Originally Posted by Firesq14
It is an 11, SR5 4x4. Wind shield, has been replaced and...... my glass guy installed a windshield with the wiper defrost option. Told him it did not have it and he said, the plug is there. I physically helped him and plugged the connector together myself. My runner did not come with that option. My thought is if the engine compartment wiring harness has the connector, why would not the cabin side have it? I checked the fuse box. There is no fuse, however, spade connectors are visible.
So, having stated all of this, would it be possible to add a harness if cannot locate the cabin side harness?
Chris
High current accessories, such as wiper heaters, always use a relay, so check to see if you have the relay. Best way to proceed is to get the wiring diagram for the wiper heater system, then do continuity checks from the existing wiring plug, relay, power source and the switch location.
Don't know if they have changed anything between years, but my 2018 4Runner has the switch for the wiper heaters on the panel to the left of the steering wheel.
