Old 05-22-2022, 01:32 PM #1
Something_Awesome's Avatar
Something_Awesome Something_Awesome is offline
Something_Awesome will become famous soon enough
Question about gear mounted on roof and wind noise.
I have a Pelican V730 (long cargo box) on the way as well as the LFD crossbar bundle that includes the wind fairing. My question is, how forward should the box be mounted so as to reduce wind noise? Should it be before the wind fairing? On the wind fairing? Just barely kissing the wind fairing? My guess is the third option. I'm asking because I plan to drill.
Here is a pic online for reference:
The guy in the referenced pic has the front of the box (the front being the right side of the picture) mounted just before the wind fairing, so there is space. I was the box would be better mounted more forward so that the box is just barely on top of the wind fairing (but it won't be forward it enough where I could bolt it on there. I think for sure the box should not pass over the fairing.
Thoughts?
Something_Awesome is offline   Reply With QuoteReply With Quote
Old 05-22-2022, 02:52 PM #2
Humble Leader's Avatar
Humble Leader is a glorious beacon of light Humble Leader is a glorious beacon of light Humble Leader is a glorious beacon of light Humble Leader is a glorious beacon of light Humble Leader is a glorious beacon of light
I have the LFD bars with faring and a pelican protector case on them. actually 2 pelican cases up there. they are on there almost all the time
I have it so that the front of the case is just behind the faring. there's a slight skew rearward but I wanted to fit them as centred as possible without being over the faring, makes it easy to access
at the end of the day you are putting a box on the roof, wind noise will not be zero, BUT I find if you put it within the width of the faring (so not over the side rails, if that makes sense) and behind the faring, wind noise is minimal. it's there but it's not obnoxious. and when I mean it's there, I mean I can hear it driving solo, through headwinds and crosswinds at 90+mph with no radio on. it's very slight and very reasonable, and that's with 2 cases mounted up there
Just IMO, I actually don't like how that pic is set up. its not possible to reach the bolts from the underside of the case when it's on the roof and tighten. IIRC that pic is from trail4r where the author of the article somehow was able to bolt from the inside of the case without requiring a wrench on the underside. I wouldn't be comfortable with this, even using carriage bolts. I have 4 studs per case mounted on the crossbars to allow for quick detachment of the case if I need the roof for other things. case goes on and off in less than a couple minutes, only need one wrench. I also reinforced the drilled mounting holes on the cases with an aluminum flat on the exterior of the case (1/8" thick) so the plastic case mounting holes don't get stretched or worn
if you want I can take some pictures. just lmk anything specific
Old 05-22-2022, 03:51 PM #3
Thanks for the info. And you are right about the 4Runner owner you identified. I will follow your advisement though on how to bolt the case on to the bars. Do you think you can provide a side profile pic of your vehicle to show how close the case is to the faring? It sounds like you have the case positioned right at the edge of the faring, right where the bar slopes downward toward the roof of the vehicle?
Old 05-22-2022, 04:00 PM #4
let me get some pics this afternoon. I'll get a couple pics from different angles and report back
Old 05-22-2022, 06:08 PM #5
her are some pics. from bottom to top this is how I secured:
m8 x 40mm bolt, m8 fender washer, crossbar, m8 fender washer, lock washer, nut, 1/8" aluminum flat attached to case, case plastic, EPDM washer, nut. when I remove the case I have the tops of the m8 bolts which I use those plastic screw covers to protect the threads
if the cases are perfectly centred the 1720s are about the exact length of the side rails. I had to slightly move to the rear so the front edge didn't pass over the back edge of the faring. this also doesn't cover the mounting slots in the faring in case I want to use them. if you get anything longer than the 1720 you will lose your slots in the front faring
Question about gear mounted on roof and wind noise.-case1-jpg  Question about gear mounted on roof and wind noise.-case2-jpg  Question about gear mounted on roof and wind noise.-case3-jpg
Old 05-22-2022, 10:02 PM #6
You are the man! I will probably go without the aluminum. In which case I think an m8 x 35mm bolt should do the trick. Though I will also have to take in to account our differences in box thickness.
I am starting to think I want to return my V730 for a Pelican 1720 in tan. Amazon has free returns. I will. I am thinking the slightly lower profile 1720 still has enough height for me.
Old 05-23-2022, 10:45 AM #7
I would recommend the 1720 or the larger 1750. there is good height in the 1720, I use the foam insert in the top in case I hit some big bumps and to keep things firm in there. if I start adding too much stuff up there I'll lose the foam to make more room
ya m8 35mm will be more than enough. I could have ran m8 35mm with the aluminum but that would have left zero threads exposed at the top. I like to keep 2-3 threads protruding past the nut as a matter of good practice
if you are going to do an easy on/off set up like I have think about reinforcing the bottom of the case. you could use some large 24mm fender washers over the nut before placing the case on instead of the aluminum. the aluminum reinforcement attached to the case is a bit overkill but I wanted to test it out. I also have a habit of using the side handles on the case to pull myself up to get to the roof. what you don't want is the case bending around the mount holes from it resting on just the bolts. the plastic is good quality and pretty thick but still I just wanted to be safe
Old 05-23-2022, 03:53 PM #8
USStrongman
Guest
Posts: n/a
USStrongman
Guest
Posts: n/a
My advice. Use a few tiedowns and test what position works best then decide what is the best for you. If you are by yourself most of the time the box will be up, my advice is to put it on the passenger side, not the middle. Reduces noise for you regularly. There is nothing to be gained mpg or anything else by putting it in the middle.
Old 05-24-2022, 11:23 AM #9
Good advice on the tie downs. Also, I planned to put it on the passenger side because I want the box’s wheels facing to the rear of the vehicle and for better weight distribution.
Old 05-24-2022, 01:33 PM #10
Captain Spalding's Avatar
Captain Spalding Captain Spalding is offline
Captain Spalding has a spectacular aura about Captain Spalding has a spectacular aura about
My memory is failing me. Isn’t there a company that makes aftermarket cross bars, that work with the stock roof rails, that are also slotted for T-nuts? That would make attaching boxes a lot easier.
Captain Spalding is offline   Reply With QuoteReply With Quote
Old 09-20-2022, 08:39 PM #11
sandbuster sandbuster is offline
sandbuster is on a distinguished road
That would be the LFDs...
sandbuster is offline   Reply With QuoteReply With Quote
Old 09-22-2022, 10:19 AM #12
I don't think so. at least not one of the more popular brands you hear about.
rago, victory, LFD, greenlane all have factory rail fitting crossbars but no t slot feature
Old 09-22-2022, 12:49 PM #13
TRD PANTHER's Avatar
TRD PANTHER TRD PANTHER is offline
Real Name: BLACK TRD PRO
TRD PANTHER has much to be proud of TRD PANTHER has much to be proud of TRD PANTHER has much to be proud of TRD PANTHER has much to be proud of TRD PANTHER has much to be proud of TRD PANTHER has much to be proud of TRD PANTHER has much to be proud of TRD PANTHER has much to be proud of
That would be: 4Runner Roof Rack | NiseRack.com
TRD PANTHER is offline   Reply With QuoteReply With Quote
Old 09-22-2022, 02:14 PM #14
auspilot auspilot is offline
auspilot is on a distinguished road
Originally Posted by TRD PANTHER View Post
Or these guys:
Extrusion Crossbar Mounts for Stock Racks
– Go Xplore Basecamp
2020 MGM TRDOR | Dobs IMS, other minor mods
auspilot is offline   Reply With QuoteReply With Quote
Old 09-22-2022, 06:15 PM #15
Originally Posted by auspilot View Post
Does the upper T-slots on these type of crossbars have drainage holes? Otherwise water and dirt can settle in them. I went with 4 wide LFD crossbars and fairing. No removal of the side rails and can be used with their longer 7/8 rack.
Question about gear mounted on roof and wind noise.-03ccb05a-ef8d-4627-b0f5-74a43e2f0a68-jpg
box , fairing , forward , mounted , wind
Wind noise w/ roof rack 08medic4x4 4th Gen T4Rs 10 06-25-2021 08:03 PM
Roof Rack Wind Noise Fix? itr1275 5th gen T4Rs 6 05-04-2020 12:17 AM
Do Ditch lights (A pillar mounted) create significant wind noise? rob_dixon General Discussions 5 06-22-2019 12:55 PM
Roof Rack vs Sunroof wind noise ? 05Rrunner 5th gen T4Rs 2 01-14-2016 08:01 PM
Sun roof wind deflector=noise reduction? bradym239 4th Gen T4Rs 6 06-29-2004 10:53 PM
