06-06-2022, 05:43 PM
#1
Junior Member
Junior Member
$10K KDSS Repair!!
Hi all, Our local Toyota dealer quoted me $10,000 to fix the KDSS system on my 2010 4R Trail, with 220K miles. The KDSS light comes on now and then, and they said it was very rusty (salty upper Midwest roads) and leaking slightly from the unit. The $10K is to replace the unit and all four lines. Does this sound right to you? Many thanks for sharing your insights!!
06-06-2022, 05:49 PM
#2
Elite Member
Real Name: Danny
Elite Member
Real Name: Danny
Is insurance claim an option?
__________________
2010 LE > TE Conversion, Fox 2.5 DSC Front W/ Camburg BJ UCA's Fox 2.5 Resi rear W/ Icons. Method 701's, Cooper S/T Maxx 285/70/17. Shrockworks sliders. LLama Tales
Dual Battery Thread
06-06-2022, 06:02 PM
#3
Senior Member
Senior Member
source your own used parts and replace whats failed. thats ridiculous.
__________________
2016 TE : Grocery Getter, 34/10.5R17 Toyo at3, Prinsu Rack, King Coilovers, DuroBumps, ToyTec HD 2.0 springs, King shocks, King hydro bumps, Total Chaos mounts, DirtKing Fabrication UCA, VIVID RACING Tune, URD Y pipe, RCI skids, Marlin Crawler gussets, DRKDSS everything
06-06-2022, 06:11 PM
#4
Member
Member
Good to know there’s a warning light for KdSS! Thx!
06-06-2022, 06:15 PM
#5
Member
Member
I've heard of expensive KDSS repairs, but that is ridiculous. My guess is that dealership doesn't have the equipment to perform the work. If it completely fails, it would be a great time to install an aftermarket setup.
06-06-2022, 06:20 PM
#6
Senior Member
Real Name: Ron
Senior Member
Real Name: Ron
Yep, those high tech systems are great (I guess) when they work, but when they don't it's often way too expensive for most of us to have pay to get it working right again. Can it be removed/replaced with normal sway bar system like Xreas can with normal shocks?
__________________
2003 Limited, V8, AWD. K&N, Dobinson IMS/FJ springs,, SPC UCA, Super Pro bushings in front LCA and in all rear control arms, Michelin 265/65R17 LTX/Defenders, stock wheels with homemade center caps, Stop Tech slotted rotors w/Posi Quiet pads all around, spare tire relocated to inside cargo area.
06-06-2022, 06:14 PM
#7
Member
Member
For that age of vehicle and that quoted cost of repair, I'd just pull the connector and turn off KDSS. That said, it'd be worth getting a quote from a non-dealer repair shop.
06-06-2022, 07:15 PM
#8
Member
Real Name: Brandon
Member
Real Name: Brandon
Reach out to Dr. KDSS and get his take on your situation.
Sent from my SM-F711U1 using Tapatalk
__________________
2016 Toyota 4Runner TEP + KDSS + RC
1971 Volvo 142e (Lovely brick with a tractor engine)
1977 International Scout II (Another brick tractor)
06-06-2022, 08:59 PM
#9
Member
Member
I second dr.KDSS, Dom is super passionate about what he does and is a super cool dude
06-06-2022, 09:12 PM
#10
Member
Member
Quote:
are you running stock suspension?
another option is to take out the kdss system and upgrade your spring coils to a heavier weighted version to negate the loss of the sway bar.
this is my plan once my system fails.
or like others have stated, just replace the parts that need to be replaced.
__________________
i got the stuff
06-06-2022, 09:31 PM
#11
Member
Member
Second this.
Also, take it to a Lexus dealer and see what they say. They see KDSS on every LC and GX, so they likely have more experience with the system.
06-06-2022, 11:17 PM
#12
Senior Member
Senior Member
x4 reach out to dom aka DR.Kdss. this isnt voodoo, its just a hydraulic system, and he's repaired them.
you can unplug the white connector under the dash by the gas pedal area and the kdss light will always be on ;)
__________________
06-06-2022, 11:21 PM
#13
Member
Member
yeah, with the stock suspension, kdss vs no kdss was night and day. After upgrading the suspension, the difference is lot less noticeable. If you're running a stock suspension, can just spend the money on a new suspension and just unplug the kdss wire by the module.
06-07-2022, 12:18 AM
#14
Senior Member
Senior Member
KDSS is definitely off the list of options on the next 4Runner.
06-07-2022, 12:37 AM
#15
Member
Member
Quote:
We really like our Kdss. OP has 220k miles in the rust belt. Probably not many of the competition vehicles from 2010 still on the road in high salt use areas.
__________________
2018 Offroad Premium w/KDSS
1993 Jeep YJ w/stuff
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is On
