I am wanting to clean up some wiring and plan for the future, but I am having trouble finding, if it even exists, a relay box capable of holding 6 Bosch style relays, fed from one constant 12v power supply. I was going to use a blue sea block to organize and power low amp switches. Still need something to organize any relays.
If you're looking for something with a common bus for both +12v and ground, that might be tough. You could brew your own common feed but keep in mind the need to fuse for safety. 6 relays could potentially be 120-180 amps so not something to trifle with.
__________________ '20 Army Green 4Runner TRD PRO '16 Quicksand Tundra TRD PRO Gone '08 Salsa Red Pearl 4x4Runner SE V6: Gone
Yeah, I looked at that and it was the leader so far. Just didn’t know if a box existed with the fuse to relay already wired. Makes sense that they wouldn’t pre wire it in case you wanted a mix of constant and ign.
