06-22-2022, 07:56 PM
2010-2013 Trail Wheel color question
Banged up one of my OEM Trail Edition wheels and found one on ebay that was listed as 2010-2013 Trail Edition wheel. When it arrived it was a darker gray metallic color and isn't anywhere close to the original wheel color.
I seem to remember seeing this gray metallic on FJ Cruisers, or maybe later 4Runners.
If someone could enlighten me as to what the darker gray metallic wheels came on, I'd appreciate it. I need to make sure I have that info for when I contact the seller to return it in case he claims it's the correct one.
2011 Salsa Red TE, KDSS, Running boards (not sure what to replace these with), Weathertec mats, Canvasback cargo liner, BudBuilt skid plates, full set of Billy 5100s, Light Racing UCAs, Toytec Ultimate front coilovers (with the "correct" 5th gen 5100s), SAW 1.5 rear coils, ScanguageII...
06-23-2022, 10:30 AM
This is interesting. I just assumed they were all the same color. Looks like your best bet is to get rid of your 4runner and start with a different vehicle. I'll take that one off your hands as a favor for you ;)
06-23-2022, 02:00 PM
I believe there was a darker shade option on the FJ Cruiser - can't remember which trim exactly though...
2015 Magnetic Gray SR5P
06-23-2022, 02:04 PM
06-23-2022, 08:36 PM
Originally Posted by emmantik
Yes! Thank you! The charcoal color is what I received, not the Silver i have on the 4Runner.
Do you know anything about Originalwheels.com? Are they legit?
06-24-2022, 10:14 AM
Also try Hub Cap Heaven for used wheels.
06-27-2022, 08:23 AM
There are two different Toyota part numbers for these rims.
42611-35420
42611-35410
I'm not sure which of these is for the lighter color version and which is for the darker color version. Might want to check the inside of your rims (originals and newly purchased) for stamped codes.
Summer: Michelin Defender LTX 245/60R20 on OEM Limited 20" rims / Winter: Toyo Observe GSi-5 265/70R17 on 2018 TRD Off-Road 17" rims.
06-27-2022, 09:26 AM
I’m no help, but I think those are some of the best looking stock wheels made.
2018 ORP Barcelona Red
Dobinsons 2.5”/1.5” lift with springs and shocks.
Diff. Drop.
Pro Comp UCAs.
RSG angled sliders.
09-19-2023, 09:31 PM
Any experience w/ Original Wheels?
Also, I think the PN is 42611-35420 from what I found online for the 4runner wheels
