Old 07-05-2022, 11:20 PM #1
Sonoran_Desert Sonoran_Desert is offline
Real Name: Jo
Sonoran_Desert will become famous soon enough
Real Name: Jo
Cold Engine Coolant Level
Curious what coolant level you like on a cold engine. Truck came with Coolant at the level Full line but I was getting overflow. I have my level now set right in the middle of Full and Low and no more overflow.
Sonoran_Desert is offline   Reply With QuoteReply With Quote
Old 07-05-2022, 11:25 PM #2
mbm112 mbm112 is offline
mbm112 has a spectacular aura about mbm112 has a spectacular aura about mbm112 has a spectacular aura about
Anywhere between Min and Max.
2016 Limited 4WD Blizzard Pearl | Black
TRD Pro Sema | Toyo AT3 LT285/70/R17 C
Dobinsons IMS 302/700 and 505/705 | SPC UCAs | Durobumps
Victory4x4 Rack, BajaRack Ladder, Full RCI Skids & Sliders
CaliRaisedLED Ditch Lights & Light Bar
mbm112 is offline   Reply With QuoteReply With Quote
Old 07-06-2022, 03:24 PM #3
Real Name: Jo
Real Name: Jo
Thanks - seems others found the same.
I would like to find the time to read more about cooling systems in general. I remember some vehicles had a fan which ran even after the vehicle was turned off.
Old 07-08-2022, 06:51 PM #4
Bmnorm2 Bmnorm2 is offline
Bmnorm2 is a jewel in the rough Bmnorm2 is a jewel in the rough Bmnorm2 is a jewel in the rough Bmnorm2 is a jewel in the rough
The radiator should be full (up to the neck) and the overflow reservoir should be at the full or max line when cold.
This is in the manual.
Bmnorm2 is offline   Reply With QuoteReply With Quote
Old 07-10-2022, 01:44 PM #5
seatia seatia is offline
seatia will become famous soon enough seatia will become famous soon enough
Don't overthink this.
Although the physics of the cooling system is complex, we need not go that far.
Basically the coolant expands as the engine warms up, the coolant goes thru the vacuum valve in the radiator cap and into the plastic overflow tank. The level will rise with a hot engine.
When the engine and coolant cool down and since the overflow hose is immersed in the overflow tank, a vacuum is created and the coolant is sucked back into the radiator/expansion tank.
This back and forth movement insures that the radiator/expansion tank is always completely full and void of an air.
It also insures that coolant is no longer spilled onto the ground.
And this is why the overflow tank should always have coolant covering the overflow hose, preferably at least at the min level, but not so much that it runs over to the ground.
seatia is offline   Reply With QuoteReply With Quote
Old 07-10-2022, 04:04 PM #6
Decided to actually find it for you. Pages 412 and 514 of the owner's manual.
2021 Toyota 4runner Manuals & Warranties | Toyota Owners
Old 07-11-2022, 02:16 AM #7
Real Name: Jo
Real Name: Jo
Thanks for the quick chalk talk.
Old 07-11-2022, 02:16 AM #8
Real Name: Jo
Real Name: Jo
Owner's manual is clear and thanks for finding the pages.
Old 06-05-2024, 11:55 AM #9
4RL75 4RL75 is offline
4RL75 is on a distinguished road
I am getting overflow on my 2023 Limited, took some coolant out of the overflow tank, now is 2 fingers when cold and about 1 finger when hot below the FULL line. It´s only been 2 days, usually the overflow mark (coolant debris in the cap) is seen weeks after I clean it so I can´t still be sure this level will work. Full level at cold doesn´t seem logical because the level rises when hot. It´s not the first time the owners manual is wrong, maybe a translation error, who knows. Although leaving it full at cold would only leave a trace of dry coolant, no big deal.
4RL75 is offline   Reply With QuoteReply With Quote
Old 06-05-2024, 12:46 PM #10
Just make sure it is never below the bottom line when cold.
Simple as that.
Old 06-05-2024, 03:45 PM #11
Simple as that.
Yep, you got it right
cold , coolant , engine , full , level
ATF level high on cold... swampy_swimmer 3rd gen T4Rs 12 05-25-2023 10:21 PM
Coolant Level - Should I be Concerned? Chilow 5th gen T4Rs 9 12-29-2020 12:31 AM
Low Coolant Level KP Texan 5th gen T4Rs 5 12-19-2015 11:33 PM
Coolant Sensor and level questions Recoil Rob 3rd gen T4Rs 9 09-30-2014 01:34 PM
V8 Coolant level question centralparunner 4th Gen T4Rs 1 09-27-2009 04:02 PM
