Old 08-08-2022, 01:09 AM #1
HamSnacks HamSnacks is offline
HamSnacks is on a distinguished road
Driver Heated Seat Not Working
2011 Limited
Driver's side isn't working, the little amber light does not come on. Checked the fuses, checked the plugs underneath the seat as best I could, just made sure nothing was unplugged.
Is it common for the actual switch to go bad? Don't want to buy a $120 switch and it turns out not to be the issue.
Any other things to check?
Passenger side works great.
Thanks
HamSnacks is offline   Reply With QuoteReply With Quote
Old 08-08-2022, 08:01 AM #2
Bossman's Avatar
Bossman Bossman is offline
Bossman is a glorious beacon of light Bossman is a glorious beacon of light Bossman is a glorious beacon of light Bossman is a glorious beacon of light Bossman is a glorious beacon of light
Bossman's Avatar
Maybe some tips in this 4th Gen thread (I had the driver's side seat heater stop working on my 03 Limited).
Troubleshooting Heated Seat
It could be that simply the amber bulb in the switch is burnt out, but it likely is the switch. I would also check the connection at the switch (center console) first before ordering a replacement.
Summer: Michelin Defender LTX 245/60R20 on OEM Limited 20" rims / Winter: Toyo Observe GSi-5 265/70R17 on 2018 TRD Off-Road 17" rims.
Bossman is offline   Reply With QuoteReply With Quote
Old 08-08-2022, 09:31 AM #3
fkheath fkheath is offline
fkheath is a splendid one to behold fkheath is a splendid one to behold fkheath is a splendid one to behold fkheath is a splendid one to behold fkheath is a splendid one to behold fkheath is a splendid one to behold
Originally Posted by HamSnacks View Post
2011 Limited
Thanks
Swap the switch for the driver's side with the passenger's side. If the problem changes to the other side, it is the switch. If not, it could be the relay or wiring.
fkheath is offline   Reply With QuoteReply With Quote
Old 08-08-2022, 12:31 PM #4
I'll take a look, thank you.
What's annoying is that they're 2 different plugs, I took them both out, they can't be plugged into the other seat.
Old 08-08-2022, 01:59 PM #5
spartacus's Avatar
spartacus's Avatar
You can also use a multi meter and test the function of the switch by probing the pins in the connector.
Old 08-13-2022, 03:04 AM #6
Just thought I'd update this in case anyone in the future had the same problem.
So I pulled out the Driver's heated switch, unplugged it and then took it apart, it's fairly easy to pull apart, just need a flat head and have to run it along 1 side. I realized there was a little gold metal piece that was out of place, it sits on a plastic piece near the dial. I had to bend the board back a bit to make some room and then simply Krazy glued the metal piece where it was supposed to sit. Just like that, working again. If anyone ever runs into that problem and needs more detailed instructions, send me a PM.
Thank you
Old 08-13-2022, 10:42 AM #7
Muskrat14's Avatar
Muskrat14 Muskrat14 is offline
Real Name: Dave
Muskrat14 will become famous soon enough
Muskrat14's Avatar
Real Name: Dave
As a kid, my dad would make me watch him trouble shoot electrical circuits on all his old cars. Boring fkr me. Now I wish I would’ve paid attention. Don’t know squat!
Muskrat14 is offline   Reply With QuoteReply With Quote
Old 08-13-2022, 08:44 PM #8
czgunner czgunner is offline
czgunner is on a distinguished road
Unplug the heater grid and ohm check it. If it show open/infinite your grid is bad. If it's OK, good chance the switch is bad. Pretty simple to test to see if there is voltage coming out of the switch when you turn it on.
Sent from my Pixel 3 using Tapatalk
czgunner is offline   Reply With QuoteReply With Quote
Old 02-20-2023, 12:06 PM #9
11 4Runner 11 4Runner is offline
11 4Runner is on a distinguished road
Thank you
Hey running into same problem can you detail more about how you did this, does the circuit board pop out?
11 4Runner is offline   Reply With QuoteReply With Quote
Old 02-20-2023, 07:36 PM #10
CutthroatSlam CutthroatSlam is offline
CutthroatSlam is a splendid one to behold CutthroatSlam is a splendid one to behold CutthroatSlam is a splendid one to behold CutthroatSlam is a splendid one to behold CutthroatSlam is a splendid one to behold CutthroatSlam is a splendid one to behold CutthroatSlam is a splendid one to behold CutthroatSlam is a splendid one to behold
2011 Limited
Thanks
I know you got it fixed, but just so you know, there are other options than Toyota’s $120 switch:
Motosupply A Pair Rectangle Hi-Off-Low Seat Heater Switch Left and Right Heat Control Switch
CutthroatSlam is offline   Reply With QuoteReply With Quote
Old 02-20-2023, 07:52 PM #11
Captain Spalding's Avatar
Captain Spalding Captain Spalding is offline
Captain Spalding has a spectacular aura about Captain Spalding has a spectacular aura about Captain Spalding has a spectacular aura about
Has anyone tried these? The rotary switches are annoyingly easy to turn on by accident and it might be worth the $20 to avoid the aggravation.
Captain Spalding is offline   Reply With QuoteReply With Quote
Old 02-20-2023, 08:08 PM #12
They came with my seat heater kit and they work great.
Driver Heated Seat Not Working-3ec11e4d-b905-4694-b448-2749ed468430-jpeg
Old 02-21-2023, 04:14 AM #13
They look good. Any idea how to mate them to the factory wiring? It says above that the factory switches aren’t wired the same.
Old 02-21-2023, 08:04 PM #14
No, but it should be easy to figure out. Post #184 has some pics of my wiring. It’s all simple plugs.
Seat Heater Install
Old 02-22-2023, 04:01 PM #15
Thanks. But judging by this wiring diagram, I’m going to have more wires than I know what to do with.
checked , seat , side , switch , working
Heated Seat Not Working briansturgeon 5th gen T4Rs 2 02-23-2022 12:30 PM
2001 limited drivers heated seat not working OffroadTwin 3rd gen T4Rs 0 10-10-2021 03:42 PM
WTB good condition 4th gen heated/powered driver's seat Roody Want to Buy/Trade 0 09-12-2017 03:24 PM
Heated front driver seat? lmnowires General Discussions 0 06-05-2010 10:49 AM
Warm driver seat.. I do not have heated seats? frohbego 3rd gen T4Rs 5 08-27-2006 04:35 PM
