06-14-2022, 11:02 PM
Soft lift?
I want a 2"-3" lift AND a soft/plush ride. Or a divorce lawyer, because the spousal unit didn't like the harsh rides I had on previous trucks (Bilstein and OME shocks). I'm ashamed to say that 99.999% of driving has been -and will likely be- on pavement. Mostly unloaded, no towing.
So I'm looking for the softest shocks I can find. Ride quality has priority over lift (anything over 1 inch will do). Any suggestions from personal experience?
06-14-2022, 11:29 PM
Buy an Avalon.
My 4R has the absolute softest/soggiest/unstable ride of any vehicle I have ever owned. Softer than my '66 Chrysler Imperial that literally floated down the road like it was on the high seas. If your 4R isn't soft enough for your spouse, you're probably in the wrong vehicle.
2016 Trail Attitude black. 1.5" unknown brand lift, 275/70-17 Toyo Open County A/T on DX4 Rebel 17x8.5 -6, bull bumper, light bar, skid plate by Amazon, DD fogs, TRD roof rack by Craig's List, Accessorides remote start kit
06-14-2022, 11:45 PM
King/fox 2.5s and have the stack custom made to be stupidly weak. Keep OEM rear springs and go with king 550 fronts.
Or like previously stated buy the correct vehicle
06-15-2022, 12:35 AM
Oem fox with westcott lift. Soft ride
06-15-2022, 01:21 AM
Soft lift?
You need something with progressive rate such as Dobinsons. Mine rides like a boat and I like it.
Bilstein are digressive and will ride much firmer.
2016 Limited 4WD Blizzard Pearl | Black
TRD Pro Sema | Toyo AT3 LT285/70/R17 C
Dobinsons IMS 302/700 and 505/705 | SPC UCAs | Durobumps
Victory4x4 Rack, BajaRack Ladder, Full RCI Skids & Sliders
CaliRaisedLED Ditch Lights & Light Bar
06-15-2022, 10:35 AM
2015 Magnetic Gray SR5P
06-15-2022, 11:10 AM
I have the Rough Country leveling kit - 2.5" front, 1" rear lift. Since they are spacers (front on top of strut), the ride is the same as OEM because there is no change to the OEM shocks or springs. Very soft which I really like when going over the rocks in my annual pilgrimage to Colorado.
06-15-2022, 12:54 PM
Bilstein 6112 ride much better than stock. If you don’t like the mushy stock ride then you are in the wrong vehicle. To me, stock is too soft.
06-15-2022, 06:06 PM
Why do I want another car? That's not helpful!
Ideally, I'd like to buy one of each: King/Fox/OME/Dobinson/etc and find which ride I like best. Obviously, not a realistic option.
Stock ride is not bad, and I have small spacers now, but I'd like a proper lift kit.
Adjustable shocks seem to be what I want, but if I can find a simpler=cheaper shock instead, I'd go that route. And I don't know how much difference one can feel after making all those adjustments.
This is where personal experience is priceless. To those who have contributed, thank you!
It looks like I need to find someone to build some Kings/Fox with the softest stack possible.
06-15-2022, 07:39 PM
For a softer ride go progressive shocks versus digressive.
Elka, Kings, FOX.
Get adjusters for an even softer ride. They make a big difference when adjusting mine from soft to hard or back. Very happy with my decision.
Wish I never would have waisted my money on 6112’s and just went for the Kings or Elka’s.
2016 TEP, Elka 2.5 RR Adj F&R, Chaos UCA & LCA, OME 899, KO2 285/70E, Wheeler F&R Bumps, BMC, Spindle Gussets, Cam Tabs, Nitro 4.88 Gearing, Tranny Cooler, Hefty Fab F&R Bumpers Dual w/ ladder, Warn Plat 12s, Icon Pan & Billet Rear Links, OCD Links, GFC RTT, RCI Sliders, Every RCI Skid Plate (In Alum if avail), SCS Stealth 6 Rims, ARB Twin Comp, ARB 2500 Awn, Quick Pitch Shower Awn, Compustar T11 & RMS, Dual 42" drawers W/ Adj sleep/dog height platform (2nd Row Removed) Switch Pros, Baja LP9's, Squadron & S2 Pros, Rock Lights, Dometic CFX3 35qt.
06-15-2022, 09:40 PM
Thanks!
How do you like the Elkas?
06-15-2022, 11:25 PM
I really like them. Much more comfortable and controlled at higher speeds with the resi’s turned up some than the previous setup I had of 6112 and Icon2.0. Much less jarring at slower speeds with the resi’s turned down. Washboard roads are still there but less noticeable. I’m typically going slower and that’s where I notice the biggest difference, no baja near me. Different price level, but what I have to compare to. Difference in progressive vs digressive.
06-15-2022, 11:39 PM
Just get whatever lift you want and one of these bad boys for the passenger seat...
Gel Foam Car Seat Cushion
Boom!
