View Poll Results: What is the best auxiliary light switcher for the T4R?
Trigger Six Shooter 3 14.29%
Trigger Six Shooter
3 14.29%
Auxbeam 8 Gang Switcher 4 19.05%
4 19.05%
Other system: 14 66.67%
Other system:
14 66.67%
Multiple Choice Poll. Voters: 21. You may not vote on this poll
Old 05-05-2022, 03:42 PM #1
Jrunr Jrunr is offline
Jrunr will become famous soon enough
Switch panel locations
I am debating between the Auxbeam 9 Gang switch panel and the Trigger Six Shooter system for my 21 TRD Pro. Which system would you choose, and why?
Also, what are the best mounting locations for the switches inside the cabin? I would love if you all could post pictures of your setups.
Show us what youíve got!!
2021 TRD Pro, MGM
Jrunr is offline   Reply With QuoteReply With Quote
Old 05-05-2022, 05:39 PM #2
chrisridebike8 chrisridebike8 is offline
chrisridebike8 will become famous soon enough
I picked s-tech because I wanted OEM style switches. they take up the little cubby under the radio. super nice system. it says it's for up to 2019 but I e-mailed asking if it would work on my '21 and it does. you just have to relocate one of the boxes to the rear (super easy). rather than have mine wired to a trigger to only be on when the truck is on, i wired mine to a switch to my second battery so I can choose when my switches are active.
S-TECH 6 Switch Systems - S-Tech Switch Systems™
I'll post pics from my phone later
2021 MGM 4Runner TRD Off Road, KDSS
Eibach | Falken | CaliRaised | Sherpa| Rago | Odyssey | Redarc | Rigd | Waterport | Baja Designs | Diode Dynamics | MaxTrax | Level 8 | OVS | S-Tech | Dr. KDSS | ARB | JLT | Anzo
2010 Black/Black C63 AMG, 460 whp (I miss this car every day)
chrisridebike8 is offline   Reply With QuoteReply With Quote
Old 05-05-2022, 05:39 PM #3
Titanpat57's Avatar
Titanpat57 Titanpat57 is offline
Real Name: Patrick
Titanpat57 is a jewel in the rough Titanpat57 is a jewel in the rough Titanpat57 is a jewel in the rough
Titanpat57's Avatar
Real Name: Patrick
I got the Auxbeam 6...still have 2 spots left...love it!
White 2016 TEP .....My ROAM Truck Build....... My ROAM trailer Build
Titanpat57 is offline   Reply With QuoteReply With Quote
Old 05-06-2022, 02:46 AM #4
They light up blue like the OEM switches. I have another OEM switch to the left of the steering wheel that ďarmsĒ these switches. You can even request that your first switch in the 6-pack do that but I wanted 6 specific things.
Old 05-06-2022, 10:04 AM #5
How and where did you mount the touchpad? How long have you had it? Any issues at all?
2021 TRD Pro, MGM
Old 05-06-2022, 01:37 PM #6
MasterFoo MasterFoo is offline
MasterFoo will become famous soon enough
Auxbeam 8 gang RGB here. Have had it for about a few months now. It works, it's priced decent. Doesn't feel cheap.
RGB model has a few features like changing the pad back light color and also have a strobe mode you can set for individual lights. You can control the lights with a phone app. Hide the switch and use your phone, if one would want it this way.
MasterFoo is offline   Reply With QuoteReply With Quote
Old 05-06-2022, 04:20 PM #7
PJSnow's Avatar
PJSnow PJSnow is offline
PJSnow is on a distinguished road
PJSnow's Avatar
That is a very clean installation! Don't mean to hijack the thread but how does that mount? Does S-tech give you a mount that fits in there or is it custom? Do you need to screw into the factory plastic cubby? I assume you need to drill a hole at the back of the cubby but is that the only modification?
PJSnow is offline   Reply With QuoteReply With Quote
Old 05-06-2022, 04:36 PM #8
91foxbody 91foxbody is offline
91foxbody will become famous soon enough 91foxbody will become famous soon enough
This unit looks to be very popular in the Jeep circles and I just received mine. Hope to install it next week but we'll see!
switch panel
91foxbody is offline   Reply With QuoteReply With Quote
Old 05-06-2022, 04:41 PM #9
The switches come in a 3D printed housing that just bolts into the cubby (you get to pick what you want and they are easily swapped later if you want). You are supposed to be able to just drill a hole in the back of the stock cubby, but the plugs are kind of long so I just cut the whole back of it off. I think this install guide will answer a lot of questions. Where my install differs is in the wiring. I ran the power to my second battery. And then rather than that trigger wire going to a fuse tap, I ran that to the second battery with an OEM style power switch in line.
https://stechswitch.com/wp-content/u...uide-0620c.pdf
Old 05-10-2022, 12:33 PM #10
ws6616 ws6616 is offline
ws6616 is on a distinguished road
don't use those cheap MIC crap... we do plenty of electrical installs at the shop and many people elect to have cheap MIC alternatives, and more often than not we find these MIC crap not working right out of box and have to send them back for replacement.
We also had a few older versions of auxbeam control panel failures, and when we tried to replace the control panel we found out the new panels use a different style connector to the control module, so the whole thing had to be replaced.
i personally run switch-pro 9100 mounted to the left side dash panel using SDHQ's mount. Inside the engine bay i use PowerTray switch-pro mount and bussman/ bluesea bus bars and fuse blocks. With Switch-Pro set up, I have one touch on for various lights (one master switch for front roof, front bumper, and ditch lights all on without toggling individual switch), 5-step output dimming, auto on when ignition is on (for the back light function of S8 that I use as DRL), bluetooth connectivity (very useful when you're not next to your rig but you see someone suspicious staying too close... very useful in california... or if you have side lights that you use for camp lights), strobe and burst (for people who cut you off and also for chase lights), and ability to turn on your lights with ignition off (camp lights)
ws6616 is offline   Reply With QuoteReply With Quote
Old 05-10-2022, 01:02 PM #11
97BlackAckCL's Avatar
Real Name: Chris
97BlackAckCL has much to be proud of 97BlackAckCL has much to be proud of 97BlackAckCL has much to be proud of 97BlackAckCL has much to be proud of 97BlackAckCL has much to be proud of 97BlackAckCL has much to be proud of 97BlackAckCL has much to be proud of 97BlackAckCL has much to be proud of 97BlackAckCL has much to be proud of 97BlackAckCL has much to be proud of
Real Name: Chris
I did the sPod and mounted over the stock switch bank, love the look
2017 Nautical Blue SR5 Premium - Black Emblems, AFE TB Spacer, AFE Momentum GT Intake, URD MAF Calibrator, Borla Touring Cat-Back Exhaust, RCI Skid Plate, Morimoto MLED 2.0 Headlight Retrofit, Morimoto LED Fogs, Eagle Eye Smoked Black Tail Lights, FyreFlys LED Interior, Meso Puddle Lights, Tinted Mirror Turn Signals, Smoked Amber Raptor Lights, Odyssey 34 Battery, 32" LED Bar with Rago Hidden Brackets, Rago Molle Panels, Side Shooter LED Ditch Lights, sPod w/ PowerTray, Raceline Matte Bronze Wheels w/ Cooper Discoverer RTX, CaliRaised Rock Sliders, BajaRack Full Length Roof Rack, Kenwood DMX1057XR, Infinity Kappa Door Speakers and 3.5's in dash, JL 8w3v3 in JBL Enclosure, Husky Weather Beaters, Blackvue DR900S Dash Cams
Old 05-11-2022, 02:53 PM #12
bayaz bayaz is offline
bayaz will become famous soon enough
Online LED Store has some great product. The whole power distribution block, fuse and relay block, and switch box will run you less than $100. All the fuses, wires, and relays included. You would have to spend a few hours wiring every fuse, relay, abs button, however.
bayaz is offline   Reply With QuoteReply With Quote
Old 05-11-2022, 05:57 PM #13
Ascole Ascole is offline
Ascole will become famous soon enough
I mounted mine below the factory switches. As long as you know what switch does what, you donít have to look at them. 2 years now and no issues whatsoever.
Ascole is offline   Reply With QuoteReply With Quote
Old 05-11-2022, 08:21 PM #14
matoolie's Avatar
matoolie matoolie is offline
matoolie will become famous soon enough matoolie will become famous soon enough
matoolie's Avatar
Switch Pro. This location is very visible and easily accessible. Mounted with 3M double sided tape with one hole in dash panel for wiring. Dash Panel can easily be replaced from Toyota for $30+.
Michael
2021 Pro Lunar Rock: RCI tranny/transfer case/tank skids, Victory roof rack
2014 LE Nautical Blue: 285/70R17 Falken A/T3W, FX Pro wheels, Fox TRD Pro suspension with Wescott lift, Dobinson UCA's, Metal Tech sliders
matoolie is offline   Reply With QuoteReply With Quote
Old 05-16-2022, 11:43 AM #15
Titanpat57's Avatar
Real Name: Patrick
Titanpat57's Avatar
Real Name: Patrick
sorry it took so long....
Switch panel locations-auxbeam1-jpg
locations , panel , switch , switches , system
FS,BNIB: Switch-Pros 8100 Switch Panel PAKM4N For Sale: T4R Items 2 12-28-2016 05:14 PM
Anyone using a switch pros switch panel? mavrick1903 4th Gen T4Rs 0 04-11-2016 11:14 PM
What are all these empty switch locations for? akaknowlesy Engines / Suspension / Wheels / Tires / Audio / Accessories 5 03-30-2010 10:59 PM
Fuse Panel Locations / Diagrams? 3rd Brake Light Out whodkne 4th Gen T4Rs 3 10-31-2004 02:39 AM
