesting idea. I have not seen it before but I'm sure it can be done by someone willing to hack up their tail light wiring. I expect it would require cutting, swapping, and reconnecting the wires to the bulb connectors, as well as getting the correct bulb colors installed (turn signal and reverse bulbs are different sizes/shapes but I'm sure you can get amber and white versions of each). The "field of view" shouldn't be too impacted because the existing turn signal is essentially pointed straight back (the reflective bowl in the tail light acts as "blinders" so they are not actually visible from the side anyway). DOT laws probably require a certain area of illumination for the turn signal but I can't see someone being pulled over for this as long as the bulb is bright enough. I would guess an LED turn signal in the reverse light location would be plenty bright enough (have you seen some of these aftermarket LED turn signal bulbs? They are blinding!!!). Probably won't be too much aftermarket support for something like this since the tail-as-turn module exists but it would be a unique solution!
Just to share my solution (even though its probably not what you are looking for): I went the Meso Customs hitchpod route with the Baja Designs S1 and a custom wiring solution from a hacked up Diode Dynamics stage series reverse light wiring harness (not plug and play, required cutting and adding a new ground). This combined with LED reverse bulbs in the factory location definitely increased the amount of light output and is almost unusable when it rains (fair bit of glare...). My next goal is to wire up a momentary switch to allow be to flash people behind me that have their brights on!
Keep us updated if you decide to hack up your tail light wiring. Would love the see the final result!!
04-27-2022, 12:13 PM
Real Name: C8H18 Mike
I spliced into my reverse light wiring at my rear to add external LEDs, simple. Picked up the ground off the frame.
Sent from my Pixel 4 XL using Tapatalk
1999 Toyota 4Runner SR5 Un-Sported 2WD, V6 Auto -> 2WD 4runner Journal Thread
04-27-2022, 01:20 PM
I did the DD tail as turn mod. Instead of using the factory reverse lights, I left them unplugged. I also did not want 4 reverse lights. In the factory reverse light locations, I added 2 red bulbs switched independently to act as rear fog lights. Similar to what is found in Asia/Europe etc.
Rear fog light - EDM/JDM spec, factory look
Or you can add another reverse light in the hitch receiver.
HitchPod Combos
– MESO CUSTOMS LLC
2015 Magnetic Gray SR5P
04-27-2022, 04:15 PM
I hacked up my wiring and have a white/amber switchback in the original turn signal and left the original reverse light as is. Reverse now has the original light and the white bulb in the turn signal. Amber turn signals still function as expected and will override the reverse signal
04-27-2022, 09:17 PM
I have the sport ssc1 version of these and been happy.
2010-2021 Toyota 4Runner LED Pod Reverse Light Kit
Get extra red taillights (no brake) when lights are on. Bright white reverse lights when in reverse. And I also wired the white lights into a switch on my switchpro so i can turn them on whenever as well.
Michael
2021 Pro Lunar Rock: RCI tranny/transfer case/tank skids, Victory roof rack
2014 LE Nautical Blue: 285/70R17 Falken A/T3W, FX Pro wheels, Fox TRD Pro suspension with Wescott lift, Dobinson UCA's, Metal Tech sliders
04-28-2022, 01:07 AM
04-28-2022, 04:19 PM
Originally Posted by JaSC1
This is what I’ve done too, and it’s worked great. Bright as day in the back without any extra wiring.
04-28-2022, 04:25 PM
Real Name: Chris
Real Name: Chris
I had the tail as turn and it was ridiculous and too much for me, I went back to single reverse lights, but they're bright AF and work plenty good for me
Amazon.com: LASFIT 921 912 LED Bulb Reverse Light, T15 W16W 6000K Xenon White Replacement Back up Lights For Cars (Pack of Two) : Automotive
05-05-2022, 04:05 PM
I had the VLED's 921's in 5k temp and they were much brighter than the halogen bulb.
