07-07-2022, 10:50 PM
#17
Thank you all for your replies! So far, the list of “weak spots” is pretty low from what I gather. The only common problem areas that I see that are:
Rust
Secondary air injection pump
Needle bearing going out at diff
And owners haha.
The rest of the problems seem to be from missing.
How are the interior bits holding up such as leather? We have a 2010 Lexus RX350 which has been a huge disappointment, specifically the leather.
Anyone else that wants to chime in, feel free!
07-08-2022, 12:39 PM
#18
Rust
And owners haha.
Unless you're getting a Limited you won't have to worry about leather. The softex is a pretty good "fake" and quite durable
07-08-2022, 01:04 PM
#19
Rust
And owners haha.
The Lexus in leather has always been super soft to the point of feeling thin and fragile. The leather in the Limited is harder and more durable. The stuff in the SR5P and ORP is Softex which I synthetic material and way more durable than real leather.
2016 Limited 4WD Blizzard Pearl | Black
TRD Pro Sema | Toyo AT3 LT285/70/R17 C
Dobinsons IMS 302/700 and 505/705 | SPC UCAs | Durobumps
Victory4x4 Rack, BajaRack Ladder, Full RCI Skids & Sliders
CaliRaisedLED Ditch Lights & Light Bar
07-08-2022, 01:37 PM
#20
I feel that the 5th gen is sluggish. I think Toyota is lazy in not upgrading the engine and transmission. After installing a supercharger and re-gearing to 4.56 now my 5th gen feels really good and responsive, but it is an expensive fix.
BLACK 2015 TRD PRO - SAFARI SNORKEL - GOBI STEALTH - TREK BOXX
ICON STAGE 7 (700 LB SPRINGS) - 285/75 R17 NITTO TRAIL GRAPPLER
MAGNUSON SUPERCHARGER - URD FUEL & TUNE UPGRADE
DUAL BATTERY - 250 AMP ALTERNATOR - COMEUP 9500 RSI
SCHROCKWORKS BUMPERS, SLIDERS & SKIDS - 4.56 GEARS
07-08-2022, 02:27 PM
#21
My '15 Limited only has 58k and the leather still looks like new. Have only had it for a year or so, so not sure what kind of conditioning the previous owner did but it's holding up without signs of wear and tear.
As far as weak spots, my only complaint would be the power / fuel economy. Numbers wise it's better HP, torque, and mpg than my '07 V8, but the exhaust sound and butt-dyno leave me wanting more. I have no doubts that if maintained it will last forever, just wouldn't mind a little more power and a little better mileage.
07-08-2022, 03:28 PM
#22
I don’t think I’d let go of my 08 V8, but when you purchased your 5th gen, did you feel like for what you were getting for your 5th gen, if you had to let go of your V8 4th gen, you would do it?
07-08-2022, 06:38 PM
#23
The headlights are horrible.
2019 ORP
Dobinsons suspension- Front:C59-314 / GS59-700 Rear:C59-325 / GS59-701
SSO Slimline bumper with Warn VR Evo 10-S, LFD Offroad crossbars
Diode Dynamics SS3 fogs,GE Megalight Ultra +130 low beam
07-08-2022, 08:11 PM
#24
Should have been clearer, it was a trade, so the answer is yes. No regrets after a year
07-08-2022, 09:58 PM
#25
Real Name: Joe
Real Name: Joe
Originally Posted by baldrik78
That loose CV at the diff sounds like the needle bearing has gone out. This has been the most common failure I've seen in 5th gens in all of the owners groups. East Coast Gear Supply makes a bushing to replace it. It's about $60 for the bushing and $75 for the tools to remove/install. Probably takes 1-2 hours depending on how comfortable you are with a wrench. Don't forget to refill the diff with fluid when you're done.
TOYOTA CLAMSHELL BUSHINGS - 2003 & Newer 4runner and GX470
I second that. Needle bearing is garbage. The CV is sloppy off the lot new. As soon as i put a lift on it i swapped out with the ECGS bearing. No more slop
07-09-2022, 09:55 AM
#26
I have the Softex faux leather in both my 4Runner and RAV4. Zero problems with it. Very durable.
No rattles or other unwanted noises which is rather rare as cars tend to age. I did some serious off roading in Colorado two weeks ago and everything worked great.
One of my only "complaints" is when you are off roading, coming to a crest of a hill, it is hard to see over the hood and see where the trail goes. Left? Right? Or straight?
07-09-2022, 11:03 AM
#27
Just saw a 2012 RX450h with 88k on a dealer lot listed for $22,900.
07-09-2022, 11:24 AM
#28
My chief complaint is the general availability of aftermarket modifications, which can get expensive....
2019 TRD ORP. BFG KM3 285/70R17. Hefty front tube bumper, LFD dual swing-out rear bumper. Warn Zeon 10S. RSG sliders. Sherpa roofrack. Goose Gear interior. Radflo 2.5 suspension.
07-09-2022, 02:04 PM
#29
Real Name: Chris
Real Name: Chris
Needle bearing and the plastic oil filter cartridge were the only flaws I've found with mine
07-10-2022, 09:03 AM
#30
Having recently gone from a 2018 to 2022, I can tell you the difference between the OEM LED headlights in newer 4Runners and the older halogen headlights is like night and day. So much better.
2023 4Runner TRD Pro, Midnight Black
2022 4Runner TRD Pro, Lime Rush
2022 4Runner TRD Off-Road Premium, Magnetic Gray (SOLD)
2018 4Runner TRD Off-Road Premium, Super White (SOLD)
