07-05-2022, 04:26 PM
Body Mount Chop plates.
Are they all the same? Any do a better job than the others?
Any to avoid? Any the gold standard?
Sent from my SM-S908U using Tapatalk
07-05-2022, 04:29 PM
2017 SR5 if it makes a difference.
07-05-2022, 04:59 PM
are you DIYing it or having a shop do it? I had a shop do mine and they made their own plates. I've had no issues. Just ask the shop what they recommend if you are going that route. Otherwise I think they all look pretty good online, but no personal experience
2021 MGM 4Runner TRD Off Road, KDSS
Eibach | Falken | CaliRaised | Sherpa| Joe's | Rago | Odyssey | Redarc | Rigd | Waterport | Baja Designs | Diode Dynamics | MaxTrax | Level 8 | OVS | S-Tech | Midland | Dr. KDSS | ARB | JLT | Anzo
2022 MGM Corolla Hatchback 6-speed
2010 Black/Black C63 AMG, 460 whp (I miss this car every day)
07-05-2022, 08:46 PM
DIY
07-05-2022, 09:35 PM
i never filled mine lol. makes it easier to trim more.
07-05-2022, 10:14 PM
they all the same. I never understand why anyone would buy fancy filler plates that nobody will ever see or care.
When it comes to BMC, if done correctly, they should be hard to spot if you are trying to make it look aesthetically pleasing. Thats just me.
07-05-2022, 11:00 PM
The tires were replaced today. Toyo Open Country AT (1st gen) with AT3. Same size, 285/70r17. So there is the increase in tread from worn to new.
Then had an alignment. After that the tires rubbed.
Got home and removed the mud flaps. Tires now clear. Barely.
Then one of the horses wandered over to inspect the work, and signed off on the job by pooping on (splashed) one of the new tires.
07-05-2022, 11:26 PM
I love my Toyos. I had the Wildpeaks before but these just seem to ride so much better.
2016 Limited 4WD Blizzard Pearl | Black
TRD Pro Sema | Toyo AT3 LT285/70/R17 C
Dobinsons IMS 302/700 and 505/705 | SPC UCAs | Durobumps
Victory4x4 Rack, BajaRack Ladder, Full RCI Skids & Sliders
CaliRaisedLED Ditch Lights & Light Bar
07-06-2022, 12:10 AM
I never have either. The body mount bolts and sleeves will rust out. Well, not in Phoenix, they won't.
07-07-2022, 03:00 PM
I used the SDHQ plates, they are angled a bit so fit tighter to the mount and give a bit more room vs alignment settings and tire size/wheel offset.
2019 TRD OffRoad - Fox w/Resi, 650lb Springs, JBA HD UCA, T12 Rear Springs w/DS 5mm Spacer, Odyssey 34R-PC1500T AGM w/Diode Upgrade and CTEK Monitor, NOCO battery charger wired to external port for shore power, Rago Hidden Winch Plate, Comeup Seal 9.5 RSI, RCI Sliders/ Skids, 285/70-17 Cooper AT3 XLT on Fuel Rims, Various LED upgrades, OE Engine Heater w/External Port, XenonDepot Low Beam HID & LED 3k Fogs, ScanGauge, Midland GMRS, Accessory Mount for iPad, mike and Inreach, iKamper Mini 3.0, Custom Kitchen/Cargo system, ARB 50Q, Goose Gear dual drawer, Wilco Solo Tire/Hilift/RotoPax Carrier.
07-07-2022, 03:58 PM
DIY
I welded nuke plant pipe for several years. This took me about 15 minutes per side. No new plates needed and maintain the factory look. Free. I made this video to show how to do it. If you have the skill it's no problem! Check this vid out. I attached a picture of the finished result.
登录 Facebook | Facebook
07-07-2022, 04:02 PM
Really? I run wildpeaks and love them except they only last me about 10,000 miles instead of 50. I drive hard though and off road year round. Do they last longer?
07-17-2022, 09:49 AM
I used RSG. They're curved to give more clearance than the flat plates.
| IG: daks.4rnr | 2018 TRD Off Road Premium | Dobinsons 302/505 700/705 | Dobinsons UCA | Shrockworks Angled Sliders | RCI Skids | C4 LoPro | Prinsu 3/4 |
07-17-2022, 10:26 AM
I’ve only had the Toyos a short time, but from I read, they have a tougher tread compound so they typically last longer. My biggest knock on the Wildpeaks was how heavy they are compared to an equivalently sized Toyo. I probably don’t off-road as much as you, but they both perform about the same off-road.
07-17-2022, 09:51 PM
HEAVY Plus on this, filler plates are purely cosmetic and no one is going to see them anyways. As you move up in tire size and adjust suspension why not leave it flexible? It doesn't bother me but I know it will trigger some of those show truck "overlanders" out there :P
'12 Silver 4Runner SR5: 14+ facelift, CBI front, CBI Rear, Warn EVO 10-S, ARB Snorkel, Baja Designs 30" S8, Squadron Sports, S2 Rack Lights, King 2.5 Suspension, OME 899, 33" Cooper ST Maxx, Full CBI Skids, Metaltech Sliders, GFC Tent, ARB Awning
Xtremluck's 2012 SR5 Build Thread
