Old 06-04-2022, 11:32 PM #1
jmp55 jmp55 is offline
jmp55 is on a distinguished road
Wet rear brake caliper
This is for my 2014 GX460, but I believe GX and 4Runner share same brake components so posting here for help.
I just found out the rear brake calipers (both sides, a little worse on left side) are wet and possibly leaking brake fluid. But I haven't yet had a low brake fluid and it still brakes fine.
First thought it might be from rain or carwash, but it hasn't rained here for last 5 days and I haven't taken it to carwash in the last week either.
It must be from brake caliper, right? Is it from the bleeder valve?
I looked at the piston but piston seal seems fine, it's dry there. But around the edge of rotor, splash shield, even the front of the caliper is wet.
Do I need a new caliper?
Thanks for your help!
Wet rear brake caliper-20220604_211218_2-jpg  Wet rear brake caliper-20220604_211010_2-jpg
2009 Black T4R Sport Edition V6 4x4
jmp55 is offline   Reply With QuoteReply With Quote
Old 06-05-2022, 06:57 AM #2
Greydog's Avatar
Greydog Greydog is offline
Greydog is on a distinguished road
Greydog's Avatar
Looks like either brake fluid or the axle seal is leaking gear oil. Does it have a strong smell? If so it’s gear oil.
Can you put a wrench on the bleeder valves and gently snug those up?
2019 TRD OffRoad - Fox w/Resi, 650lb Springs, JBA HD UCA, T12 Rear Springs w/DS 5mm Spacer, Odyssey 34R-PC1500T AGM w/Diode Upgrade and CTEK Monitor, NOCO battery charger wired to external port for shore power, Rago Hidden Winch Plate, Comeup Seal 9.5 RSI, RCI Sliders/ Skids, 285/70-17 Cooper AT3 XLT on Fuel Rims, Various LED upgrades, OE Engine Heater w/External Port, XenonDepot Low Beam HID & LED 3k Fogs, ScanGauge, Midland GMRS, Accessory Mount for iPad, mike and Inreach, iKamper Mini 3.0, Custom Kitchen/Cargo system, ARB 50Q, Goose Gear dual drawer, Wilco Solo Tire/Hilift/RotoPax Carrier.
Greydog is offline   Reply With QuoteReply With Quote
Old 06-05-2022, 01:01 PM #3
BlackWorksInc's Avatar
BlackWorksInc BlackWorksInc is offline
BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold
Talking
Easiest way to to tell will be to take the caliper off and inspect it more completely. While you have the caliper off, go ahead and pull the rear rotor off. My suspicion is that you're looking at an axle seal leak; usually the backing plate and the bearing housing (between the brake backing plate and axle flange) shows signs of seepage. But it does look more like an axle seal.
If it is an axle seal leak, I highly recommend replacing the bearing as well.The reason being the axle seal keeps fluid in the axle tube/axle assembly, when they leak it let's gear oil wash through the bearing on its way out to leaking over the parking brake assembly.
BlackWorksInc is offline   Reply With QuoteReply With Quote
Old 06-05-2022, 02:50 PM #4
flyrv9's Avatar
flyrv9 flyrv9 is offline
flyrv9's Avatar
Checking both brake fluid level (at the reservoir under the hood) and the rear diff fluid level at the rear diff fill port should yield more info. Have car on level ground when checking. I agree that it looks like an axel seal issue; and diff gear lube fluid has a real distinct smell, so it should be easy to tell which is the culprit.
Old 06-05-2022, 11:03 PM #5
TrailRunnin14's Avatar
TrailRunnin14 TrailRunnin14 is offline
TrailRunnin14 has a spectacular aura about TrailRunnin14 has a spectacular aura about
I had similar situation but not as bad. Turned out it was the outer rear axle seal. Replaced bearing, outer and inner seal. Mine was only on the driver side. If your not low on brake fluid, I’d check your rear axle.
TrailRunnin14 is offline   Reply With QuoteReply With Quote
Old 06-06-2022, 01:18 PM #6
flyrv9's Avatar
flyrv9's Avatar
As I remember, rear axel seals / bearings are normally replaced in pairs.
Old 06-07-2022, 03:23 PM #7
Thank you everybody for pointing out the possibility of rear axle seal leak. I did not think of that. And as I do more research on that issue, it's a telltale sign of axle seal leak, and to confirm, I can smell it!
Now I kind of wish it was brake caliper - that's much easier issue.
Looks like I am looking at new axle seal, wheel bearing, parking brake shoes, and rear brake pads.
I've done front wheel bearing replacement but not the rear one.
Few more questions:
Do I need to drain rear differential fluid to replace rear axle seal? It's been only about a year since I changed that.
Has anybody had a good luck with bringing in the axle to independent shop (or a dealer) to press out the old bearing assembly and press in the new one? I can order and get all the required parts, but looks like special tool is required and at least a 20 ton press. Not sure if independent shop will have that special tool.
Thanks.
Old 06-07-2022, 11:07 PM #8
harper7's Avatar
harper7 harper7 is offline
Real Name: Gary
harper7 has a spectacular aura about harper7 has a spectacular aura about
harper7's Avatar
Real Name: Gary
Few more questions:
Thanks.
You didn't say how many miles are on the GX. Rare for both sides to be leaking at the same time ,your breather could be rusted shut. Never seen both sides go at the same time. Yes , diff fluid needs drained to change seals.
I never replaced a 5th gen bearing/seal but replaced several on high mileage 3rd gen 4Runners and 1st gen Tacomas .
The hard part of replacing the bearings is to find somebody who knows what they are doing as it takes a special tool to take the abs tone ring and seal land off as they are pressed on.Axle Bearing Puller Set for 95-20 Toyota 4Runner With Tone Ring Tool Installer | eBay
Friend of mine took his to a shop years ago and they cut them off. They screwed it up and beat the seal land on too far and it leaked again. When we took it apart to see what the deal is ,they had big cut marks in the axle from a cut off wheel.
2022 4Runner TRD ORP Army Green
2010 4Runner Limited -SOLDhttp://www.toyota-4runner.org/galler...m-harper7.html
............Rest in Peace Seattle Mike................
2000 Black 4Runner Highlander Edition
2001 Tacoma TRD 5sp
harper7 is offline   Reply With QuoteReply With Quote
Old 06-07-2022, 11:26 PM #9
The 4th and 5th gen axles are a bit easier than the 3rd gens, but you do want that SST as it makes life easy.
You might be able to get away with just washing off the parking brake shoes and inside of the rotor, followed by a bit of roughing up with coarse sandpaper. It all depends on how soaked in gear oil they are. Same with the brake pads, if they've been soaking in gear oil, probably best to replace them and cut the rotor. If they haven't really been that heavily contaminated you might be able to re-use them.
Some shops and/or dealers will press out and press in the new bearing for you. Always worth asking what they charge for that.
Old 06-08-2022, 08:44 AM #10
RobS10's Avatar
RobS10 RobS10 is offline
RobS10 has a spectacular aura about RobS10 has a spectacular aura about
RobS10's Avatar
We have been through the leaking rear axle seal shenanigans on our '99SR5 twice .
2022 Barcelona Red TRD ORP, KDSS, Moonroof
1999 4Runner SR5, bone stock, just turned over 200K
RobS10 is offline   Reply With QuoteReply With Quote
Old 06-08-2022, 09:47 AM #11
Only a little over 90K miles on the GX. I was surprised to find out both sides of the seal fail like that. My 09 4Runner has more than 160K miles and never had problem with the seal.
Good point on the breather, I haven't checked that yet. Might explain the reason why the seals had premature failure. Will report back once I get a chance to take a look at it.
I'll have to call around to find a dealer or a shop who knows what they are doing. I placed orders for all the parts I think I will need yesterday, including bearing, bearing retainer, parking brake shoes, and rear brake pads. A lot of money, but hopefully I won't need to touch the rearend for a long time.
brake , caliper , fluid , piston , wet
rear brake caliper stripped threads IK13 4th Gen T4Rs 13 01-03-2018 02:51 AM
rear brake caliper frozen? brettmc 4th Gen T4Rs 15 02-25-2016 12:35 AM
This rear brake caliper leaking? shahsmerdis 4th Gen T4Rs 8 10-03-2015 06:24 PM
Brake caliper question - which caliper mfg doesn't lock up? bergs 4th Gen T4Rs 6 03-14-2015 09:18 PM
Rear, not front, Brake Caliper issues Dylan 4th Gen T4Rs 18 09-04-2014 12:23 AM
