Old 07-12-2022, 08:12 AM #1
MyFirstRunner's Avatar
MyFirstRunner MyFirstRunner is offline
MyFirstRunner is on a distinguished road
Are non-OEM calipers squishier?
Hi, swapped front/back brake pads this weekend and found a piston on each front caliper was seized. Got replacement reman Duralast calipers for the 2 front wheels, swapped them out and bled them but they still feel a bit squishy. I've run a few errands and I do stop well and smooth but seems like I'm pushing a little harder to brake.
Going to re-bleed all 4 brakes today but could this just be from the new calipers? Does the braking "feel" change with non-OEM calipers on the front? Guess I'll find out later but wanted to ask the forum.
Thanks!
MyFirstRunner is offline   Reply With QuoteReply With Quote
Old 07-12-2022, 09:54 AM #2
fkheath fkheath is offline
fkheath is just really nice fkheath is just really nice fkheath is just really nice fkheath is just really nice fkheath is just really nice
Thanks!
You were used to the seized caliper. The difference in feel could be attributed to the difference between the seized calipers and those that function correctly.
fkheath is offline   Reply With QuoteReply With Quote
Old 07-12-2022, 10:05 AM #3
I had that same thought this morning. I drove it around a bit this morning I felt really good. I just donít drive it that much anymore that I work from home, my wife usually drives this car so itís hard for me to tell since the brakes on our other car is much stiffer. She drove it and thought it felt good and normal.
Old 07-12-2022, 11:25 AM #4
USStrongman
Guest
Posts: n/a
USStrongman
Guest
Posts: n/a
Re bleed them to be certain. Its not difficult to get air trapped in the ABS module and that can lead to a squishy brake. If the problem still exists, buy or rent a vacuum bleeder or take it in to a local brake shop and ahve them vacuum bleed. Often times getting air out of an ABS module is nearly impossible without vacuum.
Old 07-12-2022, 06:00 PM #5
The ABS light came on and it started beeping at one point when I was bleeding them. Was keeping an eye on the fluid level and adding to keep it topped off but I guess it got Low and thus the alarm. I drove by a brake shop today and had similar thoughts to just have a pro bleed them.
brake , calipers , feel , front , swapped
5th gen calipers oljedi11950 5th gen T4Rs 5 03-24-2018 02:53 AM
Wtb 3rd gen calipers K9guy Want to Buy/Trade 2 11-28-2014 11:20 PM
Calipers again... indy500 4th Gen T4Rs 18 04-02-2012 07:31 PM
4th Gen Calipers mid9pitstop Problems & Warranty Issues 12 06-27-2009 09:48 PM
