Old 05-13-2022, 11:05 AM #1
Predatorsniper2005 Predatorsniper2005 is offline
Predatorsniper2005 is on a distinguished road
Brand New T4R - Brand New Toyo ATIII Not Balancing? **UPDATE/FIXED**
Hello Forum Experts,
I took delivery of my 22 ORP a few weeks ago and immediately order some Toyo ATIII's from Discount Tire. First time I drove the truck with the new tires the balance was off. I brought it back and they rebalanced everything. Then when I had time to drive it on the highway, there is a bit of steering wheel shake at like 58-62mph, above and below speeds its smooth. So I took it back to Discount tire and they ordered me (2) brand new tires. Installed those today on the front, same issue, just at a different speed range (54-57mph). The only thing the Manager at Discount Tire suggests is choosing a different set of All Terrains... Thoughts?
Note: My brand new ORP has 400 miles on it currently, it came with TRD Black Pro wheels from the factory.
Thanks, Mike
Predatorsniper2005 is offline   Reply With QuoteReply With Quote
Old 05-13-2022, 11:31 AM #2
mo_mo mo_mo is offline
mo_mo has a spectacular aura about mo_mo has a spectacular aura about
Take it to a shop that can balance wheels properly.
2014 T4R TE Nav KDSS Super White
Demello Hybrid Bolt On Sliders | Toyo Open Country AT III LT285/70R17 C | Ironman 4x4 Foam Cell Pro Stage 2 | Durobumps | Rago Molle Panels | Leather steering wheel cover | RCI Full Skids (Aluminum) | Drawer less drawer system and sleeping platform. | TRD CAI | RAV4 Sideview Mirrors: 87961-42D20 & 87931-42D50 | Blackvue DR650S-2CH | Cobra 75 WX ST with 4’ Firestik + Magnet Roof Top Mount | MXT275 Midland GMRS radio | 3M Crystalline: Front CR70, A-B CR50, B-Aft CR40 | RRW Leather Seat Covers w/Besond Seat Heaters| 3DMax Floor Mats and Rear Husky Liner | former LT265/70R17 C Duratracs
mo_mo is offline   Reply With QuoteReply With Quote
Old 05-13-2022, 11:45 AM #3
Sundy Sundy is offline
Sundy has a spectacular aura about Sundy has a spectacular aura about Sundy has a spectacular aura about
Road force balance
2019 TRD ORP w/KDSS: Dobinsons IMS Lift (front C302 - 3" / rear C725 - 2.5"), Freedom Offroad UCA's, Falken Wildpeak AT3W 255/80R17, RSG Angled Kickout Sliders & Skid Plate, C4 Lo Pro, Warn Evo 10S, Agency 6 Flatlink, Diode Dynamics SS3 Fogs, Desert Does It Seat Jackers, Sherpa Crestone Rack, Outer Tents RTT
Sundy is offline   Reply With QuoteReply With Quote
Old 05-13-2022, 12:19 PM #4
comtn4x4's Avatar
comtn4x4 comtn4x4 is offline
comtn4x4 is a splendid one to behold comtn4x4 is a splendid one to behold comtn4x4 is a splendid one to behold comtn4x4 is a splendid one to behold comtn4x4 is a splendid one to behold comtn4x4 is a splendid one to behold
comtn4x4's Avatar
Thanks, Mike
I'd get ahold of Toyo and see what they say. And maybe consider a different tire. Even if someone can balance the tires this time it'll be a challenge every time you rotate them. Do you really want that issue for the life of the tire? I had this issue with some Nittos and it was a huge pain
comtn4x4 is offline   Reply With QuoteReply With Quote
Old 05-13-2022, 04:05 PM #5
02SE 02SE is offline
02SE is a splendid one to behold 02SE is a splendid one to behold 02SE is a splendid one to behold 02SE is a splendid one to behold 02SE is a splendid one to behold 02SE is a splendid one to behold 02SE is a splendid one to behold
Ask the manager if there's anyone that knows how to use a road-force balancer to it's full capability.
Make sure the machine is calibrated, tell them to turn off the 'Smart Weight' feature, check the wheels for excessive run-out, and match mount the tires if necessary. If that still doesn't do it, consider other tires.
I would suggest avoiding Falken tires, as they frequently have uniformity issues.
02SE is offline   Reply With QuoteReply With Quote
Old 05-13-2022, 04:10 PM #6
Saker's Avatar
Saker Saker is offline
Saker's Avatar
Road force & Also make sure they are using the correct adapter for Toyota hub centric wheels!!!!!!
Best Regards,
Saker
Old 05-13-2022, 05:34 PM #7
Originally Posted by Sundy View Post
Road force balance
OP, that was done, also it was done on 2 different machines. The Road Force balancing was showing the new tires are in spec.
Old 05-13-2022, 05:40 PM #8
I did call Toyo directly, they feel that Discount Tire has done all the right things. The Road Force was reading 10, whatever that means. The Manager was saying that they needed to be below a 30 number, so 10 was good...
Old 05-13-2022, 05:52 PM #9
Something_Awesome's Avatar
Something_Awesome Something_Awesome is offline
Something_Awesome will become famous soon enough
Can I ask what the load rating of the tires is?
Also, this:
https://www.toyotires.com/media/1492...n_complain.pdf
I also had vibration in the low to mid 60's. It resolved itself eventually (within a few hundred miles).
Something_Awesome is offline   Reply With QuoteReply With Quote
Old 05-13-2022, 06:07 PM #10
BillsRunner's Avatar
BillsRunner BillsRunner is offline
BillsRunner is on a distinguished road
Bring 'em back - go Cooper
Don't bother trying to get this particular set of tires to behave. Toyo and the shop should take them back! I've had problems with 2 sets of Nokia's - first they replaced 'em, then gave me a refund. I brought the tires to our local Toyota dealer (they are skilled) and found they were way out of spec - even Road Force balancing couldn't be done. Nokia offered a refund and I got some Cooper AT3s - smooth as silk the first time and every time after.
Don't waste your time and brainpower on this one!
And a "below 30" as a Road Force number is a very low bar - 10 is good but 20 would be not!
BillsRunner is offline   Reply With QuoteReply With Quote
Old 05-13-2022, 06:30 PM #11
Just because it was on a road-force balancer, doesn't mean it was done competently.
Lots of shops have the machines. Few have the ability or are willing to take the time to utilize the machines to the fullest extent.
Old 05-13-2022, 11:12 PM #12
Originally Posted by something_awesome View Post
can i ask what the load rating of the tires is?
Also, this:
i also had vibration in the low to mid 60's. It resolved itself eventually (within a few hundred miles).
115t sl
Old 05-13-2022, 11:20 PM #13
Also, this:
OP, did you have the AT3's as well? I'd really like to keep these tires, I choose Toyo for a reason, I'd hate to select a different A/T tire if I don't have too...
Old 05-14-2022, 12:08 AM #14
somenoise somenoise is offline
somenoise is on a distinguished road
I put on Toyo AT3 at discount tire (America's tire locally) and they balanced no problem first time around. Only thing is mine are E load. It seems to me a larger proportion of people with the balancing issue on the AT3s are with the SL load (I could be wrong). Wonder if their SL manufacturing is less consistent on this model.
somenoise is offline   Reply With QuoteReply With Quote
Old 05-14-2022, 07:23 AM #15
JaSC1 JaSC1 is offline
Real Name: James
JaSC1 will become famous soon enough
Real Name: James
I just put Toyo ATIIIs on, 255/80/17 Load E. No issues whatsoever. 2018 TRP Prem, ToyTec lift, Warn front winch bumper and winch. (hundred plus lbs) and JBA UCAs. At 4deg castor they track straight.
The pdf that was posted answered a question for me. Was wondering what yellow dot was on my new tires and now I know!
EDIT: Had them installed at Discount Tire.
JaSC1 is offline   Reply With QuoteReply With Quote
back , brand , discount , tire , tires
Toyo Open Country ATIII vs Yokohama Geolandar X-AT Gouranga Engines / Suspension / Wheels / Tires / Audio / Accessories 10 06-23-2021 02:38 PM
FS: Brand New 4 Toyo Proxes 225 45 15 and 4 Rota Grid V White 15x8 et0 Saltville, VA serinaj10 For Sale: Suspension/Wheels/Tires 0 08-14-2018 06:36 AM
FS Brand New 2017 17" Wheels w/ Toyo Tires YellowRaven Toronto / Ottawa / Ontario 0 09-12-2017 09:31 AM
Fs ~ brand new toyo open country a/t tires - costa mesa - $650 Charles5Gen For Sale: Suspension/Wheels/Tires 7 01-29-2017 01:00 PM
Brand new LC cat Yoda85 For Sale: T4R Items 0 11-05-2012 09:47 PM
