08-11-2022, 09:12 AM
What do you use to get rid of tree sap/pitch?
We have a 2022 Barcelona Red ORP, picked up in March of this year. I have picked up some tree sap and pitch spots which the regular car soap won't touch. I thought of using old fashioned paint thinners, but don't want to damage the finish. Any ideas?
2022 Barcelona Red TRD ORP, KDSS, Moonroof
1999 4Runner SR5, bone stock, just turned over 200K
08-11-2022, 09:17 AM
Real Name: Jim
Real Name: Jim
Goo Gone works pretty well. There are other products that work on this, just check in any auto parts store.
2019 Nautical Blue SR5. Mostly stock but a few mods: Borla muffler, blacked out badges, removed the running boards, painted the silver roof rails with bed liner, painted the wheels gloss black, Weather Tech window deflectors. AFE replacement air filter in stock air box & removed the charcoal after filter, DC Sports exhaust tip. H11 to H9 headlight bulb swap. 265/70/17 Falken Wildpeak AT3W tires, Sprint Booster, 1" Cornfed leveling lift.
08-11-2022, 09:30 AM
Ive used rubbing alcohol for years with no ill effects. It works great.
08-11-2022, 10:13 AM
Turpentine. That is made from pine pitch. For tar use mineral spirits.
08-11-2022, 10:22 AM
It doesn't mar the gloss of the paint?
08-11-2022, 10:36 AM
Light it on fire and start over.
2019 TRD Offroad | Dobinson's suspension/UCA | Warn bumper | M8000 winch | Victory4x4 Strike bumper |BFG 33’s | 4xInnovations sliders/skids | Frontrunner Slimline 2| Safari snorkel | Rago Fab molle panels/shelf | ICECO fridge slide | AJC cargo Plate.
it will strip any wax thats left on the clear coat. make sure you wax it at a minimum. there are some silicon hybrid sealants available too (step down from a ceramic coating) you can then do a old school coat of wax over the sealant for an extra barrier of protection.
https://shinesupply.com/collections/...oducts/daddy-o this stuff is easy to apply, let it set for 15 minutes after the last panel is applied, wipe off
https://shinesupply.com/collections/...applicator-8oz stack this on top.
i've had good luck using a clay bar to remove some sap but it was not easy. chemicals are better, work smarter not harder lol
08-11-2022, 10:39 AM
08-11-2022, 01:02 PM
WD-40 works on alot of stuff. It's food de-gradable. I used LPS Degreaser on a paper towel just rubbed what was left from when I scraped off by stubby thumb nail.
Take Off You Hoser
Boston Bruins #1 2018 TRD OR Super White, Few Mods: Tinted Frt windows,Eibachs Set @ 0.85 up Frt, , Cooper Discoverer ST/MAXX 275/70/17 Interior LED's, H9 Lo Beams, Anytime LED Fog lights, Led Backup lights, CF overlays above Glove Box, Steering Wheel & all Door Control Panels to match OEM CF Center Console, Pro Grill, Fangs, Bruins on Startup Screen.
08-11-2022, 01:03 PM
This stuff works great.
2017 Silver SR5 Premium
Vietnam 67-68
Greed and corruption are rampant.
08-11-2022, 01:24 PM
Oh god don't use paint thinner... Try a clay bar...
08-11-2022, 01:32 PM
Clay bay was a fail for me. Added to the problem.
08-11-2022, 01:43 PM
I had a vehicle sit under a tree for over a year while I worked on it. Once fit mechanically, there was now the issue of sap covering the vehicle, dropped from a silver maple.
I am not the type to spend hours going over my paint with Goo Gone, however a few automatic washes (with brushes) will get it off completely.
Touchless are a waste of money for stubborn sap, I wouldn’t even try it. Maybe once it’s all gone if you prefer touchless.
08-11-2022, 02:06 PM
Speaking as one who details cars for a living, good lord, no! The degreaser spray is going to be pretty tough on a painted surface. A paper towel is only a few steps away from sandpaper. Used together on a dark color, you're going to be able to see each individual "repair" after you're done.
My advice: Isopropyl Alcohol liberally applied to a clean microfiber towel. Gently rub the area with very little pressure. Let the alcohol dissolve the sap as opposed to trying to mechanically remove it. Polish and wax / seal the entire area when done.
08-11-2022, 02:24 PM
WD-40 and a microfiber cloth.
lll 2016 SR5P MGM lll OEM TRD Pro Matte Black Wheels w/ Falken Wildpeak LT255/80 17 "Pizza Cutters" l Bilstein 5100 F+R set at 1.75F + 1" Cornfed Rear Spacers l OEM TRD F+R Lower Valances l Prinsu Non-Drill Full Length Roof Rack l Shrockworks Sliders l RCI Steel Skid Plate l OEM bi-LED Headlights l DD SS3 Sport Amber Fogs l
My 3rd Row Delete Thread
Thread Tools |
Display Modes |
Rate This Thread |
Linear Mode
