View Poll Results: What is the best auxiliary light switcher for the T4R?
Trigger Six Shooter 3 12.50%
Trigger Six Shooter
3 12.50%
Auxbeam 8 Gang Switcher 5 20.83%
5 20.83%
Other system: 16 66.67%
Other system:
16 66.67%
Multiple Choice Poll. Voters: 24. You may not vote on this poll
Old 05-17-2022, 12:07 AM #16
NautyBruiser19 NautyBruiser19 is offline
NautyBruiser19 will become famous soon enough
I went the path of building my own Bussman IPDM mounted on a Powertray bracket. I moved the USB/AUX. port in the center stack to the glove box, and that gave me 6 OEM switch blank spots. I use AOB switches since they have the same light blue LEDs as Toyota, and they are high quality. 2 of the positions are used for a dual voltage meter and a RJ45 passthrough, so I plan on machining an insert for the useless cubby to add 2 more positions. S-tech has a 3-D insert they offer for that spot, but it's ridiculously expensive.
Picture of the Bussman on the Powertray bracket:
Switch panel locations-bussman-jpg
-2019 Nautical Blue ORP
NautyBruiser19 is offline   Reply With QuoteReply With Quote
Old 05-23-2022, 06:23 PM #17
sandbuster sandbuster is offline
sandbuster is on a distinguished road
That's a nice clean way of doing it - looks good!
sandbuster is offline   Reply With QuoteReply With Quote
Old 05-24-2022, 01:22 PM #18
Nice clean work! I like to see folks be a little more creative in their add-ons as opposed to just slapping on store bought items - which I readily acknowledge we all do but it's nice to see folks go out of the box occasionally.
Being an older guy (and having the extra time) I try to make my add-ons reflect a little of me - an example of that is I used several of the available blank switch spots on the dash to put in OEM look-alike switches but on my last DIY project I went back to the old school way by building my own simple switch panel with a couple of voltmeters to monitor main & aux batteries. I'm new to this forum so not sure if my picture/video efforts will turn out...
https://www.youtube.com/watch?v=9ZjfeeHldkc
Okay, so I think the video plays okay but suspect there is a better way to do this?
Old 05-24-2022, 08:30 PM #19
bayaz bayaz is offline
bayaz will become famous soon enough
Originally Posted by 91foxbody View Post
This unit looks to be very popular in the Jeep circles and I just received mine. Hope to install it next week but we'll see!
switch panel
Voswitch is great. It’s like the old school version of the S pod for a more affordable price.
bayaz is offline   Reply With QuoteReply With Quote
Old 05-25-2022, 06:53 AM #20
Thanks! I feel exactly the same. I've got quite a few unique modifications I'll be posting about eventually. One of them is a hidden solar panel port behind a self-opening, hinged front license plate. Just unthread two thumbscrews on the license plate and it opens up 90 degrees and stays in place with a spring loaded hinge. Have a flush mount APP receptacle behind it with a weather seal cover on it, and plug in my portable 200w panel.
The video works fine and what a great set-up! That 3000w inverter is a monster. I see you have a 2nd battery as well. Mine is installed in the same spot as yours. Which 500A solenoid are you using? I didn't catch it in the video. I've got a BlueSea Systems remote battery switch I'm using to keep my winch(waiting to be installed) disconnected when not in use, which is also rated at 500A continuous - with 2x 4/0 cables, lol. That's one of my switch positions(winch power).
You've got a lot of radios in there as well. I'm just now in the process of installing a GMRS. Installing the previously mentioned RJ45 passthrough is one of my tasks this weekend.
Old 09-06-2022, 03:45 AM #21
socal74 socal74 is offline
socal74 is on a distinguished road
Just purchased an Auxbeam 8 gang. Mine came with add a fuse with a 5 amp fuse in it. Is it ok for me to replace the 5 amp fuse and put a 10 amp fuse? I've read some guys putting the add a fuse in the acc slot. Any of you guys know where that would be? I have looked up and down my 2022 4 runner fuse box diagram and can't seem to find it. below is a diagram of a 2022 4runner fuse box. Please dont mind the ac writing on the pic.
[IMG]EEE44-B50-27-C1-4-F07-B6-E6-B239895-E7-E99
image upload
[/IMG]
socal74 is offline   Reply With QuoteReply With Quote
Old 09-06-2022, 04:09 AM #22
je32188 je32188 is online now
je32188 is on a distinguished road
I'm 95% sure the ACC fuse is in the cab by the OBDII port.
This post has pictures of the fuse box diagrams of a 2020, so it's probably similar, but of course triple check yours:
https://www.toyota-4runner.org/3427726-post5.html
je32188 is online now   Reply With QuoteReply With Quote
Old 09-06-2022, 05:38 AM #23
mrblah's Avatar
mrblah mrblah is offline
mrblah's Avatar
i run the trigger 6 shooter. I have no complaints. Its very easy to add lighting accessories.
Old 09-06-2022, 03:16 PM #24
hoppyjr hoppyjr is offline
hoppyjr has a spectacular aura about hoppyjr has a spectacular aura about hoppyjr has a spectacular aura about
image upload
[/IMG]
Not Toyota specific, but it’s generally not a good idea to use a higher amp fuse in any location. You want it low enough to blow before damage is done elsewhere.
While I don’t have experience with the Auxbeam 8, the switch panel should only require minimal amps anyway, as it only handles the switching/triggering. The relay or main unit handles the power distribution duties.
hoppyjr is offline   Reply With QuoteReply With Quote
locations , panel , switch , switches , system
FS,BNIB: Switch-Pros 8100 Switch Panel PAKM4N For Sale: T4R Items 2 12-28-2016 05:14 PM
Anyone using a switch pros switch panel? mavrick1903 4th Gen T4Rs 0 04-11-2016 11:14 PM
What are all these empty switch locations for? akaknowlesy Engines / Suspension / Wheels / Tires / Audio / Accessories 5 03-30-2010 10:59 PM
Fuse Panel Locations / Diagrams? 3rd Brake Light Out whodkne 4th Gen T4Rs 3 10-31-2004 02:39 AM
