Old 07-12-2022, 12:54 PM #46
Bmnorm2 Bmnorm2 is offline
Bmnorm2 has a spectacular aura about Bmnorm2 has a spectacular aura about
Originally Posted by stiles_s View Post
Yep, same. I think it's a combination of how lazy our engines are below 3k and the large gaps in gears. You go from "a little more power please" to "downshift, noise, revs"). I just want to be able to make it up a small hill without downshifting on the highway. I have zero issues w/the HP the engine makes up high. In fact it's fairly rapid.
Looks like the Magnusson does make a bit of power down low but I was paying pretty close attention to the graphs and the promised 30% gain appears to be from 3-3.5k and up. It's worth noting the quote above that peak torque is at 4400 RPM. Again, this sounds like a sports-car/sedan (from 10 years ago before turbos) and not a truck.
Love, love that this is available. Just not 100% that this is for me. Anyone do an engine/tranny swap out of a GX460?
While I understand where your thought process is coming from - this idea that truck engines must make peak torque at super low RPMs is based on very very very old technology. This is from a time before VVT when you sized the camshaft the make peak torque at a very low RPM and then the engine runs out of breath shorty after and often makes less horsepower than torque because it doesn't even get to 5252 RPM.
Modern naturally aspirated gasoline TRUCK engines all make peak torque in the ~4k RPM range....
Chevy 5.3L V8 TRUCK engine - Peak torque @ 4,400 RPM
Ram 5.7L V8 TRUCK engine -
2003 - 2008 Ram 1500/2500/3500 - 375 lb-ft @ 4,400 rpm
2009 - 2012 Ram 1500 - 407 lb-ft @ 4,000 rpm
2009 - current Ram 2500/3500 - 400 lb-ft @ 4,000 rpm
2013 - current Ram 1500 - 410 lb-ft @ 3,950 rpm
Ford 5.0L v8 TRUCK engine
2011 to 2014 Ford F-150 - 380 lb-ft @ 4,250 rpm
2015 - 2017 Ford F-150 - 387 lb-ft @ 3,850 rpm
2018+ Ford F-150 - 400 lb-ft @ 4,500 rpm
With VVT, DOHC, 4 valves per cylinder (All breathing mods) - these engines may not produce peak torque till ~4k RPM, BUT they make 80% of that peak torque through a majority of the curve. It's not like you have some massive jump in torque across the speed range (VTEC just kicked in bruh!)
Regarding the Magnusson supercharger - It does make additional torque in the ~2k RPM range. Unfortunately, I am having a hard time finding a dyno plot that starts lower than ~3k RPM and doesn't include the "load-up". Some dyno plots show the load up from not full load to full load which includes the engine changing timing and Cam Phase as well as the supercharger closing the bypass valve.
Looking at Tacomas with the M90 (different SC but similar flow) and our engine I am seeing ~2.5 psi boost @ 2k RPM and full ~6 psi boost @ 3.5k-4k RPM to redline. I am also seeing ~15% increase in torque at 2k RPM. As the testimony from several members who have the SC shows - this increase in torque (even if only ~30 ft-lbs) @ 2k RPM is providing enough to prevent the miserable 5th to 4th downshift at highway speeds when entering a grade.
Bmnorm2 is offline   Reply With QuoteReply With Quote
Old 07-12-2022, 03:00 PM #47
Battle Born Offroad Battle Born Offroad is offline
Official Vendor
Battle Born Offroad has a spectacular aura about Battle Born Offroad has a spectacular aura about Battle Born Offroad has a spectacular aura about
Official Vendor
Originally Posted by Crob42 View Post
Would this void the factory warranty?
No, not automatically. I would suggest speaking with your local dealership. Remember, if installed by an ASE certified mechanic, you get a 3yr/36000 mile warranty from Magnuson
Warranty – Magnuson Superchargers
From Magnuson "Most Toyota dealerships are very familiar with Magnuson as we were the Manufacturer of the Toyota TRD Supercharger therefore, they usually are good with warranties and installing as well."
BATTLE BORN OFFROAD
Las Vegas, NV | 702.333.0868
The Offroad Part Source
Battle Born Offroad is offline   Reply With QuoteReply With Quote
Old 07-12-2022, 03:02 PM #48
Official Vendor
Official Vendor
Originally Posted by TrailRunnin14 View Post
There is no more downshifting when encountering inclines that used to require a downshift from the transmission. Itís a much better driving experience with the supercharger. I would say I am pretty easy on my 4Runner and there is a big difference in just regular day to day driving.
Thank you for your review. Does your truck have the stock gear ratio as well?
BATTLE BORN OFFROAD
Old 07-12-2022, 11:33 PM #49
TrailRunnin14's Avatar
TrailRunnin14 TrailRunnin14 is online now
TrailRunnin14 has a spectacular aura about TrailRunnin14 has a spectacular aura about
Yes, Iím running 285/70/17 ATKO2 c load with stock gearing.
TrailRunnin14 is online now   Reply With QuoteReply With Quote
Old 07-13-2022, 05:11 PM #50
stratoman stratoman is offline
stratoman is on a distinguished road
It is now available for purchase thru 2022 models. Tuning is good to go, and Mag is making slightly more than 335hp and 345lb-ft at the crank. With a few supporting mods, you can boost that even higher.
CARB approval is pending for the new year ranges, but should be approved by end of summer.
Magnuson 2010-22 Toyota 4Runner / FJ Cruiser Supercharger System PN 01-13-40-021-BL
I'm waiting for my Lime Rush PRO and was also waiting for Magnuson to release this SC. Now Waiting to hear from accessory manager to make this happen.
stratoman is offline   Reply With QuoteReply With Quote
Old 07-13-2022, 09:50 PM #51
fistfulofgravy fistfulofgravy is offline
fistfulofgravy is on a distinguished road
Anyone have a dyno chart at high elevation? 5k ft+? I'm moving to 7k next month and dreading the power loss. Also don't want to spend the money on the SC and find out it only gets me back to stock sea-level performance.
2016 TEP, MGM
6112/5160 Bilstein lift + Dobinsons T13 rear springs | 2"F/1.5"R
SCS Ray 10 Matte Dark Bronze / 17x8.5 4.30" | 285/70/17 BFG KO2
FrontRunner 3/4 Slimline, ARB 2M awning, White Knuckle Off Road sliders
fistfulofgravy is offline   Reply With QuoteReply With Quote
Old 07-14-2022, 11:57 AM #52
lewdog998's Avatar
lewdog998 lewdog998 is offline
lewdog998 is a glorious beacon of light lewdog998 is a glorious beacon of light lewdog998 is a glorious beacon of light lewdog998 is a glorious beacon of light lewdog998 is a glorious beacon of light lewdog998 is a glorious beacon of light
lewdog998's Avatar
This is not a direct answer, but consider this....
A sup moves a fixed volume of air at a given rpm regardless of the density of the air....so you will have same volume of LESS dense air at altitude. Only fix is to spin it faster with a smaller pulley or increase engine rpm (which is not really an option).
this article talks about exactly what you are asking, i cant vouch for accuracy, but its on the internet, so it must be true
https://www.5250performance.com/blog...-5000-altitude
2020 TRD Pro in Super White
RCI full alum skids - C4 Fab sliders-Diff breather mod-Upper grill hidden light bar- Auxbeam switch panel- DD reverse / turn light LED mod - Front Runner 3/4 Rack - 285/70 Dura tracs - Maxi Trac onboard air - Eibach TRD Pro lift springs - Front Runner 3/4 rack - Hefty Fabworks Lo-pro bumper - Warn VR Evo 12S. Dirt King UCAs
Man is born free, yet he is everywhere in chains....
lewdog998 is offline   Reply With QuoteReply With Quote
Old 07-14-2022, 12:12 PM #53
Makes sense. Thanks for digging up and sharing that link. Decisions, decisions!
2016 TEP, MGM
Old 07-14-2022, 12:55 PM #54
lewdog998's Avatar
lewdog998's Avatar
I am debating the same..... while altitude is not really an issue here in TN, I am trying to justify spending that much to make a slow vehicle...less slow. lol
Yes the highway gear hunting on grades is annoying and I often dont use cruise for that reason.
Old 07-18-2022, 08:08 PM #55
Official Vendor
Official Vendor
Weve had some customers do 4.56 or 4.88s with the same tire size and its like adding a second supercharger. Really rips! Glad to here that you have such good results in driveability with just the blower upgrade.
BATTLE BORN OFFROAD
Old 07-18-2022, 08:10 PM #56
Official Vendor
Official Vendor
Update - we have secured the first run of these blowers for the 20+ 4Runners. They are expected the second week of August. As of right now we have 2 more that are uncalled for!
Feel free to call us if youd like to put your name on one 702-333-0868!
BATTLE BORN OFFROAD
Old 08-05-2022, 09:27 PM #57
Daluvian Daluvian is offline
Daluvian is on a distinguished road
MAGNUSON 2020-22 Toyota 4Runner Supercharger System! Coming VERY Soon!-40ab0c18-70b8-404b-9969-ec65cdd42607-jpg
Daluvian is offline   Reply With QuoteReply With Quote
Old 08-05-2022, 10:47 PM #58
jdm-v35 jdm-v35 is offline
jdm-v35 has a spectacular aura about jdm-v35 has a spectacular aura about
I live at 6500ft and have taken this thing up to 12000ft. I would say if you have the money "to spare" it is a great upgrade. If you will be pinching pennies to afford this it is not worth it. You will pay less in extra gas than in the upgrade. even with the supercharger, with my RTT and fully loaded I got 13.5mpg between CO and UT.
Would I personally do it again? Yes, but the net worth is relative to if you see the price as worth it or not.
jdm-v35 is offline   Reply With QuoteReply With Quote
Old 09-20-2022, 03:20 PM #59
Official Vendor
Official Vendor
Thank you all for the continued orders! We are installing two more this week. If anyone would like to get on of these for themselves, or if you have questions regarding the Supercharger or install, dont hesitate to reach out to us at Info@battlebornoffroad.net. We are the #1 Toyota Magnuson installer!
BATTLE BORN OFFROAD
Old 09-21-2022, 12:23 AM #60
TDotCord TDotCord is offline
Real Name: Ian
TDotCord is on a distinguished road
Real Name: Ian
Does anyone know if the Magnuson kit will play nice with the an S&B intake installed with the Magnuson canned tune? Of course officially says their tune is for the stock motor. Just curious whether anyone has experience with this potential setup.
TDotCord is offline   Reply With QuoteReply With Quote
4runner , high , power , supercharger , system
Magnuson Supercharger JailbreakOverlandr General Discussions 19 03-22-2022 07:04 PM
help with Magnuson Supercharger clarkyclark87 5th gen T4Rs 9 05-21-2021 11:28 PM
Magnuson Supercharger on 2020 4Runner Questions TeaMan 5th gen T4Rs 18 10-30-2020 07:55 AM
