Old 07-22-2022, 11:48 AM #16
Grug556's Avatar
Grug556 Grug556 is offline
Grug556 is a jewel in the rough Grug556 is a jewel in the rough Grug556 is a jewel in the rough
Grug556's Avatar
Could we old LED, I had two sets from a decent vendor here that both sets slowly aged and brightness output went from great to... barely any light at all in intensity.
Went back to a factory bulbs although a HO type instead. To bad as I like LEDs, but my experience in mine for headlights at least they arent worth the hype.
Grug556 is offline   Reply With QuoteReply With Quote
Old 07-22-2022, 12:38 PM #17
seatia seatia is offline
seatia will become famous soon enough seatia will become famous soon enough
Originally Posted by MAST4R View Post
I love the old-school nature of my 4R EXCEPT for the headlights. Worthless and dangerous, they are.
I changed the headlights with the best available regular/legal bulbs I could find and that helped a little.
Then I added SS3 LED Fog Light Kit for 2014-2022 Toyota 4Runner
in white which helped a great deal but still left the issue of distance.
I have a 2013 4R that I bought used.
Surprisingly, it has the brightest headlights I have ever seen on any vehicle ever. Cutoff is dramatic and both the low and high beam go on forever.
Assuming they are LED, haven't checked physically, but definitely will. I want to get these same bulbs in other vehicles. When I do I'll post the info here.
seatia is offline   Reply With QuoteReply With Quote
Old 07-22-2022, 05:20 PM #18
DirtyMarcus DirtyMarcus is offline
DirtyMarcus will become famous soon enough
when i got my 2021 ORP everyone was flashing me non stop. I finally realized the previous owner adjusted the headlights with the cutoff over anyones roof line.
DirtyMarcus is offline   Reply With QuoteReply With Quote
Old 07-22-2022, 07:35 PM #19
Too Stroked's Avatar
Too Stroked Too Stroked is offline
Too Stroked is a jewel in the rough Too Stroked is a jewel in the rough Too Stroked is a jewel in the rough
Great headlight performance is due more to good headlight design that better bulbs. For instance, if you have poor optical design - as some T4R's have - no matter what bulb you slap in there, the light still has to go through those lousy optics.
Also important is the fact that some bulbs work better in some headlights than others. I've personally seen some aftermarket bulbs work great in one particular application and terribly in others.
Too Stroked is offline   Reply With QuoteReply With Quote
Old 07-23-2022, 11:29 AM #20
paczowski123 paczowski123 is offline
paczowski123 is on a distinguished road
Well I can confirm that the issue was the bulbs not being fully seated in the sockets. I am not sure how them not being fully seated (they were only out maybe 1MM) caused it but after trimming down the tabs on the H9 bulbs and getting them locked into place the lights now look fantastic. I will be upgrading them to either full HID or LED, but for now they are doing great with the H9’s
paczowski123 is offline   Reply With QuoteReply With Quote
Old 07-23-2022, 07:24 PM #21
If I could offer some advice, be careful with drop in HID's. Lots of cheap Chinese parts out there and with them comes the (very real) risk of degraded performance and failed components due to the increased complexity of the system.
As for drop in LEDs, although there are far better LED options than HID, there are actually an awful lot of poor choices with these. Stay away from the cheap eBay and Amazon crap. If you want truly improved lighting, a pair of $19.99 LED bulbs are just not going to do it.
If you want my 2cents, the H9 swap is about the best bang for the buck you're going to get. It's inexpensive, easy to do and actually results in better lighting. If you go the HID or LED route, you might get improved lighting. Then again, you might not. And you're going to spend a lot more money to find out.
Old 08-03-2022, 03:30 PM #22
Thanks for the head up! To be honest, after now getting them installed properly and running them a bit, they are so bright and offer a great cutoff, I will probably leave the H9's in there. Even when my brights flip on, it is only a light increase in lighting performance, so as you've said, I always prefer stock over modified equipment/electronics.
cutoff , defined , headlight , night , vehicle
4runner thumbwheel brightness yoyomonkey 5th gen T4Rs 2 12-05-2020 09:35 PM
06+ Headlight Conversion - Headlight Cutoff Gen4SR5 4th Gen T4Rs 5 05-24-2019 01:24 PM
Gen 5 Clock Brightness Pastor passum 5th gen T4Rs 14 11-13-2018 11:36 AM
A/C High/Low PSI cutoff ghs215 4th Gen T4Rs 4 06-02-2015 09:05 PM
XB Halo Brightness Issue TiN Engines / Suspension / Wheels / Tires / Audio / Accessories 3 04-19-2015 05:56 PM
