Originally Posted by ferrisDJB
So I've seen a whole bunch of lift possibilities, companys, products, procedures....etc. I'm thinking of lifting (2") my 2018 4runner SR5 Off Road for light duty trail riding (hunting..logging roads and such) and a slightly larger, better gripping tire. So for those that have lifted, what have you been satisfied/dissatisfied with your lifts and what are some of the better companys out there suppling these kits. Also when lifting do you have to level as well or do some lift kits require additional components for leveling? I know there are cheap, quick lift kits out there, but I'm concerned with long term ride quality and product durability. Any suggestions or advice would be appreciated, thank you.
I got the Rough Country leveling kit which is 2.5" on the front and 1" on the rear. You don't have to level, just that it looks better, more purposeful if level.
The Rough Country leveling kit is spacers; front on the top of the front strut and rear on top of the rear spring. Since there is no change to the springs, shocks or suspension travel, the ride is the same as OEM which I prefer on very rough roads.
There is nothing to wear out so nothing to worry about on durability.
Also, it is very inexpensive compared to new springs/shocks. Only real cost is installation and a wheel alignment following installation.
I got KO2 tires in OEM size, load range E because where I go off road, there are lots of sharp granite rocks (not rounded soft sandstone rocks) and with the extra plys of the load range E tires, there is better protection from tire damage.
I also have the OEM TRD front skid plate and RCI integrated skid plates for the rest of the underside. I have never had any damage underneath, but I did put a big ding on the TRD skid plate once. Glad I had it.
