Old 07-30-2022, 03:12 PM #1
obxbird obxbird is offline
obxbird is on a distinguished road
Tint Sunroof???
I've done some research about tinting the sunroof and some have said that it may cause the glass to shatter because its trapping heat. Has anyone tinted their sunroof or heard of the glass breaking if you do? Thanks!
2021 4Runner TRD ORP: Bilstein 5100's all 4 corners, 1" Cornfed spacers in the rear, Firestone Air Bags rear, Poly bushings for sway bars, Scangauge 2, Vent Visors, Pro Comp 32 wheels and Wildpeaks 265-70R17 tires.
obxbird is offline   Reply With QuoteReply With Quote
Old 07-30-2022, 03:50 PM #2
mbm112 mbm112 is offline
mbm112 has a spectacular aura about mbm112 has a spectacular aura about mbm112 has a spectacular aura about
I’ve tinted the sunroof of every car I’ve had and never had any issues. I typically keep my sunshade closed too which should be trapping more heat against the glass.
2016 Limited 4WD Blizzard Pearl | Black
TRD Pro Sema | Toyo AT3 LT285/70/R17 C
Dobinsons IMS 302/700 and 505/705 | SPC UCAs | Durobumps
Victory4x4 Rack, BajaRack Ladder, Full RCI Skids & Sliders
CaliRaisedLED Ditch Lights & Light Bar
mbm112 is offline   Reply With QuoteReply With Quote
Old 07-30-2022, 04:07 PM #3
numbay numbay is offline
numbay will become famous soon enough
I got my sunroof tinted after I got it new, and within a month. Also got top windshield about 6 inches tinted. So far no issue, and loving it. I am in Seattle area.
numbay is offline   Reply With QuoteReply With Quote
Old 07-31-2022, 11:13 AM #4
DirtyMarcus DirtyMarcus is offline
DirtyMarcus will become famous soon enough
my sunroof is tinted. We've had a record 50 days of over 100 degree days this summer and nothing has happened to the glass.
DirtyMarcus is offline   Reply With QuoteReply With Quote
Old 08-01-2022, 01:15 PM #5
BobsTrail's Avatar
BobsTrail BobsTrail is offline
Real Name: BobH
BobsTrail is a name known to all BobsTrail is a name known to all BobsTrail is a name known to all BobsTrail is a name known to all BobsTrail is a name known to all BobsTrail is a name known to all
BobsTrail's Avatar
Real Name: BobH
Yes, tint the sunroof. I did mine with ceramic tint and it really helps reduce the incoming heat. Many 100+ day trips with no problem. I leave the shade open all the time to let in more light.
Did my other Toyota also no problem on a trip last week also with 100+ days.
The ceramic film keeps the heat out very well.
BobsTrail is offline   Reply With QuoteReply With Quote
Old 08-01-2022, 03:10 PM #6
chrisridebike8 chrisridebike8 is offline
chrisridebike8 will become famous soon enough
This. I didn't tint it. I had them put clear ceramic film since the stock color is already slightly tinted. The ceramic is crucial to heat rejection
2021 MGM 4Runner TRD Off Road, KDSS
Eibach | Falken | CaliRaised | Sherpa| Joe's | Rago | Odyssey | Redarc | Rigd | Waterport | Baja Designs | Diode Dynamics | MaxTrax | Level 8 | OVS | S-Tech | Midland | Dr. KDSS | ARB | JLT | Anzo
2022 MGM Corolla Hatchback 6-speed
2010 Black/Black C63 AMG, 460 whp (I miss this car every day)
chrisridebike8 is offline   Reply With QuoteReply With Quote
Old 08-01-2022, 03:42 PM #7
rangers1976 rangers1976 is offline
rangers1976 is on a distinguished road
Same here, central TX is going thru a shitty summer as far as high temps and zero rain.
I tinted mine to 20% last summer, and no issues. I usually keep the slider closed unless I'm using the sunroof.
rangers1976 is offline   Reply With QuoteReply With Quote
Old 08-01-2022, 04:41 PM #8
Whippersnapper02's Avatar
I keep my shade closed all the time but may do it for more head rejection. I'd like to do all the windows at some point with ceramic.
Old 08-01-2022, 10:17 PM #9
CRasch505 CRasch505 is offline
CRasch505 is on a distinguished road
We tinted every piece of glass on ours with ceramic including the sunroof. It eliminates almost all the heat and is definitely worth the extra cost over standard. Couldn't be happier. Just our 2 cents!
CRasch505 is offline   Reply With QuoteReply With Quote
Old 08-05-2022, 07:54 PM #10
Ezlife45 Ezlife45 is offline
Ezlife45 will become famous soon enough
I wanted to have mine done and my tint shop refused to do it claiming the infamous exploding sunroof. Wish they would have done it.
Ezlife45 is offline   Reply With QuoteReply With Quote
Old 08-05-2022, 08:58 PM #11
chester4Run chester4Run is offline
chester4Run is on a distinguished road
I had ceramic limo tint put on my sunroof the week I got it. It’s seen 12 years of FL sun without issue. I’ve done similar on every vehicle I’ve had with a sunroof.
2011 SR5 4wd
2004 SR5 4wd
1994 SR5 4wd (SOLD)
chester4Run is offline   Reply With QuoteReply With Quote
glass , heat , sunroof , tint , tinted
Spray tint or film tint on lights? BigMike18 4th Gen T4Rs 9 12-04-2019 11:31 PM
Waxed and what 20% tint looks like over factory tint Lineman Maintenance/Detailing 6 10-21-2013 01:31 PM
1991 Hilux Surf tint (4runner tint removal) bia Classic T4Rs 7 02-28-2013 03:34 PM
Tint question (need to match factory tint) Susan 5th gen T4Rs 1 08-17-2010 11:50 PM
