Old 06-29-2022, 11:32 AM #1
Jrunr Jrunr is offline
Jrunr will become famous soon enough
Question Tried upgrading JBL Audio system - FAIL
So, I tried to upgrade my JBL system in my TRD Pro a little bit, like I did in my last SR5, but replacing the dash speakers with the good infinity reference 3.5” speakers. It sounded like I covered my front soundstage with a mattress!! (Saying it sounded like I covered it with a blanket is a massive understatement!!)
I was extremely disappointed in what I heard! It was sooo quiet and thin sounding that I had to put the stock JBL speakers back in the dash and that just opened everything up again! The volume and dynamics were back. I also noticed that as soon as I put the grille back on the dash, the speakers bloomed even more! This makes me think they actually put some time into the creation of this system…
So, now I have to figure out something else… I am not happy with the clarity of the JBL system, but just adding aftermarket speakers isn’t going to help like it would in previous set ups.
Do any of you have any advice on how to possibly upgrade without tearing up the vehicle? What I want is for everything to still LOOK like it’s stock, but to sound significantly better while retaining everything we have connected through our factory head unit.
Definitely open to suggestions on how to “stealthily” improve the JBL system.
Thanks in advance!
2021 TRD Pro, MGM
Jrunr is offline   Reply With QuoteReply With Quote
Old 06-29-2022, 12:11 PM #2
97BlackAckCL's Avatar
Real Name: Chris
Real Name: Chris
I know on the non-jbl the door speakers are wired in series with the dash tweeters, so if you don't wire all those wires correctly it could cause issues. I used TacoTunes harnesses in order to install JBL and Infinity 3.5's in my dash and have had no issues with sound quality. Since you mentioned the grilles, I did have to trim my tweeter grilles in order for them to not contact the cone on the speakers
Old 06-29-2022, 12:27 PM #3
Whippersnapper02's Avatar
You basically need to bypass everything and run your own headunit and/or amp because the JBL amp powers everything.
Old 07-01-2022, 03:45 PM #4
matoolie's Avatar
matoolie matoolie is offline
matoolie has a spectacular aura about matoolie has a spectacular aura about
matoolie's Avatar
I agree with 97blackackcl and double check the polarity of the speakers as this could impact sound. Also remember the JBL speakers are 2ohms so if you were using aftermarket 4ohm speakers the sound level will be reduced.
Honestly the best option to maintain the stock appearance/functions and best sound with least amount of work is going to be OEM Audio Plus package for JBL systems. Seems pricey but if you were to do your own system with similar components and features the cost would be similar. I have been going back and forth on pulling the trigger on their system myself.
Michael
2021 Pro Lunar Rock: RCI tranny/transfer case/tank skids, Victory roof rack
2014 LE Nautical Blue: 285/70R17 Falken A/T3W, FX Pro wheels, Fox TRD Pro suspension with Wescott lift, Dobinson UCA's, Metal Tech sliders
matoolie is offline   Reply With QuoteReply With Quote
Old 07-01-2022, 10:25 PM #5
achtung6 achtung6 is offline
achtung6 is on a distinguished road
This is the way. You need to tap the speaker outputs of the JBL amp and run them through a digital signal processor like the JL AUDIO Fix 82. Then you can use any amp and speakers you want. You cannot eliminate the JBL amp unless you also change the head unit. I wanted it to look stock so I did the DSP along with a JL amp, FOCAL components for the front stage, FOCAL co-axials for the rear doors, deleted the speakers in the hatch and swapped the stock sub for a JL. I installed Dynamat in the doors and trunk floor. The system sounds amazing and looks totally stock.
achtung6 is offline   Reply With QuoteReply With Quote
Old 07-02-2022, 09:59 AM #6
2000se 2000se is offline
2000se is on a distinguished road
and the impedance level for the jbl speakers are like 2ohms
if you installed standard speakers they’re probably 4ohms. You effectively cut your wattage in half at that point.
2000se is offline   Reply With QuoteReply With Quote
dash , jbl , put , speakers , system
Upgrading stock audio to 15-speaker JBL? kaitlyn2004 5th gen T4Rs 7 05-27-2020 06:54 PM
Upgrading Audio...still looking for subwoofer solutiins Louisiana Overland 5th gen T4Rs 4 03-16-2018 09:25 PM
Upgrading audio, what do I need?! wmflyfisher 4th Gen T4Rs 11 05-11-2017 11:14 PM
Finally got around to upgrading the audio.. emmwhat 4th Gen T4Rs 11 04-27-2016 12:27 PM
Upgrading 3rd gen audio c1rca491 Engines / Suspension / Wheels / Tires / Audio / Accessories 4 08-30-2011 09:02 PM
