Old 06-19-2022, 09:37 AM #1
mmeuli mmeuli is offline
Real Name: Michael Meuli
mmeuli is on a distinguished road
How has the dealership tried to screw you?
I took my 2016 Limited 4WD into Fred Anderson Toyota in Charleston, SC with a small oil leak. They then 'discovered' that my rear main and timing cover were leaking, and also 'noticed' one of my front struts had some caked-on dirt, prompting them to say I need new struts and that Toyota ONLY recommends changing all 4.
See attached estimate. I laughed in their faces and left. I decided to start the repairs myself and replaced the rear main seal, which was a giant PITA. Figured I'd test it out and guess what? Oil still leaking.
It got to the point that I was leaking a quart a day. I'm not a mechanic and have no idea how to generally diagnose an oil leak, but I thought it was very unlikely that I'm losing a quart of oil a day via the timing cover.
So, I cleaned off the engine completely with dawn and put UV dye in the oil, and fired it up the next morning. Oil was essentially pouring out of the oil pressure assembly switch.
I bout the OEM part for $30 and a $10 tube of Permatex high temp thread sealant and replaced the existing switch around 5 PM. Let it sit overnight (says 24 hrs to fully cure, but given the weather in Charleston, I was pretty sure it was able to cure faster). Cranked it up in the morning: ZERO OIL LEAKING. ZERO.
I was confused when I pulled the RMS because it didn't really look like anything leaked from it. The original RMS was intact and zero oil was behind the plate it goes into. That's why I questioned the timing cover.
I was able to fix, for $40, what the dealership wanted over $5,000 to 'fix.' and it wouldn't have even fixed it!!!! I've had issues with Fred Anderson coming up with bogus repairs in the past, so I don't usually take them with a grain of salt--but $100 repair BS'ed into $5,000?
So what is the worst thing a dealership has tried to do to you that was total BS?
Sent from my SM-G998U using Tapatalk
mmeuli is offline   Reply With QuoteReply With Quote
Old 06-19-2022, 01:11 PM #2
BlackWorksInc's Avatar
BlackWorksInc BlackWorksInc is offline
BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold
Would have liked to see pictures of the rear main seal area... Usually they leak because the oil gets baked and forms a hard ring on the crankshaft and allows it to seep by the seal (highly recommend lightly scrubbing the crankshaft before you reinstall the new seal). The other thing, that is a bit more rare but I just dealt with it on a 2019 a while back was that the oil galley plug above the rear main seal will seep oil and look like a traditional rear main seal plate leak. There's no "official" fix for this beyond a short block, but it can be fixed with some creative thinking if you're willing to risk it.
As for the timing cover leak, again would have been nice to see pictures (does this dealership not do that?), but you might still have an actual timing cover leak. Though I would be shocked to find one pissing a quart a day, if I noticed the cover was actively dripping like that, it would be a red flag for sure. I have seen a few Toyota Oil Pressure Switches/Sensors leaking badly, something about the crimp seal or something, they'll literally pour out of the connector housing. We had a rash of them years ago, a bad batch from the supplier I guess? But haven't seen it as often in the last two-three years.
Judging roughly by the vehicle you own and the estimates I am going to guess you have an XREAS system. Generally speaking, if the vehicle is high mileage and you're showing signs of a decent leak on the shock, it's recommended by Toyota to replace the companion shock, center dampener, and associated lines. Also standard practice is to replace shocks in axle pairs, which because it's XREAS, ends up meaning all 4 shocks, center dampeners, and lines. So that's not out of the ordinary, though pictures of the leak would have been nice to see as if it wasn't too bad a leak and you have relatively low mileage you could probably try getting away with just 1 shock.
I can't say they weren't trying to screw you, I have heard some horror stories both on the forum and from others in the industry about dealerships on the East Coast and Southern Regions (not just Toyota ones). But depending on the age/mileage/condition of your vehicle and the actual condition of the leaks when they recommended it, it's possible that whoever looked at the vehicle just didn't catch the signs of a leaking oil pressure sender (again, it's uncommon... but I have seen it happen a few times) and just recommended what they are used to seeing. That being said, they are a business; what would have been truly sleazy is to charge you $4k for a timing cover reseal and then make you pay for the oil sender replacement even though it'd be their incorrect diagnosis on your active oil leak.
BlackWorksInc is offline   Reply With QuoteReply With Quote
Old 06-19-2022, 01:16 PM #3
2021nightshade4x4 2021nightshade4x4 is offline
2021nightshade4x4 is just really nice 2021nightshade4x4 is just really nice 2021nightshade4x4 is just really nice 2021nightshade4x4 is just really nice 2021nightshade4x4 is just really nice
Not on my Toyota (yet) but Fred Anderson is slimy as hell in general. Sales, finance, service. I bought mine from Hendrick of Wilmington.
If we question the dealer model as a whole, you pay $40-50k for your 4Runner, only to have another man’s name on your hatch. Why doesn’t the dealer put my name on the wall or something? Especially for all that. I can pay $500 and get my name on a brick at a hospital, or $50 and get my name on a brick at a school.
I’ve got big plans for mine after the warranty runs out (I’m playing it safe and doing dealer service only until it runs out).
2021nightshade4x4 is offline   Reply With QuoteReply With Quote
Old 06-19-2022, 01:20 PM #4
tpetsch's Avatar
tpetsch tpetsch is offline
tpetsch is on a distinguished road
tpetsch's Avatar
What's the mileage on your 2016 mmeuli? ..just out of curiosity?
BTW: Happy to hear you found the $40 fix to remedy Toyota's $9000 estimate.
tpetsch is offline   Reply With QuoteReply With Quote
Old 06-19-2022, 01:46 PM #5
I am so glad the most we do is put our license plate frames on vehicles, I always DESPISE dealership networks/companies that insist on slapping their stickers/emblems on a nice new vehicle. Like seriously, you think I want to spend $60k on a new vehicle just to have your tacky ass advertising on my car? You paying my detail bill when I have to remove it and it ****s up my paint?
Also I swear most sales departments for dealerships in general must go to the same training course. If I had a nickel for every time I have had a service customer tell us "sales said it was included/they would pay for it as part of the purchase" when it wasn't in writing, I'd probably have a 5th gen now. Granted the sales department we work with is doesn't seem to be as bad as prior ones I have dealt with; but it still happens every now and then.
To be fair, it was a $4k bill for the timing cover, which if it is leaking, won't fix that; but I would prioritize an active leaking oil sender over a relatively passive timing cover leak (I have mentioned to customers in the past to save their money on a timing cover leak and to use it on other repairs that are more important/pressing simply because it's just efficient).
Old 06-19-2022, 02:55 PM #6
Old Tanker Old Tanker is offline
Old Tanker has a spectacular aura about Old Tanker has a spectacular aura about Old Tanker has a spectacular aura about
I have mostly avoided the local dealers since purchase in 2019. Last month I needed a zero point calibration, the "service consultant" had no idea what I was talking about, and when she returned from a discussion with someone more senior, she quoted three hours of labor. I drove off and fixed it myself with a paper clip in 15 minutes.
The first mod I did after purchasing the vehicle was to remove the dealer name from the tailgate. The second mod was to swap out the license plate frame.
2019 TRD ORP. BFG KM3 285/70R17. Hefty front tube bumper, LFD dual swing-out rear bumper. Warn Zeon 10S. RSG sliders. Sherpa roofrack. Goose Gear interior. Radflo 2.5 suspension.
Old Tanker is offline   Reply With QuoteReply With Quote
Old 06-19-2022, 11:28 PM #7
Pavement Tested Pavement Tested is offline
Pavement Tested will become famous soon enough
This topic is just one of the reasons I do not go to the dealership for anything unless it is absolutely necessary for recall or warranty work. This is not just a Toyota dealer thing but all dealers in my experience.
From the maintenance side for multiple dealers I've had performance parts stolen off my vehicle, fasteners broken and not replaced, unauthorized work performed, unauthorized parts replaced, misdiagnosed conditions, attempts to charge me for warranty work and maintenance flat out not performed when documented as done.
From the parts side I've had them quote me one price over the phone that was in line with MSRP pricing listed online then try to charge me over 300% markup at the counter with claims they "have to keep the lights on somehow". When pressed on the price it magically went down to the MSRP price.
The last sales experience I had at a manufacturer's dealership (Toyota) was the end of the year last year, my wife and I worked out a deal for a 2022 TRD Pro that wasn't built yet and was scheduled to be delivered 2 months later. We got a final OTD price and secured our own financing through the bank I've been with for over 25 years. With a check in hand to finalize the deal we called the dealership for 3 weeks, left messages or got no answer. Never got any calls returned. Neither the salesman nor the finance dept seemed interested in taking our money so we returned the check to the bank and cancelled the loan. Then called the dealership to get our deposit back. They kept giving my wife the runaround over the phone so after 2 weeks we went in to talk to some management. After about an hour we walked out with a refund. A month later the salesman called and asked if we were going to finalize the deal and we laughed at him, told him that we had killed it a month earlier and he was oblivious.
I bought my 4R at a used car lot in March, which wasn't a much better experience, knowing they didn't have the "extras" the new car dealers try to swindle you into and having what I wanted for a marginally acceptable price, I did my own inspection and made the deal. The dealer advertisement plates and frames were in the trash before the engine oil settled in the pan after arriving home.
It is always my advice to find a locally owned, small shop that has a good reputation and is experienced with the brand of vehicle you own to do your work. You do not HAVE to have your maintenance done at the dealership to maintain the warranty. It just needs to be done on schedule, by an experienced technician and documented properly using materials (fluids, parts, etc.) that meet the manufacture's recommended specifications. If this is done, the manufacturer has no legitimate reason to deny a warranty claim.
2016 Trail Attitude black. 1.5" unknown brand lift, 275/70-17 Toyo Open County A/T on DX4 Rebel 17x8.5 -6, bull bumper, light bar, skid plate by Amazon, DD fogs, TRD roof rack by Craig's List, Accessorides remote start kit
Pavement Tested is offline   Reply With QuoteReply With Quote
Old 06-20-2022, 06:33 AM #8
JaSC1 JaSC1 is offline
Real Name: James
JaSC1 will become famous soon enough
Real Name: James
First thing I did was remove the obnoxious dealer advertisement. It was not a decal but a 3d rubber logo! You tube videos of removing without damage helped.
JaSC1 is offline   Reply With QuoteReply With Quote
Old 06-20-2022, 09:26 AM #9
MZ2215 MZ2215 is offline
MZ2215 will become famous soon enough
I'm always enthralled by these fantastical descriptions, can you elaborate a little? You've had multiple dealers STEAL performance parts off of your vehicle? Like went in with an aftermarket intake and got home to realize it was gone? Multiple times?!? Like not by mistake replaced a part, but a tech saw your rig roll in, eyed a performance part, and legit stole it? Were the police involved? How were these multiple instances remedied?
In the service dept was there some kind of misunderstanding with the parts in question or are you telling us that at the window when they're ringing your parts up they have a special button that says "dry anal with no lube price" they hit for you? And you just said "hey man i'm not paying your rip off prices" and they were like yeah our bad, we'll charge you the regular price then. Not that it's imposssible, but every time I've purchased parts at the dealer there's a universal part number and the price for the part in the system is the price. It wasn't a "I tried buying a wheel bearing and they rung up a whole hub assembly" situation? Going to the dealership for an oil change and being told you need thousands in repairs is a story old as time, but them intentionally ringing up a part like you've described throws up some new red flags.
Not a fan of dealerships and agree, definitely prefer to have a trusted mechanic in an independent shop, but it sounds like you've either had the worst luck possible or are perhaps slightly hyperbolic when describing your interactions
MZ2215 is offline   Reply With QuoteReply With Quote
Old 06-20-2022, 09:43 AM #10
Humble Leader's Avatar
I can't stand dealers that staple their names to cars. if you want throw on a nice license plate frame with your name that's not obnoxious ok fine, I can just remove it if I want
I don't have any horror stories thank goodness. I think honestly the worst that's happened is lexus broke a plastic push pin for that plastic trim in the engine bay on my wife's RX and didn't replace it lol. the RX needed a new muffler, went in for service but the part hadn't arrived yet. they offered me a new IS 350F for a week to test out until the part came in if I wanted to leave my vehicle there. they knew I drive a long way to get to that dealership. that's probably the worst
I do extensive research on where I bring my vehicle in for service though, probably more than 99% of people out there - so far it has paid off for me. I don't have the tools and don't have mechanical ability to do some of the more complicated stuff so I have to rely on others. maybe if there wasn't any time pressure to have my vehicle operational as a daily driver I could stretch a repair out over a week and take my time but I don't have that luxury
OP you knew this dealer had bogus repairs in the past, why did you waste time and go back? you know what they say... fool me once...
Old 06-20-2022, 09:45 AM #11
the $1900 charge for rear struts is great. remove wheel, 2 bolts, replace with another generic $50 shock.
Old 06-20-2022, 09:57 AM #12
Predatorsniper2005 Predatorsniper2005 is offline
Predatorsniper2005 is on a distinguished road
OP,
My dealership has done some work on my wife's RAV4. When they were doing their diagnostics, they filmed it on video, then the service advisor sent me that video link with the tech narrating what he is determining the issue/repair needed on my personal vehicle. I thought is went a long way in trusting what the tech was recommending. Not sure if this helps.
Mike
Predatorsniper2005 is offline   Reply With QuoteReply With Quote
Old 06-20-2022, 09:59 AM #13
Pedro367 Pedro367 is offline
Pedro367 is a name known to all Pedro367 is a name known to all Pedro367 is a name known to all Pedro367 is a name known to all Pedro367 is a name known to all Pedro367 is a name known to all
I just got a coupon for them to check my AC system for me for $450. I thought that was nice of them.
Pete - 2018 Silver TRDORP w/ KDSS. 2" Fox 2.0s and 285/70r17 Maxxis Razr ATs
Pedro367 is offline   Reply With QuoteReply With Quote
Old 06-20-2022, 10:48 AM #14
orcking orcking is offline
orcking is on a distinguished road
They have not yet, because I try not to take it there... I try to do work myself...
orcking is offline   Reply With QuoteReply With Quote
Old 06-20-2022, 10:50 AM #15
I4CUTigers I4CUTigers is offline
I4CUTigers is on a distinguished road
Bought my truck from that exact dealer. They have a good alignment guy, but I do everything else myself or would take it to LexTech or Japanese import pros for work I couldn’t or wouldn’t want to do.
They were actually the best price back in 2018 when I bought, but they’re service has always been agonizingly slow. Two techs did pop a bumper back into place without me asking or having to pay, which was nice (it had be damaged in a wreck). Typical dealer, some good, some bad, lots of indifference.
I4CUTigers is offline   Reply With QuoteReply With Quote
cover , dealership , leaking , oil , timing
What is the set screw for? goatfarmer Classic T4Rs 3 03-22-2021 09:23 PM
Did I screw up? Zachpins34 3rd gen T4Rs 15 12-02-2015 03:45 PM
Did I just screw up?!? imola20ae 5th gen T4Rs 7 05-05-2015 07:08 PM
How to screw up Seafoming your car USSEnterprise Maintenance/Detailing 0 06-09-2012 10:04 PM
Did I screw up? Techenigma 4th Gen T4Rs 2 03-08-2006 05:12 PM
