Old 07-31-2022, 12:41 PM #16
repo repo is offline
repo is a glorious beacon of light repo is a glorious beacon of light repo is a glorious beacon of light repo is a glorious beacon of light repo is a glorious beacon of light
Originally Posted by Ali0227 View Post
Funny, I just updated an older post today on the steering wheel vibration at speeds of around 65 mph. This may be purely coincidental, but after having 2 sets of Bridgestone tires (one set was the original and experienced vibration on both sets), I decided to try Michelin and I couldn’t be happier. Vibration gone and driving on the highway is now a pleasure, ride is smooth as glass even at 90 mph. The second set and the 3rd being the Michelins were both put on by different Costcos and the 2nd set was put on in 09”. At the time, I didn’t know about the certain balancing machines the balance tires correctly, so I can’t speak to balancing machines at Costco. Just know I’ve never been happier with the ride especially in highway.
Did you have them all at the same psi the whole time or are these new ones higher? I notice different shops have different ideas about psi. Big O had my old set of E KO2s at 48psi when they installed them.
99 SR5 v6 4WD
11 SR5 v6 4WD
repo is offline   Reply With QuoteReply With Quote
Old 07-31-2022, 04:10 PM #17
BlackWorksInc's Avatar
BlackWorksInc BlackWorksInc is offline
BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold
Originally Posted by Jeremy556 View Post
The front drive shaft, that isn't spinning, was causing a vibration?
Tire's weren't properly balanced, which this vehicle is incredibly sensitive to, and has been for 20 years now.
We oddly enough have had a couple CV axles on newer Toyotas causing an odd vibration/shake (I believe it was a Camry and two Rav4's IIRC?), not sure what about the axle was causing the issue (wasn't a horrible vibration/shake, but just enough to be annoying on a new vehicle).
From what I recall when one of our coworkers got a brand new TRD PRO and went through this similar ordeal; the port that was converting/finishing TRD PRO vehicles had issues with the calibration of their balancer and it meant just about every damn TRD PRO for a good run had some form of balance issue.
I will also note that I have no idea if it's due to the supply/current issues in global manufacturing; but I have noticed an increase in mainly tires, but a couple wheels being just garbage out of the box. You'll road force them and the run out on the wheel is just way out or the tire won't roadforce below 50-60ft.lbs no matter how you turn it on the wheel. It used to be easy to tell which ones were the brands that'd give you the most trouble when you go with their AT/MT's (a Romani curse upon you Micky Thompson and Dura-Trac!), but it seems everyone is popping out more wonky tires these days.
BlackWorksInc is offline   Reply With QuoteReply With Quote
Old 07-31-2022, 04:11 PM #18
Deuxdiesel Deuxdiesel is offline
Deuxdiesel has a spectacular aura about Deuxdiesel has a spectacular aura about
Originally Posted by 02SE View Post
The skill of the person doing the balance job matters. Some are hacks, others simply don't know what they're doing. Ask for someone with lots of experience, who knows how to use the machine to it's full capability.
There's also the possibility you just got a tire or tires with poor uniformity, in which case they should be replaced.
"All of our installers are experienced experts"- DT management.
I'm done with DT. In six years, I've had 9 or 10 sets of tires installed at my local DT. I have an expensive set of Motegi wheels on my 4R now because they gouged up my ORP wheels and replaced them (didn't get to keep the damaged wheels) plus they damaged the wheels on my wife's GTI. I made them replace them with wheels through the VW dealership, not OEM knock-offs. I did get to keep the damaged ones for winter use.
Deuxdiesel is offline   Reply With QuoteReply With Quote
Old 08-01-2022, 10:30 AM #19
KM1.8T KM1.8T is offline
KM1.8T is on a distinguished road
We have good results with Michelin tires, no balancing issues on our 2017 20" on the Limited. I think you do get what you pay for when it comes to tires.
KM1.8T is offline   Reply With QuoteReply With Quote
Old 08-02-2022, 09:19 AM #20
PNWscott's Avatar
PNWscott PNWscott is offline
PNWscott is on a distinguished road
PNWscott's Avatar
Another take on the issue...replacing the needle bearing in the front diff where the CV axles connect. I don't know if it's the correct answer, but seems legit. Thoughts?
https://www.youtube.com/watch?v=nllcwqI1YVIx&feature=youtu.be
Sent from my SM-N975U using Tapatalk
-PNWscott
'18 SR5
PNWscott is offline   Reply With QuoteReply With Quote
Old 08-12-2022, 08:40 AM #21
<<<<'s Avatar
<<<< <<<< is offline
<<<< is just really nice <<<< is just really nice <<<< is just really nice <<<< is just really nice <<<< is just really nice
<<<<'s Avatar
I finally fixed my shake. Long story's short version: all tires balanced perfectly every time, one was out of circle with high spot found by road force balancing but mostly by observing tire spinning during balancing. It takes observant and honest tire shop tech to spot such a small but important issue.
<<<< is offline   Reply With QuoteReply With Quote
Old 08-12-2022, 02:46 PM #22
CutthroatSlam CutthroatSlam is offline
CutthroatSlam is a splendid one to behold CutthroatSlam is a splendid one to behold CutthroatSlam is a splendid one to behold CutthroatSlam is a splendid one to behold CutthroatSlam is a splendid one to behold CutthroatSlam is a splendid one to behold CutthroatSlam is a splendid one to behold CutthroatSlam is a splendid one to behold
With 302K miles on a 2014 SR5, I've dealt with the wheel shake issue repeatedly. Road force balance is a must. The more aggressive the tire tread, the more important this becomes. If this shake is allowed to go on over extended time, you will wear out tie rods. When this happens, you will get steering wheel shake when braking from 60 or 70 down to 30 to 40. It's on the level of a death wobble and it is not cause by rotors. Tires just a bit out of balance, brakes grabbing the rotors and the whole violent shake starts. Inspection by a top drawer independent mechanic revealed slight wear on the inner tie rods. Outers were already replaced. New tires cleaned most of it up. New inner tie rods going in when mechanic returns from vacation as there are special tools involved to remove and install.
CutthroatSlam is offline   Reply With QuoteReply With Quote
Old 08-12-2022, 05:31 PM #23
Matt831 Matt831 is offline
Matt831 will become famous soon enough
At what mileage did you replace the outers?
Matt831 is offline   Reply With QuoteReply With Quote
Old 08-12-2022, 05:35 PM #24
FoxtrotRomeo FoxtrotRomeo is offline
FoxtrotRomeo is on a distinguished road
Hmmm - I am new here - but not new to Toyota, owned them since the late 1980s.
Most recent was a 2013 FJ Cruiser Trail Teams (bought new), had the TRD wheels. I had a bit of shake, not too much, I could live with it. Sold it about 15 months ago, got $6k more than I paid for it.
Looking at a new 2022 (maybe 23) 4 Runner TRD Off Road Premium with the TRD wheels, would not exclude a TRD Pro.
How prevalent is the shake on the TRD wheels? We had the same issue on the FJ Cruisers. Test drive at highway speeds before purchasing?
I wish they had this fixed by now.
FoxtrotRomeo is offline   Reply With QuoteReply With Quote
Old 08-12-2022, 06:00 PM #25
Happens on every trim level.
Old 08-12-2022, 06:01 PM #26
Thanks Matt - every wheel option has shake issues? Or only the TRD wheels?
Add -every wheel option has the recorded shake issues?
Old 08-12-2022, 07:09 PM #27
About 290K to 295K. They were not in bad condition, but it does not take much. Every wear piece is additive to front end issues.
Old 08-12-2022, 07:12 PM #28
Every wheel option, does not matter. The steering system is highly sensitive to improperly balanced tires.
Old 08-12-2022, 07:27 PM #29
I had CV axles on a 2005 Honda Accord cause steering wheel pulse under heavy acceleration from 40 to 70 mph.
Old 08-15-2022, 01:24 PM #30
AppleIsSkynet AppleIsSkynet is offline
Real Name: Michael
AppleIsSkynet is on a distinguished road
Real Name: Michael
Y’all go back and read the update to the update post. The OP made a mistake and it wasn’t the front axel but the rear.
Very Respectfully,
Michael
AppleIsSkynet is offline   Reply With QuoteReply With Quote
interesting , outcome , someone’s , steering , wheel
Steering Wheel Shake sport2004 4th Gen T4Rs 11 11-18-2021 12:24 PM
Steering Wheel Shake stever1000 3rd gen T4Rs 52 10-30-2021 03:04 PM
Steering wheel and car shake Duke562 5th gen T4Rs 16 10-08-2016 09:42 AM
Possible fix for the steering wheel shake 68ChargerJMP 3rd gen T4Rs 3 01-08-2016 03:56 PM
Steering Wheel Shake nvestor88 3rd gen T4Rs 10 07-13-2014 01:40 PM
