Old 04-12-2022, 06:08 PM #1
ncflyer ncflyer is offline
ncflyer is on a distinguished road
Slinging grease
2019 with about 24K miles and majority on road. Not primary vehicle and today moved it, grease on the floor. Looked underneath and there is grease in the area around the inside boot on the front dif. on both side. I have a lift but not extreme, 2" maybe, boots look ok and clamps look fine.
Anybody seen or had this occur?
Thanks for any info.
Slinging grease-kimg0496-jpg  Slinging grease-kimg0497-jpg  Slinging grease-kimg0499-jpg  Slinging grease-kimg0500-jpg  Slinging grease-kimg0501-jpg  Slinging grease-kimg0502-jpg  Slinging grease-kimg0507-jpg
ncflyer is offline   Reply With QuoteReply With Quote
Old 04-13-2022, 12:44 AM #2
Dynamo's Avatar
Dynamo Dynamo is offline
Dynamo has a spectacular aura about Dynamo has a spectacular aura about Dynamo has a spectacular aura about
Dynamo's Avatar
Yep, been there, done that. Happened on my '19 ORP when it had 27k miles. Fixed under warranty and it's been dry every since (50k miles now).
Inner CV axle boot leaking...
Make sure whoever fixes it crimps the clamps properly.
Also, several other '19 owners had the same problem. Makes me wonder if there was a bad batch that weren't properly crimped from the factory.
2019 TRD ORP
Dynamo is offline   Reply With QuoteReply With Quote
Old 04-13-2022, 01:50 AM #3
BlackWorksInc's Avatar
BlackWorksInc BlackWorksInc is offline
BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold
Maybe not crimped enough? I do recall doing a handful under warranty a couple years ago, thought it was a little weird.
To the OP, you're probably still under warranty for that; can't hurt to ask at least? I wish the really nice CV Boot clamp tool we have wasn't so expensive, I'd recommend everyone get one vs. those boot pliers. :/
BlackWorksInc is offline   Reply With QuoteReply With Quote
Old 04-13-2022, 10:11 AM #4
Thanks gents. I would think warranty should cover it but when I was asked about the lift got me thinking a good way for them to deny warranty. We'll see.
Old 04-13-2022, 10:47 AM #5
headstaller headstaller is offline
headstaller is on a distinguished road
Same with my 19 and covered under warranty.
headstaller is offline   Reply With QuoteReply With Quote
Old 04-25-2022, 10:23 PM #6
Just as I guessed, said the lift/install caused the problem so said I could...
1. Spend about 1,000.00 on OEM cv axles (said axle had to be replaced too and couldn't just reseat or replace the boots only)
2. Spend maybe 50 or less on aftermarket parts.
Looking into aftermarket (larger) boots to replace OEM.
Old 04-25-2022, 11:06 PM #7
Jeremy556's Avatar
Jeremy556's Avatar
Don't change anything, OEM boots are probably the best thing available. All you need to do is fully crimp the Oetiker clamp. Any decent set of the pliers ($30+) should easily do the job in about 5 minutes.
OEM CV axles are $350, and you can change the boots. A kit with inner and outer boots, grease, and clamps is sold as a kit by Toyota for like $60. Also, lift has nothing to do with this problem.
ETA: As BlackWorks mentions, the Toyota tool for these is tits, but I haven't seen the same design on the aftermarket anywhere. I have some Knipex that are great for smaller ones like the TRE boots, but not big enough for the CVs. I have this style, and they sort of work with some long prybars to get a lot of leverage, but because of the slop and poor tolerance and they don't do a very good job.
Old 04-26-2022, 12:02 AM #8
"Also, lift has nothing to do with this problem.'
Thanks and will get it worked out but likely any reason to deny and then say I need 2 new axles and boots to fix the boots that may have loosened some.... I have suspicions but doubt the dealer will go back against their tech.
Might try another, or just put take the clamp off, push back and put a regular screw clamp on? They said Toyota is real particular about this kinda stuff. Who knows, maybe got stretched out with the suspension install but didn't look it over so can't say that's what happened either. Odd when you see some dealers that will do aftermarket no problem, and then others won't touch anything not OEM.
Live and learn - Thanks all for the information.
Old 04-26-2022, 01:32 PM #9
Little follow up if it may help if you see this, one possible issue...
I cleaned up the area good around the boot/axle and grease on parts around. All things looked okay best I could tell and then found this on both sides, same location. On the inside (towards diff) of the boot, at the lower part of the clamp where it's crimped, found if I pushed on this area it seemed to give slightly. You could see grease but no coming out so maybe the "point of failure" so to speak when it turning.
In the pic, the area is where the ridge and clamp/boot meet and can see the grease in the area. Cleaned it up a bit more and gonna try silicone to see how it works out. May want to do some minor moves with the vehicle to see the other ridges to see if they may be the same but think it may be just these areas since same on both sides.
I have a mild lift so may not apply to others that are 3" or so since the angle will definitely be more.
Slinging grease-cv-1-jpg  Slinging grease-cv-2-jpg
Old 04-26-2022, 02:40 PM #10
DougR's Avatar
DougR DougR is offline
DougR is just really nice DougR is just really nice DougR is just really nice DougR is just really nice
DougR's Avatar
I think the clamp may be a little loose. If so, a rise in ambient temperature combined with a recent lift may force out some grease. Here is a spec for checking the clamp.
Slinging grease-2022-04-26-11_34_22-jpg
DougR is offline   Reply With QuoteReply With Quote
Old 04-26-2022, 03:51 PM #11
Cool, Thanks.
Old 04-27-2022, 07:46 AM #12
<<<<'s Avatar
<<<< <<<< is offline
<<<< is just really nice <<<< is just really nice <<<< is just really nice <<<< is just really nice <<<< is just really nice
<<<<'s Avatar
Don't silicon rubber boot. Get new band regrease the joint and reclamp leaky boot.
<<<< is offline   Reply With QuoteReply With Quote
Old 05-01-2022, 05:13 PM #13
WRM1 WRM1 is offline
WRM1 is on a distinguished road
I would never put a regular screw clamp on a CV boot. Too much risk of it being out of balance and causing a bunch of vibration for me to even think about it.
OP, If you can live without the vehicle for a couple of days, remove the CV axles and take them to the dealer(or elsewhere) and have the boots replaced, along with the clamps. I had to do that with my wife's Volvo when I wasn't watching what I was doing, and pulled one of the CV joints apart. The bright side was I did that just before the last of the grease was going to go away, so avoided having to replace the axle.
WRM1 is offline   Reply With QuoteReply With Quote
Old 05-01-2022, 05:45 PM #14
So I was always taught to mark every portion of the axle when you take it apart to rebuild/reboot it and have had two schools of thought imparted on me regarding the clamps. First one was to line all the clamps up because that should be how it was done from the factory, the second was to vary the clamps by 180° because that is how it was done from the factory.
I was really religious about that for many many years and then over time I started getting lazy and forgetting about the clamp orientation as well as the marking some days. The vast majority of technicians I've talked to from the really seasoned old timers to the relatively seasoned guys who have at least a decade under their belt didn't and/or don't bother with it anymore. Even the factory doesn't seem to consistently match clamps up and the more I think about it, it really doesn't matter because the bigger weight that is being slung is the grease itself which will "self-balance" itself. So I think this is one of those "it's great on paper and if you want to do it, go ahead, but in the real world it's negligible."
As to the OP's concern, the clamp looks like it could do with a little more crimp. I'd go and buy one of the tools that was pictured earlier, they're not the best; but unless you want to dole out the cash for a Toyota SST, they'll work fine. Get two 1/2" breaker bars and carefully squeeze the crimp on the clamp a bit tighter, I say carefully because with the tool that Jeremy556 mentioned it's easy to twist the pliers and either stretch or break the clamp when you're trying to tighten them (especially if your using breaker bars.
But I can tell you that the majority of the time I have seen that type of light grease seepage it's been due to a slightly loose clamp. In most cases I just snug the clamp up, hit it with brake clean, and have them keep an eye on it; rarely had any that came back needing to be fully replaced.
Old 05-02-2022, 09:49 AM #15
and to think the potatoes at the dealer told him to install new axle assemblies. SMH
boots , extreme , grease , lift , slinging
Grease orcking 5th gen T4Rs 22 09-25-2023 04:21 PM
Can I use EP moly grease on all the drive shaft grease zerks Pyral 3rd gen T4Rs 3 07-18-2021 12:46 AM
What grease do you use in your UCA's? TOTAL CHAOS 5th gen T4Rs 38 05-29-2021 05:52 PM
what is The BEST grease? Billynath1988 4th Gen T4Rs 1 09-25-2018 12:20 PM
Steering rack polyurethane bushings: grease or no grease? fourfive 3rd gen T4Rs 14 05-07-2017 02:59 PM
