Old 06-09-2022, 09:01 AM #1
Jrunr Jrunr is offline
Jrunr will become famous soon enough
Question Adding Scene/Chase lights to Gobi Rack
Does anyone know the best way to add scene/area/chase lights to the sides and back of the Gobi Stealth rack? I want to add a couple sets of Baja Designs S2 or Diode Dynamics SS2 lights for camping area illumination and chase lights.
I am open to suggestions and recommendations on how to get this accomplished.
Thank you in advance.
2021 TRD Pro, MGM
Jrunr is offline   Reply With QuoteReply With Quote
Old 06-09-2022, 09:59 AM #2
codyHTX's Avatar
codyHTX codyHTX is offline
codyHTX is a glorious beacon of light codyHTX is a glorious beacon of light codyHTX is a glorious beacon of light codyHTX is a glorious beacon of light codyHTX is a glorious beacon of light
codyHTX's Avatar
@Jrunr here's what I am using:
Amazon.com: GS Power Tube Clamp Brackets (Choice 1/1.25/1.75/2 inch) Mount LED Light Bar Radio Whip Antenna Safety Flag on Rack Roll Cage Bumper Compatible with Can-Am RZR Rhino Teryx ATV UTV (2 pc) : Automotive
Adding Scene/Chase lights to Gobi Rack-side1-jpg  Adding Scene/Chase lights to Gobi Rack-side2-jpg
2015 Trail Premium
SCS/BFG, King/Dobinsons/JBA, Icon/Sonoran Steel, Hefty Fabworks, Shrockworks, RCI, XD HID, Gobi, FJ Toyman, GZila, Dog-Proofed
codyHTX is offline   Reply With QuoteReply With Quote
Old 06-09-2022, 10:51 AM #3
Awesome. Thank you. Can I ask how you ran your wires for those?
Thanks again!
2021 TRD Pro, MGM
Old 06-09-2022, 11:12 AM #4
JPOVS's Avatar
JPOVS JPOVS is offline
JPOVS will become famous soon enough
JPOVS's Avatar
When I had my Gobi installed I ran one of the horizontal bolts for the front mounting feet bracket through the s2 mount. I had to open up the hole on the s2 bracket more to fit the lag bolt, but it worked perfectly. Fit below my ARB awning too. Best part is with a plastic washer in between I was able to rotate the s2 bracket and have the lights not only shine up or down but forward and backwards. No need for ditch lights then either.
Adding Scene/Chase lights to Gobi Rack-light-jpg
2016 TEP, Elka 2.5 RR Adj F&R, Chaos UCA & LCA, OME 899, KO2 285/70E, Wheeler F&R Bumps, BMC, Spindle Gussets, Cam Tabs, Nitro 4.88 Gearing, Tranny Cooler, Hefty Fab F&R Bumpers Dual w/ ladder, Warn Plat 12s, Icon Pan & Billet Rear Links, OCD Links, GFC RTT, RCI Sliders, Every RCI Skid Plate (In Alum if avail), SCS Stealth 6 Rims, ARB Twin Comp, ARB 2500 Awn, Quick Pitch Shower Awn, Compustar T11 & RMS, Dual 42" drawers W/ Adj sleep/dog height platform (2nd Row Removed) Switch Pros, Baja LP9's, Squadron & S2 Pros, Rock Lights, Dometic CFX3 35qt.
JPOVS is offline   Reply With QuoteReply With Quote
Old 06-09-2022, 11:55 AM #5
codyHTX's Avatar
codyHTX's Avatar
Thanks again!
in a mesh loom, zip tied under the rack across to passenger side, combined with loom for passenger side light, zip tied under the rack forward to the windshield, down the windshield weather stripping, through the cowl and back across to an SPOD (drivers side windshield was already in use so had to go across and back through the engine compartment)
similar to @JPOVS cool idea, this low/upside-down mount allows the light to fit below an ARB awning
2015 Trail Premium
Old 06-09-2022, 12:09 PM #6
comtn4x4's Avatar
comtn4x4 comtn4x4 is offline
comtn4x4 is a splendid one to behold comtn4x4 is a splendid one to behold comtn4x4 is a splendid one to behold comtn4x4 is a splendid one to behold comtn4x4 is a splendid one to behold comtn4x4 is a splendid one to behold
comtn4x4's Avatar
I'm doing something similar to @codyHTX .
The lights are from Stedi and the mounts are fom Axia Alloys.
On the driver side I Mounted it under the awning so it could serve dual purpose.
Adding Scene/Chase lights to Gobi Rack-4-jpg  Adding Scene/Chase lights to Gobi Rack-3-jpg
comtn4x4 is offline   Reply With QuoteReply With Quote
Old 06-10-2022, 06:59 PM #7
These set ups look awesome. Definitely gives me ideas on how I can move forward! Thank you! 👍
2021 TRD Pro, MGM
add , gobi , lights , rack , suggestions
Adding Area/Camp Lights to Stock Roof Rack Bagels 4th Gen T4Rs 5 01-20-2022 06:48 PM
Chase Lights on a full Prinsu rack MOONMAN5 5th gen T4Rs 1 01-16-2021 02:16 PM
LED Lights for GOBI Rack Coyotegray 5th gen T4Rs 1 04-14-2019 12:01 AM
Lights for my new Gobi rack Sundog7121 5th gen T4Rs 4 01-23-2016 08:53 PM
