Originally Posted by Firesq14
I am in the process of repainting a gobi I purchased used. Since my runner is emaculate, this was a concern. My solution is: 1. Complete color restoration
2. Ceramic coat.
3. Every two yrs or so, remove the rack, leaving the six base brackets bolt to the roof.
Seems a bit time consuming but I would rather do this that reseal the brackets and roof.
It is not too bad of a job, I recently removed the rack to move some mounts around. I used ratchet straps to the front and rear to pull it up.
I did like you plan to and left the six base brackets on and the whole operation took less than 20 minutes to remove, another 20 or so to re install. Once you have those base brackets lined up and mounted subsequent removal/installation of the rack is pretty easy.
