Old 06-18-2022, 11:47 PM #1
bapsdds bapsdds is offline
bapsdds is on a distinguished road
brake lights bulb work on running mode but not on braking mode
HI everybody,
I have a 2011 toyota4runner limited , the driver light bulb works if turn on the head lights running lights but when press down on the brake lights it does not light up only the passenger side does
please help
thx
bapsdds
bapsdds is offline   Reply With QuoteReply With Quote
Old 06-19-2022, 12:42 AM #2
Whippersnapper02's Avatar
Whippersnapper02 is a splendid one to behold Whippersnapper02 is a splendid one to behold Whippersnapper02 is a splendid one to behold Whippersnapper02 is a splendid one to behold Whippersnapper02 is a splendid one to behold Whippersnapper02 is a splendid one to behold Whippersnapper02 is a splendid one to behold Whippersnapper02 is a splendid one to behold
They are dual filament bulbs so probably the brake light filament is blown.
Old 06-19-2022, 04:24 PM #3
flyrv9's Avatar
flyrv9 flyrv9 is offline
flyrv9 has a spectacular aura about flyrv9 has a spectacular aura about flyrv9 has a spectacular aura about
flyrv9's Avatar
Yea, I agree with what Whippersnapper02 said - either a bad bulb, or a bad crimp on the wiring at the socket. There were a few threads here about that in the early 5gens. Haven't seen any lately.
The way to troubleshoot is to remove the bulb and either check the bulb with a meter or test light (if you can't tell if there is a broken filament by looking). If you don't have a meter, then just swap in a new bulb (or the working bulb from the other side) and see if it fixes it.
If the bulb is good, then the wiring / crimp is most likely the issue. Turn the lights on and check for 12v at the socket in both places (12v for tail light and 12v when brake pedal is depressed) easier to check brake function with a helper. Be careful not to short the pins with 12v to ground (not much room in the socket). If you determine it's probably a bad crimp, then there are threads you can search on that have pics and descriptions on how to resolve the issue.
brake , bulb , lights , mode , running
DYI Headlight Mode ( not light bulb changes) Charlievee 5th gen T4Rs 14 05-10-2019 11:00 PM
Switching from shift mode to drive mode Happy 1 5th gen T4Rs 31 05-12-2017 12:34 PM
2009 Limited V6 Multi Mode 4wd in 2wd mode JCSTEW 4th Gen T4Rs 2 09-11-2015 07:52 PM
Engine braking - sort of like the Tow/Haul mode alia176 4th Gen T4Rs 4 07-23-2015 04:12 PM
multi mode: 4wd button and L4L (no lights on dash though) work but H4L does nothing scuheckler88 3rd gen T4Rs 0 02-28-2011 02:55 AM
