Old 01-01-2024, 02:02 AM #1
coltm4's Avatar
coltm4 coltm4 is offline
coltm4 is on a distinguished road
coltm4's Avatar
Worn spherical bearings, rebuilding shocks
So.... rebuildable shocks need to be rebuilt. Don't be like me and let it get too far gone. These are 4 year old Kings with about 80k on them. What finally drove me to rebuild was the squeaking. The front lower bearings were corroded and worn ,the rear lower bearings were nearly seized from the rust, but due to less movement the wear was nearly nonexistent.
More impressively though, the O-rings and oil were still in decent condition. Needless to say, regular anticorrosion lube will be used frequently.
[img]https://i.ibb.co/j4d81mQ/IMG-
2016 QUICKSAND TRD PRO,Rear diff breather mod, Salex organizers, Huskyliners, CBI sliders, RCI TRD intermediate skid plate, RCI aluminum transmission skid plate, RCI STEEL transfer case skid, RCI Aluminum fuel skid and A arm skid. RagoFab modular storage panel. King extended travel front and rear with compression adjusters. 2" Toytec superflex rear springs.
coltm4 is offline   Reply With QuoteReply With Quote
Old 01-02-2024, 02:48 PM #2
Xtremluck's Avatar
Xtremluck Xtremluck is offline
Xtremluck is a splendid one to behold Xtremluck is a splendid one to behold Xtremluck is a splendid one to behold Xtremluck is a splendid one to behold Xtremluck is a splendid one to behold Xtremluck is a splendid one to behold Xtremluck is a splendid one to behold
Xtremluck's Avatar
This is a great call out and had to replace my spherical bearings as well on my KING setup with 30,000 miles / 3 yrs. I dont think you need to do a full rebuild for a very long time. This is also with very heavy offroad use.
'12 Silver 4Runner SR5: 14+ facelift, CBI front, CBI Rear, Warn EVO 10-S, ARB Snorkel, Baja Designs 30" S8, Squadron Sports, S2 Rack Lights, King 2.5 Suspension, OME 899, 33" Cooper ST Maxx, Full CBI Skids, Metaltech Sliders, GFC Tent, ARB Awning
Xtremluck's 2012 SR5 Build Thread
Xtremluck is offline   Reply With QuoteReply With Quote
Old 01-03-2024, 08:38 AM #3
HiluxSurf SSR-G's Avatar
HiluxSurf SSR-G HiluxSurf SSR-G is offline
HiluxSurf SSR-G will become famous soon enough HiluxSurf SSR-G will become famous soon enough
what's the reason why spherical bearings are used in lieu of rubber/PU bushings?
HiluxSurf SSR-G is offline   Reply With QuoteReply With Quote
Old 01-03-2024, 11:39 AM #4
Jeremy556's Avatar
Jeremy556's Avatar
Cheap and easy to build. Grab an $8 standard bearing and machine a couple of misalignment spacers to fit the application and you're done.
Old 01-03-2024, 01:44 PM #5
Jetboy's Avatar
Jetboy Jetboy is offline
Jetboy's Avatar
Were you able to remove the lower mount bolt on the front without having to cut them out? Even after as little as a year, I would have to cut mine out when re-building them. I'd have to cut through the misalignments and the lower mount bolt to get them free. Seemed to be the case regardless of what coating I used or how much penetrating oil I applied. It was mostly an annoyance because it adds a bit of work and then I'd have to spend another $40 on spacers and wait a day or two to get them shipped to me.
It was the noise that always forced me to do them too. It would get so noisy it was embarrassing. My best attempted solution was rubber boots for the lower shock ends. That seemed to extend life a long time on the bearing. I never really had issues with the uppers. So I think the wear was primarily environmental. Oddly the rears never had issues. Just the front lowers.
These guys: They can be a real PITA to get on though. Apparently there's a specialty tool for it. I don't have one, but it looks like a good idea.
bearings , lower , nonexistent , shocks , worn
Is it worth rebuilding rear Icon 2.0 shocks... LOSTR4 Engines / Suspension / Wheels / Tires / Audio / Accessories 2 12-28-2021 02:00 PM
Icon Spherical Bearings - Diagnosis tral 5th gen T4Rs 2 11-04-2019 02:08 PM
Looking for advice: rebuilding spindles+new bearings+seals (4WD) BamaDrewski 3rd gen T4Rs 13 06-20-2019 10:55 AM
Worn out suspension, will new shocks be enough? T4Life 3rd gen T4Rs 12 12-16-2018 11:09 AM
COM10T or FKS10T spherical bearings Johnson51 Engines / Suspension / Wheels / Tires / Audio / Accessories 1 06-13-2017 05:14 PM
