Old 02-07-2023, 02:37 PM #1
Nikko's Avatar
Nikko Nikko is offline
Nikko is on a distinguished road
Nikko's Avatar
Anyone remove the trim around the fog lights?
I installed the Lamin X on the fogs and want to remove it, but can't get to the edges to start peeling it off. Does the black plastic around it just pull off? Attached with clips? I have a 2021 TRDP if that matters. Thanks
2021 TRDP
Nikko is offline   Reply With QuoteReply With Quote
Old 02-07-2023, 04:12 PM #2
Marvin_Rall's Avatar
Marvin_Rall Marvin_Rall is offline
Real Name: Marvin S. Rall
Marvin_Rall is on a distinguished road
The black plastic around the fog lights on your 2021 TRD Pro is typically held in place with clips, and can be removed by gently pulling on it. When removing the Lamin-X film from the fog lights, it's recommended to use a heat gun or hair dryer to warm up the adhesive, which can make it easier to get to the edges and start peeling it off. To avoid damaging the plastic or paint, be sure to use caution and gentle pressure.
Marvin_Rall is offline   Reply With QuoteReply With Quote
Old 02-08-2023, 12:30 AM #3
ED_96Ltd's Avatar
ED_96Ltd ED_96Ltd is offline
ED_96Ltd is on a distinguished road
ED_96Ltd's Avatar
If you're worried about breaking any of the bezel clips (which I usually am), you could always remove a couple of the fender liner bolts, reach up and remove the fog light from behind, giving you all the room and maneuverability you could need to get to those edges. It usually only takes a few minutes to completely remove the fog lights, just wear long sleeves or prepare for your arms to look like you tried to tame a feral cat lol.
'96 4Runner Limited - 327k miles
- OME 881/890, Bilstein 5100's, BFG KO2's (265/75/16)
'14 4Runner Trail Edition - 162k miles
- Diode Dynamics SS3 Fogs, XenonDepot DRL/High Beams, Cooper Discoverer A/T's
ED_96Ltd is offline   Reply With QuoteReply With Quote
Old 02-08-2023, 03:12 AM #4
fkheath fkheath is offline
fkheath is a splendid one to behold fkheath is a splendid one to behold fkheath is a splendid one to behold fkheath is a splendid one to behold fkheath is a splendid one to behold fkheath is a splendid one to behold
I don't think you need to remove the trim. From inside the wheel well (remove the wheel well liner), you can access the fog lights which are easily removed.
fkheath is offline   Reply With QuoteReply With Quote
Old 02-08-2023, 03:47 PM #5
emmantik emmantik is offline
emmantik is just really nice emmantik is just really nice emmantik is just really nice emmantik is just really nice
You can reach from underneath. Lots of space behind the bumper cover.
Anyone remove the trim around the fog lights?-20221205_102556_resized_1-jpg
2015 Magnetic Gray SR5P
emmantik is offline   Reply With QuoteReply With Quote
Old 02-08-2023, 05:10 PM #6
Nikko's Avatar
Nikko's Avatar
You can reach from underneath without removing the wheel well?
2021 TRDP
Old 02-08-2023, 05:45 PM #7
Yes that's right! The pic I posted was directly under the front bumper cover. I had to replace fog light bulbs and realized I could just reach under instead of through the fender liner. The passenger side may be a bit more of a challenge but I think it's still doable. Here's the video I found on the subject.
4Runner 2018 5th Gen fog light LED mod - the right way - YouTube
Old 02-08-2023, 10:54 PM #8
JWM816 JWM816 is offline
JWM816 is on a distinguished road
I think it was the passenger side that has a extra cover that I recall being quite a pain to maneuver around to pull out the light...
2018 TRD OR Magnetic Grey
So far all form and no function mods...
On the lookout for a PRO front valance...
JWM816 is offline   Reply With QuoteReply With Quote
Old 02-09-2023, 03:51 AM #9
True. I ran into that also.
Old 02-09-2023, 03:46 PM #10
Nikko's Avatar
Nikko's Avatar
Can you get the whole housing from there or just the bulb? I need the whole thing so I can take the Lumin X tint off.
2021 TRDP
Old 02-10-2023, 02:46 AM #11
The whole fog light assembly can be removed from the wheel wells or underneath.
Old 02-13-2023, 09:46 PM #12
Whole housing. I removed it all to put the Lamin-X on as well.
attached , black , plastic , pull , remove
How to remove trim on door panel? SilverGs 4th Gen T4Rs 13 11-09-2015 10:42 PM
How do I remove this piece of trim? Majindan 3rd gen T4Rs 9 09-16-2013 04:57 PM
How to remove Mud flaps and wheel well trim!!! bmanbryce 3rd gen T4Rs 5 06-20-2013 06:54 PM
How to remove gray trim around speedometer? Spiggie 4th Gen T4Rs 9 10-14-2011 11:02 PM
Cant remove fingerprints on interior trim terra4r 5th gen T4Rs 17 08-22-2011 09:00 PM
