I installed the same combination in my 2013 TE...Warn Zeon 10-S and BudBuilt hidden mount. It was a tight fit and required relocating several components, but eventually worked. The winch control box must be relocated; I used the
Maner Mount from Tandem Off-Road to simplify the relocation. I also had to relocate one of the horns; I mounted it and the winch controller plug on the same bracket. The wireless controller is optional, not required. The power steering cooling line has to be bent out of the way or rerouted. I opted to replace it with this
power steering cooler kit from 4X4Labs; expensive, but made the install much cleaner. An AC line also had to be bent a little. I found the Warn synthetic line extremely difficult to attach to the drum and and there was insufficient room to hold the full 100 ft. I replaced it with
Master Pull 7/16 Superline XD.
