Old 08-19-2022, 09:08 AM #16
Pedro367 Pedro367 is offline
Pedro367 is a name known to all Pedro367 is a name known to all Pedro367 is a name known to all Pedro367 is a name known to all Pedro367 is a name known to all Pedro367 is a name known to all
Originally Posted by DallasTRDPro View Post
Worst tire I've ever had.
Agreed. Had Terra Grappler G2s twice in the past. Once on a 14 Grand Cherokee and again on my JKU. HORRIBLE in the rain and almost as loud as a mud tire.
Pete - 2018 Silver TRDORP w/ KDSS. 2" Fox 2.0s and 285/70r17 Maxxis Razr ATs
Pedro367 is offline   Reply With QuoteReply With Quote
Old 08-21-2022, 11:45 PM #17
Lexington's Avatar
Lexington Lexington is offline
Lexington is a jewel in the rough Lexington is a jewel in the rough Lexington is a jewel in the rough
Lexington's Avatar
I had these tires on my 4Runner too. I had my 4Runner slide and hydroplane on multiple occasion. Got rid of them and bought KO2s. Been driving smooth with no problems ever since
Lexington is offline   Reply With QuoteReply With Quote
Old 08-22-2022, 12:03 AM #18
Lexington's Avatar
Lexington's Avatar
Vehicle shaking at certain speeds is usually caused by tires that have worn unevenly. Itís usually cause from improper tire inflation, wheel is bumped out of alignment and not rotating the tires. If the wear is bad enough there is really nothing you can do except buy new tires. If they are new tires itís usually a tire that did not mold properly and weight has accumulated in one particular spot. If itís bad enough not even balancing can fix it. If your able to narrow it down to a specific tire you can take it back and ask for a new one. If not return the whole set.
Here are the trouble shooting steps I take. I try doing the cheapest stuff first. I test drive the vehicle between each step.
1. Check for proper tire inflation.
2. Rebalance the tires with road force.
3. Rotate the tire. I usually do this with the rebalance.
4. Do wheel alignment.
5. Have vehicle inspected by mechanics to see if there may be other causes.
If after all this and I still get vibrations then I buy new tires.
From my personal experience, when I bought new tires the shaking went away.
Old 08-22-2022, 10:02 AM #19
JAXJeremy's Avatar
JAXJeremy JAXJeremy is offline
Real Name: Jeremy
JAXJeremy has a spectacular aura about JAXJeremy has a spectacular aura about JAXJeremy has a spectacular aura about
JAXJeremy's Avatar
Real Name: Jeremy
Been happy with my G2s. Installed a set on my 2018 a few months back..I mainly work from home so I've got maybe 2500 miles on them with no issue..They're a bit louder than a normal tire, but not that bad..We've done several long highway drives of 200 miles or more, never had a vibration problem and been through several down pours with no hint of hydroplaning, or at least no more so than any other tire.
'18 SR5 4WD, magnetic gray metallic, stock, RCI front skid, LFD cross bars, Pedal Commander, Accessorides Remote Start.
JAXJeremy is offline   Reply With QuoteReply With Quote
Old 09-01-2022, 07:59 PM #20
Mark4runnar's Avatar
Mark4runnar Mark4runnar is offline
Mark4runnar will become famous soon enough
Originally Posted by rageandlove View Post
There are a bunch of threads on this. Like, many. Things I have read:
  • Tiers go flat when parked and it takes a while to smooth out. I have a 2019 Pro w the stock nittos that still does this.
  • Need a better balance. Road force balance often appears to be the solution.
  • One of the tires is bad and needs to be replaced.
  • Multiple tires are bad.
There is one thread in the last few weeks by someone that knew someone that had found a mechanical problem, but I can't find it.
JUST an update........Bristol Toyota has decided and received approval to replace all 4 Nitto's on my 2022 TRD PRO. They are really good to do business with
Mark4runnar is offline   Reply With QuoteReply With Quote
Old 09-01-2022, 08:04 PM #21
Update 9.1.22
Originally Posted by Mark4runnar View Post
I have owned several 3rd and 5th Gen 4runners. They have performed well in all conditions including highway driving.
This is my first TRD PRO.
At highway speeds there is a noticeable vibration (between 55 and 80).
It now has 2000 miles on it and the vibration has been consistent.
I took it back to the dealer last week and they said the tires needed to be balanced, which they did at no charge.......that has not solved the vibration.
When I called them today to ask them to revisit this problem......I started to here excuses......"well the TRD PRO has off road tires", "you can't expect a smooth ride".
It's going back next wed --- the service manager will drive it.
My question is-------- are there any other TRD PRO drivers out there that have had a similar situation.
I realize the Nitto's have a more aggressive tread ---- but the highway vibration
is a bit of an overhang. I do put a lot of highway miles on getting to and from the trails etc.
Any feedback would be helpful. If my expectation are way off "straight talk " is welcome???
BTW I love this thing!!!!!
.mc
UPDATE:
JUST a quick update........Bristol Toyota has decided and received approval to replace all 4 Nitto's on my 2022 TRD PRO.
They are really good to do business with ----- if you are in New England, check them out..selling 4runners at MSRP, no dealer add-on's and work hard to resolve any outstanding problems.
Old 09-02-2022, 03:39 PM #22
Matt831 Matt831 is offline
Matt831 will become famous soon enough
My advice is too ask the service advisor to have a senior technician balance your tires with the proper flange plate adapter on a Road Force Machine.
I am sure something like this was mentioned in the above posts but I did not read through the whole thing.
I ended up junking the Terra Grapplers after 25,000 miles. While they were one of the few tires that balanced "ok", it only lasted till the first rotation.
I have since went with Michelins.
Matt831 is offline   Reply With QuoteReply With Quote
Old 09-11-2022, 12:04 PM #23
Thanks for the feedback------- the dealer did replace all 4 Nitto Grapplers..... road force balanced the new ones --- PROBLEM SOLVED
Old 09-13-2022, 01:32 PM #24
Charles Bronson Charles Bronson is offline
Charles Bronson has a spectacular aura about Charles Bronson has a spectacular aura about
Glad you got it sorted out. My wife wanted to outfit her 2020 TRD ORP just like a Pro so I did the Pro wheels and Grappler G2s.
We haven't had any issues with them through 2 full years of use and nearly 22K miles. I cross-rotate the tires every 3K miles to keep the outer shoulders from feathering which is a common issue with all AT tires.
When changing from the crap all season OEM Bridgestones to the G2s, I noted an increase in tire noise and a very minor increase in overall vibration chassis at highway speed. I noted the same when adding Pirelli Scorpion All Terrain tires on our 2015 Outback. I don't care what AT tires you have, no AT tire will have the NVH characteristics of a passenger style/all season/performance tire. AT thread blocks are too pliable and big. Same goes for braking in the dry and wet. AT tires make dismal street tires. It's all a compromise.
Charles Bronson is offline   Reply With QuoteReply With Quote
Old 11-03-2023, 05:47 PM #25
BayArea_4Runner's Avatar
BayArea_4Runner BayArea_4Runner is offline
BayArea_4Runner is on a distinguished road
hey guys, sorry to resurrect an old thread, but I also just purchased and mounted Nitto Terra Grappler G2s in 265/70R17 to my stock ORP a few weeks ago.
As a control, I had no shakes at all from the stock Dunlops, as well as no suspension mods on my vehicle.
The shop I purchased the Nittos from initially did a regular balance and I immediately noticed the shakes from 60-65mph on a long road trip I did the following weekend.
A few days later, I went back to the same shop and had them RF balance the tires, as well as provide me with the values. They recorded 12lb in the front two and 15lb in the back two. (Down from 19lb originally.)
The following day, I still noticed some vibration but a bit less, and more intermittent. I read from other posts that these tires like to "flat spot" more, especially when its cold due to the compound that allows these tires to last 60K and be M+S rated. However, I spoke to a Nitto rep who told me that shouldn't be the case at all.
Anyways, today I filled up my tires from 32 PSI to 36 PSI and got the chance to drive about 100 miles and mostly the issue is gone.
There is definitely some more road feel with these tires at this PSI, and on some roads going over 60mph, I still notice a slight vibration to the steering wheel, but not a steady vibration that I had observed before the RF balance. In other words, it vibrates on bumpier highway roads but no vibration at all on smoother roads.
I'll continue to monitor from here.
Hopefully that info is helpful to someone that is searching
BayArea_4Runner is offline   Reply With QuoteReply With Quote
Old 11-03-2023, 09:50 PM #26
CutthroatSlam CutthroatSlam is offline
CutthroatSlam is a splendid one to behold CutthroatSlam is a splendid one to behold CutthroatSlam is a splendid one to behold CutthroatSlam is a splendid one to behold CutthroatSlam is a splendid one to behold CutthroatSlam is a splendid one to behold CutthroatSlam is a splendid one to behold CutthroatSlam is a splendid one to behold
There are things you can do once it is worn into the tires. First, rotate the tires diagonally so the next wear is opposite of the current. Second, put balance beads in the tires, then have them road force balanced.
CutthroatSlam is offline   Reply With QuoteReply With Quote
back , highway , pro , trd , vibration
2022 TRD PRO - "lime rush" Fort Myers FLORIDA Mark4runnar 5th gen T4Rs 7 01-26-2022 03:19 PM
Vibration when braking at highway speeds alms_lefko 4th Gen T4Rs 14 03-31-2015 04:26 PM
3" Cornfed Lift Nitto Terra's & MB Motoring V Drive Wheels "Pics" husky62 4th Gen T4Rs 35 03-25-2010 11:28 AM
hard shaking/vibration at highway speeds mx52nr 3rd gen T4Rs 10 11-05-2007 07:48 PM
vibration at high speeds and "clink" when shifting out of reverse airbag 3rd gen T4Rs 1 10-03-2007 10:38 AM
