Old 07-31-2022, 02:50 PM #1
bling bling is offline
bling is on a distinguished road
TRD PRO Roof Rack removal
If I buy a TRD PRO and remove the rack (not a fan), do the holes line up to install the regular roof rack rails from the other models?
bling is offline   Reply With QuoteReply With Quote
Old 07-31-2022, 04:03 PM #2
Deuxdiesel Deuxdiesel is offline
Deuxdiesel has a spectacular aura about Deuxdiesel has a spectacular aura about
Yes, but the Pro rack uses Torx-style head bolts not regular bolts. Lots of videos on rack removal and installation, but just be careful to turn out the bolts a little at a time, alternating between each bolt. And use a ratchet wrench, not an impact driver.
Deuxdiesel is offline   Reply With QuoteReply With Quote
Old 07-31-2022, 05:11 PM #3
agloukhoff's Avatar
agloukhoff agloukhoff is offline
agloukhoff is on a distinguished road
agloukhoff's Avatar
I cannot stress enough how important it is to use the correct torx (T40) and not taking the bolts out until both are loose - else the bracket will rotate.
If you are not using T25s, you will strip the heads - do not fight the bolts. If they are not moving - heat them up to break the threadlock. If you try to force these out you will either strip the bolt or break the head off - plenty of people have done exactly that.
https://www.youtube.com/watch?t=392&v=PgPk-Q7iMJo&feature=youtu.be
Don't be this guy.
agloukhoff is offline   Reply With QuoteReply With Quote
Old 08-01-2022, 09:25 AM #4
fkheath fkheath is offline
fkheath is a splendid one to behold fkheath is a splendid one to behold fkheath is a splendid one to behold fkheath is a splendid one to behold fkheath is a splendid one to behold fkheath is a splendid one to behold
Yes, the hole line up. I did the opposite: removed the regular roof rack and installed the TRD which I got for a bargain on Ebay.
Just be aware that the sealing washers are very thin and prone to leak, thus when you swap out the racks, be sure to use some kind of added sealant to prevent leaks. I used a high quality, long life silicone sealant.
fkheath is offline   Reply With QuoteReply With Quote
Old 08-01-2022, 09:32 AM #5
KiwiCan KiwiCan is offline
KiwiCan is on a distinguished road
What was toyota thinking putting that abomination up there?
KiwiCan is offline   Reply With QuoteReply With Quote
Old 08-01-2022, 02:45 PM #6
Originally Posted by agloukhoff View Post
I cannot stress enough how important it is to use the correct torx (T25) and not taking the bolts out until both are loose - else the bracket will rotate.
Don't be this guy.
Thank you all for the solid info. I really appreciate it!
Old 08-01-2022, 03:23 PM #7
They were thinking "it looked good on the Xterra".
Old 08-02-2022, 10:54 AM #8
Actually it is a derivative of the FJ Cruiser rack. They stopped importing the Fj Cruiser into the US in 2014, sad to say. I still see lots of them around.
Old 08-04-2022, 07:01 PM #9
Sempre Nissart Sempre Nissart is offline
Sempre Nissart is on a distinguished road
Don't be this guy.
It’s actually T40 that needs to be used. The rest is all correct!
Sempre Nissart is offline   Reply With QuoteReply With Quote
Old 08-05-2022, 02:24 PM #10
agloukhoff's Avatar
agloukhoff's Avatar
Shit - updated the post.
Old 08-05-2022, 04:18 PM #11
Whippersnapper02's Avatar
People put ugly racks on there all the time so just fitting in with the market.
line , pro , rack , roof , trd
Roof rack removal Southkhaki 4th Gen T4Rs 4 12-16-2012 08:06 PM
Is there a DIY out there on roof rack removal? SummerallGuard04 3rd gen T4Rs 11 08-14-2012 07:04 PM
Roof Rack Removal Help :( Shoke 3rd gen T4Rs 9 10-31-2009 06:45 PM
Roof Rack Removal kinchy General Discussions 2 05-08-2009 11:06 PM
