06-06-2022, 09:24 AM
How often do you change YOUR oil??
2022 Barcelona Red TRD ORP, KDSS, Moonroof
1999 4Runner SR5, bone stock, just turned over 200K
06-06-2022, 11:05 AM
Currently, my 2011 Trail is driven about 5000 miles/year and oil is changed at 12 months and the filter every two years. Oil was changed at 10k when the vehicle was newer. No discernable oil consumption. I follow Car Car Nut advice except that I've been using 5W-30 for the last 3 years.
06-06-2022, 11:45 AM
10K miles, which has been about 4x a year,
06-06-2022, 12:32 PM
every 10000 miles now or every 2 years. it does not get driven that much now.
Originally Posted by RobS10
06-06-2022, 12:45 PM
10,000 miles. I just follow the maintenance guidelines. Lots of 500,000 Toyotas out there. Not trying to change that. Also oil has come a LONG way.
06-06-2022, 01:07 PM
Oil change every 5k since I fall under the special/heavy operating conditions.
2016 Limited 4WD Blizzard Pearl | Black
TRD Pro Sema | Toyo AT3 LT285/70/R17 C
Dobinsons IMS 302/700 and 505/705 | SPC UCAs | Durobumps
Victory4x4 Rack, BajaRack Ladder, Full RCI Skids & Sliders
CaliRaisedLED Ditch Lights & Light Bar
06-06-2022, 01:42 PM
5K miles. That's as long as I'll go on oil on any of my vehicles.
06-06-2022, 02:13 PM
whenever is sours and starts to taste bitter.
06-06-2022, 02:19 PM
1k any more you risk long term issues
06-06-2022, 02:23 PM
5K.
Oil change, filter, lube chassis, rotate tires. Usually replace air filter too.
06-06-2022, 02:32 PM
10k...about 1 time a year in the spring.
06-06-2022, 02:56 PM
Every 5k or so right now on our 2 year old 4Runner. I need to do a used oil analysis to see how quickly the 0W-20 falls out of grade. That's my primary gauge on how often to change oil. My guess is the data will tell me around 5k to 6K miles.
10K with changes is too long in my opinion. Toyotas have historically had sludge issues with extended oil changes. The 6.6 QT capacity of the 4.0L V6 might help fight this issue though.
I do find it funny that Toyota says every 10K miles so as long as they're paying the bill with the first two free changes, but then wants you back every 5k miles once out of free maintenance.
06-06-2022, 03:01 PM
Oil, grease and rotate tires every 5k.
Dealer has been doing the "free" one every 10, but I always double check their work (even lug nut torque) and do one oil change myself in between theirs.
2020 TRD Pro in Super White
RCI full alum skids - C4 Fab sliders-Diff breather mod-Upper grill hidden light bar- Auxbeam switch panel- DD reverse / turn light LED mod - Front Runner 3/4 Rack - 285/70 Dura tracs - Maxi Trac onboard air - Eibach TRD Pro lift springs - Front Runner 3/4 rack - Hefty Fabworks Lo-pro bumper - Warn VR Evo 12S. Dirt King UCAs
Man is born free, yet he is everywhere in chains....
06-06-2022, 03:09 PM
Originally Posted by patkelly4370
5K.
Same, this is my schedule.
06-06-2022, 06:22 PM
We have a '99 SR5 we've owned since 2004, now crossed over the 200K mark. We've changed oil every 3K as it sees mostly City driving, amounts to twice a year with the number of miles we drive annually. Doesn't burn a drop of oil. I was actually pretty surprised to see our new 4Runner's maintenance schedule say every 10K, and decided that since we want to keep this vehicle for the foreseeable future, we just couldn't quite go with that and sleep at night, especially after seeing that video about newer cars being more prone to burning oil. I assume this takes into account all the synthetic out there...it's not that the oil is breaking down as much as gets dirty from combustion.
