05-15-2016, 11:15 PM
Not Happy With CH4x4 Switch, Should Have Gone with AOB
Installed my rear camera dongle today and thought I would save $8 by using the cheaper CH4x4 Toyota Small Push Series switch instead of paying $28 for an AOB Switch.
The switch looks very similar to the stock ones, but when you mount the switch in your trim panel until the clips grab, the travel of the switch gets blocked and push button no longer operates. I ended up having to wrap electrical tape around the housing and pressure fit the switch into the mounting hole and leave some of the housing sticking out. It seems to work as long as I don't push too hard, but the switch sticks out more than the others and looks odd.
[IMG] ~original[/IMG]
I will call CH4x4 tomorrow to see if they are aware of this issue.
2013 4Runner Limited | OPOR Sliders | BFG KO2 in 275/70R17 on TE Rims |Bilstein 6112/5160s and SAW 1.5" | Some RCI Aluminum Skids | SPOD | Gobi Stealth No-Rise | Aurora 40” and 6” Single Row LED Light Bars
05-15-2016, 11:26 PM
Real Name: Corey
Real Name: Corey
Same issue
2015 Trail Premium W/KDSS, Icon UCA,
King Shocks W/Remote Rez Front And Rear,OME Rear 2" Lift Springs, Spider Trax 1.25' Spacers,
285/70R17 BFG KO2, Toytec 1" Diff Drop, HID 6000k headlight upgrade, Ventshade window visors, Suntec front window tint, Waiting on Rock sliders, gobi stealth, Hilift jack
05-15-2016, 11:32 PM
Real Name: Halko
Real Name: Halko
Personally I have not found the quality of the AOB to be all that impressive. I have one that doesn't light up when activated, another that sticks, the other two are ok but occasionally stick as well.
2011 Silver LE, 3rd row, 285 GY Duratracs, Elka remote with adjusters/Icon Overland springs, SPC UCA's, RCI skids, Shrockworks step slider with OE Trail rockers, CBI rear bumper, Indel B fridge, SPOD, and more...
Build link:
http://www.toyota-4runner.org/5th-ge...el-thread.html
05-16-2016, 07:43 AM
Originally Posted by Saker
AOB is the best quality I have sourced so far.
I truly wish Toyota would make some switches we could use for our accessories.
If anyone has any info, that would be fantastic.
I have not used the ch4x4 switches so I cannot comment on them. I will say that I do not think the quality of the AOB switches is too great. I have three and all three of them I had to wrap with electrical tape because the casing will not stay together on its own.
I have tried to source higher quality switches but did not have any luck. I got two samples from China, one was complete shite and the other was pretty much the same as AOB. I'm headed to Japan in the summer, I am hoping to look for some items when I'm there, I'll add these switches to my list.
My Build Thread
www.AnytimeBackupCamera.com
2011 4Runner Trail loaded w/KDSS
1992 Land Cruiser
05-16-2016, 09:42 AM
I have issues with my AOB switches actually staying activated. It take a lot of pressure to get it to stay on instead of acting like a momentary switch. Maybe I got some from a bad batch.
2015 Magetic Grey Trail Edition w/ KDSS
Front: Toytec/Bilstein 5100 adjustable coilovers at 2.5". Rear: Bilstein 5100 with OME 895E rear coils.
ARB CKMA12 air compressor.
05-16-2016, 09:46 AM
I have no personal experience, but I recall members being satisfied with OTRATTW switches..
'12 LE
'19 ORP
05-16-2016, 10:58 AM
Wrap some electrical tape around the bottom where the wiring harness plugs in. I had the same issues with mine and this fixed it.
My Build Thread
1992 Land Cruiser
05-16-2016, 12:53 PM
Toyota buys OEM switches from somewhere. Maybe someone could find the supplier that makes them, and order more to the same specs?
2011 SR5 4WD, Maroon, no 3rd row, no sliding cargo tray.
ARB Bumper/Bullbar; Southern Style Offroad Sliders; Budbuilt Gastank Skid
OME Nitrocharger Sport Suspension (884 front, 895E rear); Gen Grabber ATX 275/70R/17
05-16-2016, 12:56 PM
Real Name: Will
Real Name: Will
Bollocks! I just put a CH4x4 switch in my Amazon cart while picking up parts to install a compressor.
Liquidmantis's modest [boring] build thread
2016 MGM TEP w/KDSS | OME BP-51 w/ 2889 rear | SSO Bumper | Warn Zeon 10-S Plat | TRD Pro wheels | BFG K02 275/70/17 | RCI sliders | RCI alu skids | Gobi Stealth No Rise | 1Up USA hitch rack
05-16-2016, 01:07 PM
the OTRATTW switches are decent, no issues with the 6 on my rig so far, but the are not even remotely close in style to the OEM toyota ones
2012 Magnetic Grey Metalic SR5 w/ upgrade pkg (Canada)
pretty much bone stock
Instagram: ab4runnin
05-16-2016, 07:10 PM
Real Name: Greg
Real Name: Greg
Hi Mr saker,
That's a really good question! I'll be willing to bet that, that's not the same size as the ones we order from AOB and slee off-road; even the switches that fit the FJC won't fit the 4Runner! ...and these cost almost double ($44) what we pay for AOB ($28) so what would be the incentive... "Just curious."
Rgds
2012 Limited (in bliz) Black leather interior.
Commercial hvac diagnostics/electrical specialist (Steamfitters Journeyman Local 475)
05-16-2016, 08:06 PM
Real Name: 3 guesses..........
Sounds like face plate isn't depressing internal switch far enough down to engage/disengage, got a little experience here
Had two Slee switches that did the same thing, fix is to "message" face plate. Notice tabs on back side of face plate (sorry for crappy pictures), while engaging and releasing switch you will see where they contact with switch housing, shaving they down 1/16" will allow switch to be depressed a little further for a better latch/unlatching.
and/or shave front edge of board only where face plate tabs come in contact. A razor knife makes quick work of it.
'12 SR5, Blizzard Pearl * Factory (style) Fog Light Switch-Fits knock-out! * 30" BD Stealth LED Light Bar, Upper Grill '12 SR5 * Reverse Light Mod-SR5 Factory Bumper * FN f(x) Pro Wheels - Custom Coating * LLumar Paint Protection/Tint, Flowmaster Cat-Back, Bilstein 6112/5160, LR UCA's, AirLift w/Load Control, 285/70/17 Nitto TG, LW's D2S 4.0 HID low beam mod, V-LED Interior/Reverse/LMZ High Beam/Turn Signals/V-6 DRL Lights (all 5000K), Kappa Dash/Doors/Hatch Speakers, CompuStar Remote Start, B&M Trans Cooler, Devil Horn Emblems, XB LED Fogs, Dongle Mod, TRD CAI, DC 270-XP Alt
