Originally Posted by MyFirstRunner
Hi, swapped front/back brake pads this weekend and found a piston on each front caliper was seized. Got replacement reman Duralast calipers for the 2 front wheels, swapped them out and bled them but they still feel a bit squishy. I've run a few errands and I do stop well and smooth but seems like I'm pushing a little harder to brake.
Going to re-bleed all 4 brakes today but could this just be from the new calipers? Does the braking "feel" change with non-OEM calipers on the front? Guess I'll find out later but wanted to ask the forum.
Thanks!
You were used to the seized caliper. The difference in feel could be attributed to the difference between the seized calipers and those that function correctly.
