08-08-2022, 10:00 PM
Real Name: John
Real Name: John
Dual smart usb to replace cla - pt976-03201
I recently discovered that Toyota makes a fantastic part to add new technology to the future classic OG Trail Edition, being the OEM dual smart USB to replace the 12V cigar lighter adapter. Most importantly, I was able to confirm it is plug and play for the 2012 Toyota 4Runner which most likely indicates it will work on all years of the 5th Generation Toyota 4Runner. The most difficult decision was deciding if it should replace the front console, inside the glove box, or the rear cargo hatch.
2012 T4R Trail Edition Magnetic Gray~KDSS~Cooper STT Pro 285/70R17•Pilot stubby•3M Door Guards•WeatherTechs•Console Vault•Canvasback Liner•Interior LED upgrade•BudBuilt BumpOut Sliders and full skids•ICON Extended Travel suspension•Rokmen lower links•ARB•Warn M8000•Southeast Overland rope~CBI rear bumper
08-08-2022, 11:27 PM
That's all we get? No install instructions?
08-09-2022, 08:26 AM
More Info?
08-09-2022, 10:45 AM
I put mine in the center console storage to replace the cig lighter port.
2015 Magnetic Gray SR5P
08-09-2022, 10:51 AM
08-09-2022, 08:54 PM
Real Name: John
Real Name: John
That part number requires tapping into factory wires that is referenced in that link while this part number is 100% plug and play directly into the factory harness for the 12v adapter.
08-09-2022, 09:04 PM
Real Name: John
Real Name: John
Sorry no instructions yet. I merely tested that the harness would be plug and play last night in my 12 T4R by access the rear hatch cigar lighter plug.
This weekend, I will get the tool to remove the Cigar Lighter Adapter and look into adding this to the glovebox CLA or under the dash. I have added a picture to include the harness on this particular part.
08-10-2022, 03:30 PM
If this is used in the dash to replace the single USB, what happens with Carplay if you connect 2 apples devices? (2 iphones, iphone and ipad, etc)
08-10-2022, 03:57 PM
Real Name: Brandon
Real Name: Brandon
This replaces the 12v.. Power only no data.
2016 Toyota 4Runner TEP + KDSS + RC
1971 Volvo 142e (Lovely brick with a tractor engine)
1977 International Scout II (Another brick tractor)
08-10-2022, 08:24 PM
Real Name: John
Real Name: John
This replaces the 12v cigarette lighter adapter and not the single USB in newer 4Runners. In my 4Runner my USB linked to the radio system is in the glove compartment and I have an old school "line in" beside my 12v power supply.
08-11-2022, 10:27 AM
Instructions: http://toyotaparts.sparkstoyota.com/...03201-4run.pdf
No special tool needed. Just a small screw driver.
01-01-2024, 03:52 PM
Originally Posted by fkheath
Looking at those instructions seems like a lot of work just to pull that out. I have done a few radio installs so familiar with pulling the dash apart but seems excessive for the usb install. Is all that required for the usb install?
‘24 ORP, '04 SR5 Pacific Blue, 2000 SR5 Black
01-03-2024, 01:43 PM
Personally I wouldn't bother doing this. There are plenty of very low profile 12V to dual USB adapters available that do a nice job. There's always the possibility you might want the 12V socket for example a GRMS radio that needs 12V.
