Old 06-13-2022, 09:40 AM #16
Brandonium's Avatar
Brandonium Brandonium is offline
Real Name: Brandon
Brandonium will become famous soon enough
Brandonium's Avatar
Real Name: Brandon
Thank you for this. I will check the rear cams and see. Currently I am running new BFG KO2's and run 37 lbs front and rear. I'll get a pic of my LCA cams and post them up.
Originally Posted by BlackWorksInc View Post
I bet you someone flattened the rear cam tabs on the front bushings.
The SPC arms are not hard to work with unless the factory suspension is messed up. I had them on my 4th gen and ran them until my 35's were just a bit too much for them.
5.5° is far more caster than you need or want unless you're trying to run 34's or larger. I wouldn't go too much higher than 4° as that seems to be a good sweet spot when balanced with a fairly neutral and/or slightly negative camber for wider/larger off-road tires. Additionally a little extra toe-in can help with chunkier tires, there is such thing as going too high; at which point the vehicle will track too well and follow every imperfection in the road and feel like almost like it's wandering.
I wouldn't trust any place that can't or won't provide all your measurements. I will adjust specifications in our machine for our lifted customers so their custom specifications don't show up "Red/Out of Spec," but they always get their before and after measurements with a note that it was adjusted for "lifted specs."
Post Note- tire shape and pressure are also very important.
2016 Toyota 4Runner TEP + KDSS + RC
1971 Volvo 142e (Lovely brick with a tractor engine)
1977 International Scout II (Another brick tractor)
Brandonium is offline   Reply With QuoteReply With Quote
camber , caster , lift , time , ucas
Proper Alignment Specs Tuc4R 5th gen T4Rs 9 04-05-2019 03:42 PM
Will I need UCA's for proper alignment? kboxvegas 5th gen T4Rs 12 03-03-2015 01:32 AM
14 TE Alignment Hell GRN285 5th gen T4Rs 4 12-16-2014 02:26 AM
Help: Assistance with proper alignment after lift. Ride_Red 3rd gen T4Rs 16 04-11-2013 05:59 PM
The importance of proper wheel alignment Thai Maintenance/Detailing 0 02-12-2004 09:39 AM
