Old 07-26-2022, 10:25 PM #1
Gone4Wheeling Gone4Wheeling is offline
Gone4Wheeling is on a distinguished road
2022 Limited Wheel and Tire Section Summary
Finally, after months of trying I have landed a 2022 Limited 4Runner without third row seating and running boards. Should be available next week.
I intend to add rock sliders and aftermarket skid plates and have been investigating replacement wheels for the Limited 20” wheels to use off road.
Not looking to make a statement with big wheels, just want to fit a nice set of off-road tires like BFG KO2’s or equal without any rubbing corrections needed. Not planning to install a lift, at least initially until I get some time off road to judge if and what lift I really need.
Been reading in this forum trying to get my mind around the options and I have to say it’s a challenge to make sense of it all with so many tire sizes and rims to choose from and since a lot of people are looking to get bigger (taller and/or wider) tires for looks and for true off-road use too.
Here’s what I think I have figured out:
1. Which wheel/tire diameter 16”, 17” or 18” provides largest selection to get desired installed tire height and width – answer appears to be 17” looking at BFG KO2 tires available.
2. Primary spec for Limited rim selection – stay with +15 mm offset and select a tire that is very near the height and width of the original 20” tires that come with the Limited.
3. Once I get the vehicle, I’ll measure clearances between existing tires and potential rub points to know how much variation new tire and rim selection there is to avoid rubbing (Ie do I need to stay strictly to the existing tire installed width or can it be increased any).
4. Best source of rims with +15 mm offset will be other Toyota rims which likely will be readily available on the used market and can save some money. There are enough Toyota 17” rims with +15mm offset that I can find one I like.
5. Selected tire height should match original 20” tire height to keep revs per mile the same. I pull a small tear drop camper in the mountains and concerned about increasing tire OD thus impacting pulling performance too much.
Here’s a link to a very helpful article on Toyota rim technical data that helped me find 17” Toyota rim’s with +15mm offset:
Factory OEM Wheel Options 5th Gen 4Runner - TRD Vs. SR5 Vs. Limited (trail4runner.com)
One correction to the referenced article appears to be the offset for the 16” forged TDR wheels which according to the Toyota parts listing is only 6mm not 10mm.
I know there are many knowledgeable tire guys out there that can help correct me in my current thinking if warranted so any comments or suggestion are welcomed.
Gone4Wheeling is offline   Reply With QuoteReply With Quote
Old 07-26-2022, 10:53 PM #2
mbm112 mbm112 is offline
mbm112 has a spectacular aura about mbm112 has a spectacular aura about mbm112 has a spectacular aura about
I think you’re overthinking this. 16” wheel wont clear the brakes on 5th gen. Next best thing is to go with 265/70R17 which is the stock size for non-Limiteds thus keeping your overall diameter the same. TRD Pro wheels are +4 offset and may experience minimal rubbing on the fender liners at the front of the wheel and the mud flap in the back at full lock which is usually cleared up by the fender liner mod. Any of the other wheels should clear easily.
2016 Limited 4WD Blizzard Pearl | Black
TRD Pro Sema | Toyo AT3 LT285/70/R17 C
Dobinsons IMS 302/700 and 505/705 | SPC UCAs | Durobumps
Victory4x4 Rack, BajaRack Ladder, Full RCI Skids & Sliders
CaliRaisedLED Ditch Lights & Light Bar
mbm112 is offline   Reply With QuoteReply With Quote
Old 07-26-2022, 11:55 PM #3
Just learning about 16" not clearing calipers, didn't know that but was discounting 16" any way.
I was intending only considering wheels with +15mm offset to keep the tire positioned same as the original 20" Limited tire/rim combination and keeping the tire width and height same or very near original to avoid rubbing issues.
Thanks for the reply!
Old 07-27-2022, 07:37 AM #4
Bossman's Avatar
Bossman Bossman is offline
Bossman is a glorious beacon of light Bossman is a glorious beacon of light Bossman is a glorious beacon of light Bossman is a glorious beacon of light Bossman is a glorious beacon of light
Bossman's Avatar
Two helpful threads (if you have not already found them) from @1engineer
Changing Tire Size or Wheels? Read this first! - Toyota 4Runner Forum - Largest 4Runner Forum
Going Bigger - 5th Gen Tire Fitment Guide - Toyota 4Runner Forum - Largest 4Runner Forum
I run my 20" Limited rims on 245/60R20 Michelin all-seasons in the summer and run 17" TRD Off-Road rims with 265/70R17 Toyo dedicated winter tires in the winter.
Summer: Michelin Defender LTX 245/60R20 on OEM Limited 20" rims / Winter: Toyo Observe GSi-5 265/70R17 on 2018 TRD Off-Road 17" rims.
Bossman is offline   Reply With QuoteReply With Quote
Old 07-27-2022, 08:41 AM #5
Any SR5 of TRD Off-road wheel is going to be +15. My point being OEM wheels get as aggressive as +4 and will have very very minimal issues with rubbing. Almost nonexistent if you stick with highway tires as opposed to all terrains.
Old 07-27-2022, 09:26 AM #6
Humble Leader's Avatar
my $0.02:
stick with the 17" rim and 265/70/17 tire size. that is the spec of the non limited models. the 265/70/17 and the limited tires are basically identical in diameter. any larger tire and you will probably have rubbing issues
you may have some very slight rubbing if you run falkens or very aggressive AT tires and a rim with a +4 offset or less (TRD PRO spec). the TRD rims are +15 offset I believe and should be fine
rules of thumb for no lift:
-17" rim +4 offset no less
- 265/70/17 tire size
- mostly all AT tires will be fine with no rub. minor rubbing could occur with some brands which is easily remedied by a heat gun and sort of reshaping the fender liner/maybe front mud flap plastic as well
I swapped my 20" limited rims out. have 17" rims with +5 offset and 265 tire size. no rub obviously but I have M+S tires outside the winter season, I don't need AT
Old 07-27-2022, 10:46 AM #7
Pedro367 Pedro367 is offline
Pedro367 is a name known to all Pedro367 is a name known to all Pedro367 is a name known to all Pedro367 is a name known to all Pedro367 is a name known to all Pedro367 is a name known to all
Originally Posted by Humble Leader View Post
my $0.02:
What he said. Don't overthink it.
Pete - 2018 Silver TRDORP w/ KDSS. 2" Fox 2.0s and 285/70r17 Maxxis Razr ATs
Pedro367 is offline   Reply With QuoteReply With Quote
Old 07-28-2022, 01:54 PM #8
Grug556's Avatar
Grug556 Grug556 is offline
Grug556 is a jewel in the rough Grug556 is a jewel in the rough Grug556 is a jewel in the rough
Grug556's Avatar
Do this. On my limited I had some rub on drivers side with K02s in 17-265-70.
Rub was minor but easily correctable. Granted depending upon width of rim and offset, you may have more or less rub.
Grug556 is offline   Reply With QuoteReply With Quote
Old 10-23-2022, 10:02 AM #9
EdwardPerez EdwardPerez is offline
EdwardPerez is on a distinguished road
Thanks for sharing the video. I enjoy it By the way i am looking for a website which helps me to write my essay and i am searching it online and then i found a website writinguniverse.com/free-essay-examples/fahrenheit-451/ which helps me to write an essay easily and it will be helps me to write an essay easily.
EdwardPerez is offline   Reply With QuoteReply With Quote
Old 10-24-2022, 12:19 PM #10
Toffees's Avatar
Toffees Toffees is offline
Real Name: Micah
Toffees will become famous soon enough Toffees will become famous soon enough
Toffees's Avatar
Real Name: Micah
So, what did you get? Pics and tell us your experience.
(Short answer is get some TRD ORP wheels after someone upgrades, these are 17s and fit your vehicle already, but I'm interested in what you decided to do.)
Toffees is offline   Reply With QuoteReply With Quote
Old 10-24-2022, 10:55 PM #11
stiles_s stiles_s is offline
stiles_s will become famous soon enough stiles_s will become famous soon enough
This ^^ is exactly what I did and couldn't be happier. I think they look great on the Limited and I like the improved ride.
'22 4runner Limited (ORP 17s)
'18 MacanS (wife's)
'10 997S
stiles_s is offline   Reply With QuoteReply With Quote
limited , offset , tire , tires , toyota
FS: OEM Limited Wheel and Spare Tire - Los Angeles, CA - $50 Paw_Rnr For Sale: Suspension/Wheels/Tires 0 12-30-2020 04:08 AM
5th gen limited spare wheel/tire $135 DFW,TX clweathers For Sale: Suspension/Wheels/Tires 0 11-07-2017 03:42 PM
FS-5th gen-'15 Limited wheel/tire takeoffs-$950. Billings, MT wanderMT For Sale: Suspension/Wheels/Tires 0 12-18-2016 11:42 AM
4th Gen Rim & Tire Summary Thread Luxury Engines / Suspension / Wheels / Tires / Audio / Accessories 28 12-21-2004 10:14 AM
