Old 05-30-2022, 12:23 PM #1
Enikad's Avatar
Enikad Enikad is offline
Enikad is on a distinguished road
Enikad's Avatar
Westcott Design Lift Front Only?
Greetings all. Interested in seeing if anyone has done just the front perch lift utilizing the westcott design lift for the fox suspension. I’ve seen some pics on their site but can’t determine if the pics was actually only the front or all 4.
I’m looking to just level up the front and thinking this route looks to be the most promising. PFA.
'22 Super "Betty" White TRD Pro
to the Raptor Light reppin', Heritage Grill Pro lookalikes!
Enikad is offline   Reply With QuoteReply With Quote
Old 05-30-2022, 09:01 PM #2
fkheath fkheath is offline
fkheath is a splendid one to behold fkheath is a splendid one to behold fkheath is a splendid one to behold fkheath is a splendid one to behold fkheath is a splendid one to behold fkheath is a splendid one to behold
You are right that the 4Runner is raked, i.e. the front is lower than the rear. Most lift kits raise the front more than the rear to level the vehicle. The difference is about 2" front to rear. Thus, it is OK to lift just the front a bit. I think the 4Runner looks better level.
I don't know about the Westcott lift; I have a different brand leveling kit.
fkheath is offline   Reply With QuoteReply With Quote
Old 05-31-2022, 08:22 PM #3
Enikad's Avatar
Enikad's Avatar
Can I see your setup? I would think how yours is leveled would be similar to what I’m looking for.
Old 06-01-2022, 10:37 PM #4
I have the Rough Country leveling kit which is a spacer on the top of the front strut (strut is same length and shock travel is the same as OEM) and spacer on the top of the rear springs. Advertised lift was 2.5" front and 1" rear, but I ended up with about 3" front.
Old 06-02-2022, 03:31 PM #5
MGordo MGordo is offline
MGordo has a spectacular aura about MGordo has a spectacular aura about
Front only would be close to reverse rake, especially if you used the bottom and top piece.
Below is my 2020 with bottom Westcott and Eibach 1" rear coils. (Keep in mind bike rack and loaded roof box as well)
Westcott Design Lift Front Only?-4runner-inv-2-jpg
MGordo is offline   Reply With QuoteReply With Quote
Old 06-03-2022, 07:57 AM #6
Enikad's Avatar
Enikad's Avatar
Picture isn’t loading
Old 06-03-2022, 07:57 PM #7
rdruss's Avatar
rdruss rdruss is offline
Real Name: Ron
rdruss's Avatar
Real Name: Ron
Half inch front spacer should be all you need, will raise front about 1".
2003 Limited, V8, AWD. 4600 Bils/FJ springs, 1/2" spacer, SPC UCA, Super Pro bushings in front LCA and in all rear control arms, Michelin 265/65R17 LTX/Defenders, stock wheels with homemade center caps, Stop Tech slotted rotors w/Posi Quiet pads all around.
Old 10-14-2022, 12:44 PM #8
Southpaw07 Southpaw07 is offline
Southpaw07 is on a distinguished road
Wanted to revisit this thread since some time has passed by.
Anyone else run this front-only lift? I have a 2019 TRD Pro with the Fox shocks and I’m also looking to raise the front a little bit for a slightly more aggressive look.
Any input and/or photos appreciated
Southpaw07 is offline   Reply With QuoteReply With Quote
Old 10-18-2022, 01:02 AM #9
WillardKC WillardKC is offline
WillardKC is on a distinguished road
Did the front and rear (22 Pro) but started the install with the front. Didn't look too bad, the worse part was that it made the stock 265 tires look small.
WillardKC is offline   Reply With QuoteReply With Quote
Old 10-18-2022, 09:56 PM #10
Yeah, I was also thinking it would make stock tire sizes look small. I wonder if it will clear 285's now?
Old 10-21-2022, 05:50 AM #11
Clears my 285/70 BKG KO2 w/ little trimming on bumper and removing front mud flaps.
Old 10-22-2022, 08:13 PM #12
achtung6 achtung6 is offline
achtung6 is on a distinguished road
Buy the full Wescott lift. The truck looks awesome and the cost of the full kit is only a bit more than the front lift only.
Westcott Design Lift Front Only?-img_1757-jpeg  Westcott Design Lift Front Only?-img_1733-jpeg
achtung6 is offline   Reply With QuoteReply With Quote
design , front , lift , pics , westcott
Lift Kit - TRD Pro by Westcott Designs V2009 5th gen T4Rs 33 04-03-2023 08:07 AM
Pro Lift - Westcott Front & Eibach Rear? Xanderzuk88 5th gen T4Rs 17 10-21-2022 12:14 PM
Lift Kit - Factory Fox TRD Pro by Westcott Designs Maka15 5th gen T4Rs 78 12-06-2021 05:57 PM
Westcott Designs vs Eibach lift kit for trd pro alpaka5 5th gen T4Rs 11 10-27-2020 08:43 PM
Help me design a good lift masphx 4th Gen T4Rs 16 02-27-2017 04:10 AM
