07-31-2022, 12:41 PM
#16
Originally Posted by Ali0227
Funny, I just updated an older post today on the steering wheel vibration at speeds of around 65 mph. This may be purely coincidental, but after having 2 sets of Bridgestone tires (one set was the original and experienced vibration on both sets), I decided to try Michelin and I couldn’t be happier. Vibration gone and driving on the highway is now a pleasure, ride is smooth as glass even at 90 mph. The second set and the 3rd being the Michelins were both put on by different Costcos and the 2nd set was put on in 09”. At the time, I didn’t know about the certain balancing machines the balance tires correctly, so I can’t speak to balancing machines at Costco. Just know I’ve never been happier with the ride especially in highway.
Did you have them all at the same psi the whole time or are these new ones higher? I notice different shops have different ideas about psi. Big O had my old set of E KO2s at 48psi when they installed them.
99 SR5 v6 4WD
11 SR5 v6 4WD
07-31-2022, 04:10 PM
#17
Originally Posted by Jeremy556
The front drive shaft, that isn't spinning, was causing a vibration?
Tire's weren't properly balanced, which this vehicle is incredibly sensitive to, and has been for 20 years now.
We oddly enough have had a couple CV axles on newer Toyotas causing an odd vibration/shake (I believe it was a Camry and two Rav4's IIRC?), not sure what about the axle was causing the issue (wasn't a horrible vibration/shake, but just enough to be annoying on a new vehicle).
From what I recall when one of our coworkers got a brand new TRD PRO and went through this similar ordeal; the port that was converting/finishing TRD PRO vehicles had issues with the calibration of their balancer and it meant just about every damn TRD PRO for a good run had some form of balance issue.
I will also note that I have no idea if it's due to the supply/current issues in global manufacturing; but I have noticed an increase in mainly tires, but a couple wheels being just garbage out of the box. You'll road force them and the run out on the wheel is just way out or the tire won't roadforce below 50-60ft.lbs no matter how you turn it on the wheel. It used to be easy to tell which ones were the brands that'd give you the most trouble when you go with their AT/MT's (a Romani curse upon you Micky Thompson and Dura-Trac!), but it seems everyone is popping out more wonky tires these days.
07-31-2022, 04:11 PM
#18
Originally Posted by 02SE
The skill of the person doing the balance job matters. Some are hacks, others simply don't know what they're doing. Ask for someone with lots of experience, who knows how to use the machine to it's full capability.
There's also the possibility you just got a tire or tires with poor uniformity, in which case they should be replaced.
"All of our installers are experienced experts"- DT management.
I'm done with DT. In six years, I've had 9 or 10 sets of tires installed at my local DT. I have an expensive set of Motegi wheels on my 4R now because they gouged up my ORP wheels and replaced them (didn't get to keep the damaged wheels) plus they damaged the wheels on my wife's GTI. I made them replace them with wheels through the VW dealership, not OEM knock-offs. I did get to keep the damaged ones for winter use.
08-01-2022, 10:30 AM
#19
We have good results with Michelin tires, no balancing issues on our 2017 20" on the Limited. I think you do get what you pay for when it comes to tires.
08-02-2022, 09:19 AM
#20
Another take on the issue...replacing the needle bearing in the front diff where the CV axles connect. I don't know if it's the correct answer, but seems legit. Thoughts?
https://www.youtube.com/watch?v=nllcwqI1YVIx&feature=youtu.be
Sent from my SM-N975U using Tapatalk
-PNWscott
'18 SR5
08-12-2022, 08:40 AM
#21
I finally fixed my shake. Long story's short version: all tires balanced perfectly every time, one was out of circle with high spot found by road force balancing but mostly by observing tire spinning during balancing. It takes observant and honest tire shop tech to spot such a small but important issue.
08-12-2022, 02:46 PM
#22
With 302K miles on a 2014 SR5, I've dealt with the wheel shake issue repeatedly. Road force balance is a must. The more aggressive the tire tread, the more important this becomes. If this shake is allowed to go on over extended time, you will wear out tie rods. When this happens, you will get steering wheel shake when braking from 60 or 70 down to 30 to 40. It's on the level of a death wobble and it is not cause by rotors. Tires just a bit out of balance, brakes grabbing the rotors and the whole violent shake starts. Inspection by a top drawer independent mechanic revealed slight wear on the inner tie rods. Outers were already replaced. New tires cleaned most of it up. New inner tie rods going in when mechanic returns from vacation as there are special tools involved to remove and install.
08-12-2022, 05:31 PM
#23
At what mileage did you replace the outers?
08-12-2022, 05:35 PM
#24
Hmmm - I am new here - but not new to Toyota, owned them since the late 1980s.
Most recent was a 2013 FJ Cruiser Trail Teams (bought new), had the TRD wheels. I had a bit of shake, not too much, I could live with it. Sold it about 15 months ago, got $6k more than I paid for it.
Looking at a new 2022 (maybe 23) 4 Runner TRD Off Road Premium with the TRD wheels, would not exclude a TRD Pro.
How prevalent is the shake on the TRD wheels? We had the same issue on the FJ Cruisers. Test drive at highway speeds before purchasing?
I wish they had this fixed by now.
08-12-2022, 06:00 PM
#25
Happens on every trim level.
08-12-2022, 06:01 PM
#26
Thanks Matt - every wheel option has shake issues? Or only the TRD wheels?
Add -every wheel option has the recorded shake issues?
08-12-2022, 07:09 PM
#27
About 290K to 295K. They were not in bad condition, but it does not take much. Every wear piece is additive to front end issues.
08-12-2022, 07:12 PM
#28
Every wheel option, does not matter. The steering system is highly sensitive to improperly balanced tires.
08-12-2022, 07:27 PM
#29
I had CV axles on a 2005 Honda Accord cause steering wheel pulse under heavy acceleration from 40 to 70 mph.
08-15-2022, 01:24 PM
#30
Real Name: Michael
Real Name: Michael
Y’all go back and read the update to the update post. The OP made a mistake and it wasn’t the front axel but the rear.
Very Respectfully,
Michael
Thread Tools |
Display Modes |
Rate This Thread |
Linear Mode
